Date/Time: Tue, 15 Apr 2025 13:47:43 +0000
How to be signed in to different prop firms
View Count: 536
[2024-05-06 22:48:24]
JabbALot - Posts: 15
Hey there, I have apex and topstep propfirm trading accounts, i havent been able to figure out how to get them signed on at the same time. I have support for the copy trading mechanism, just curious how to sign on to apex and topstep at the same time
[2024-05-06 23:20:04]
John - SC Support - Posts: 39274
You would need to two separate installations of Sierra Chart to do this and have one connected to APEX and the other to TopStep. Refer to the following for how to install a second Sierra Chart:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
Keep in mind, the built-in "Order Allocation To Trade Accounts" only works with a single connection. So there is no way to copy orders between services.
[2025-04-01 23:27:18]
coachted - Posts: 389
since topstep and apex are both rithmic based data can I use trade copier in one instance of sierra charts
[2025-04-02 15:10:38]
The "Order Allocation to Trade Accounts" that is built into Sierra Chart does not allow for copying between different accounts. It does not matter that they are both Rithmic, you use two different logins for these accounts.
There is at least one third-party tool that does allow for copying between accounts.
