Date/Time: Sun, 24 Nov 2024 19:05:22 +0000
ZigZag showing only Zeros for Volume/Length in Ticks
View Count: 183
[2024-05-06 18:07:09] |
mandano89 - Posts: 24 |
Hello, I am using the ZigZag Study and try to display the Volume and Length in Ticks. Although I enabled the option, it is only showing zeros (see image). What am I doing wrong? I am using Service Package 5. |
ZigZag_Zeros.PNG / V - Attached On 2024-05-06 18:06:21 UTC - Size: 116.58 KB - 48 views |
[2024-05-06 22:37:15] |
You have "Volume to Accumulate" set to "None", but then you are asking for information regarding the volume. Change the "Volume to Accumulate" to something other than "None". Refer to the following: Zig Zag: Volume To Accumulate For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
