Date/Time: Mon, 16 Sep 2024 19:54:32 +0000
Volume At Price Threshold Aler V2 study bug
View Count: 264
[2024-05-06 16:45:18] |
User748811 - Posts: 18 |
As you can see in attachment, there is continuous Ask imbalance in top of bar at 8:30 EST May 3 whatever M1, M5, M15 bar. But Adjacent Alert Highlight at top of bar is valid only in M15 bar.I think the reason is that there are only 5 group parameter about Adjacent Alert Highlight. By the way, Trigger0-46, Adjacent Alert Highlight bottom/top 1-5 should be set with same parameter or can be set unifiedly. Otherwise, it is very troublesome for me to set all of them one by one. |
GC_ask imbalance_830_M5.png / V - Attached On 2024-05-06 16:45:02 UTC - Size: 194.47 KB - 48 views GC_ask imbalance_830_M5_footprint.png / V - Attached On 2024-05-06 16:45:07 UTC - Size: 133.01 KB - 39 views GC_ask imbalance_830_M15.png / V - Attached On 2024-05-06 16:45:11 UTC - Size: 93.18 KB - 42 views |
[2024-05-06 16:50:53] |
John - SC Support - Posts: 34455 |
Yes, this is correct. There are already 5 groupings in that bar, so there is no way to display another one. By the way, Trigger0-46, Adjacent Alert Highlight bottom/top 1-5 should be set with same parameter or can be set unifiedly. Otherwise, it is very troublesome for me to set all of them one by one.
You only need to change the first item (Trigger 0 (SG1)). Once you have modified this one and then select OK to close that window, the other 46 trigger subgraphs will update to the settings of the first one. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-08 17:34:19] |
1.Why limit only show 5 adjacent alert highlight ? Wouldn't it be better to show all? 2.I try to only change Trigger 0 (SG1) and SG49 and select OK.But no global modification occurs.I don't know what I did wrong. |
[2024-05-08 19:10:55] |
1. There is a limitation on the number of Subgraphs in the system, which is 60. Therefore, we can not have everything, hence the tradeoff of 46 triggers and 5 groupings is how we set it up. 2. Changing Trigger 0, then selecting OK to close the window and then opening the window again will change all of the triggers to be the same as what you set for Trigger 0. The above does not hold for the Adjacent Alerts Highlights. You would need to change each of those individually. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
