Date/Time: Sun, 24 Nov 2024 17:02:01 +0000
"balance sheet" / "balance" of my entire (historic) simulated trades
View Count: 236
[2024-05-06 16:36:38]
visunion - Posts: 4
Dear SC Team,
I just wanted to ask you, if there is a way where I can see a "balance sheet" / "balance" of my entire (historic) simulated trades I have made in my SC account or does it not exist in SC?
Thank you!
[2024-05-06 22:08:17]
If these are simulated trades using the built-in Simulation Mode, then the only place where this information exists is on your computer. Anything that is available will be in your Trade Activity Log.
If you have deleted information or files for some reason, then you can look in the Backups folder to see if there are backups of the Trade Activity Logs that you may need. Refer to the following:
Trade Activity Log: Restoring Backups of Trade Activity Logs
If these are simulation trades that were done using our "Simulated Futures Trading Service", then again the first place to look is your Trade Activity Log. But if you are missing something, then we might be able to recover some of the information. We would have to check into this to see what could be done.
[2024-05-13 10:04:17]
visunion - Posts: 4
I have found them all in my Backup data file. Do you know how I can open them? The data file ending name is: "Sim1.simulated.data".
I suppose the only waz to open them, would be through SC, right?
Thanks!
[2024-05-13 16:53:00]
[2024-05-14 08:26:01]
visunion - Posts: 4
Ok. One important thing:
If I delete them all, from the Backup+Trade Activity Log folder, I suppose that SC won´t send any simulated information to my broker account, when I switch off the simulation mode in my SC account, right?
Thanks!
[2024-05-14 10:28:42]
Sierra_Chart Engineering - Posts: 17156
There is no functionality like this that even exists:
So there is no possibility under any condition for this to happen.
[2024-05-14 15:31:38]
visunion - Posts: 4
ok. Thanks!
