Date/Time: Sun, 24 Nov 2024 19:20:49 +0000
FOREX-FXCM
View Count: 210
[2024-05-06 15:31:52] |
User970578 - Posts: 2 |
Hola, no me deja poner ordenes en forex. ¿necesito contratar datos extras ?
[2024-05-06 15:48:26] |
From Google Translate: Hello, it won't let me place orders in forex. Do I need to hire extra data?
Our servers show that you are connected to CQG for your trading service. If this is correct, then the problem you are having is due to CQG not supporting trading for FOREX. You would have to use a different service, and most likely a different broker. Sierra Chart only has support for trading FOREX with Interactive Brokers and LMAX. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
