Date/Time: Sun, 24 Nov 2024 19:06:52 +0000
The market doesn't move
View Count: 337
[2024-05-06 14:36:38]
DiegoGuerra2_0_0_2 - Posts: 15
I have the problem that the market doesn't move. As soon as I open Sierrachart, the chart is loaded up to the time I currently have, but then it no longer moves. I have Data Feed and haven't changed anything in the setting, the problem occurred overnight.
[2024-05-06 15:17:31]
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2024-05-06 15:18:20]
MichaelPPTF - Posts: 69
Look at the bottom right corner of the chart - do you see a green box with a number or a red box with a number?
If it's red, drag the chart to the right most edge, you should see it updating.
[2024-05-06 16:29:13]
moe1up - Posts: 22
I am having the same issue and just followed the instructions. The symbol is ES.
2024-05-06 12:26:33.486 | Software version: 2634 64-bit
2024-05-06 12:26:33.486 | Primary Thread ID: 18772
2024-05-06 12:26:33.486 | Usage end date: 2024-05-08
2024-05-06 12:26:33.486 | Enabled for: Advanced Features 2.
2024-05-06 12:26:33.486 | Enabled for: Sierra Chart Historical Data Service.
2024-05-06 12:26:33.486 | Enabled for: Denali Real-Time Exchange Data Feed.
2024-05-06 12:26:33.486 | Enabled for: Delayed Denali Exchange Data Feed.
2024-05-06 12:26:33.486 | Allow Support for Sierra Chart Data Feeds is enabled.
2024-05-06 12:26:33.486 | Current selected Data/Trading service: Rithmic Direct - DTC
2024-05-06 12:26:33.486 | Custom symbol settings values: enabled
2024-05-06 12:26:33.486 | Chart Update Interval: 500
2024-05-06 12:26:33.486 | Intraday Data Storage Time Unit: 0
2024-05-06 12:26:33.486 | Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00)
2024-05-06 12:26:33.486 | 2024-05-06 16:26:33 Local computer time in UTC
2024-05-06 12:26:33.486 | 2024-05-06 12:26:33 Local computer time in SC Time Zone
2024-05-06 12:26:33.486 | 2024-05-06 16:22:30 Server time in UTC
2024-05-06 12:26:33.486 | Local computer UTC time and Server UTC time difference: 1 seconds.
2024-05-06 12:26:33.486 | Program path: C:\SierraChart\
2024-05-06 12:26:33.486 | Data Files path: C:\SierraChart\Data\
2024-05-06 12:26:33.486 | OS Version Number: 10.0
2024-05-06 12:26:33.486 | Locale Setting: C
2024-05-06 12:26:33.487 | DLLs: BetterAnchoredVWAP_64.dll, NewFile_64.dll, OrderFlowLabs.com.free_64.dll, OrderFlowLabs.com.free_ARM64.dll, sst_draw_imbalance_64.dll, sst_FreeBundle_64.dll, Test01_64.dll, UserContributedStudies_64.dll, WayToGo_64.dll, xXmoe1upXx_64.dll
2024-05-06 12:26:33.487 | Allowed protected custom studies: OrderFlowLabs.com FREE, SST_FreeBundle
2024-05-06 12:26:33.487 | Crash reporter started: true
2024-05-06 12:26:46.576 | Saved Chartbook: E-Mini Gold Futures.Cht. Time: 0.0039 seconds.
2024-05-06 12:26:46.587 | Saved Chartbook: E-Mini NASDAQ 100 Futures.Cht. Time: 0.0097 seconds.
2024-05-06 12:26:46.593 | Saved Chartbook: E-Mini SP500 Futures.Cht. Time: 0.0047 seconds.
2024-05-06 12:26:46.599 | Saved Chartbook: WTI Crude Oil Futures.Cht. Time: 0.0050 seconds.
2024-05-06 12:27:35.775 | ESM4.CME 1 Min #1 | Reloading chart.
2024-05-06 12:27:35.785 | ESM4.CME 1 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESM4.CME.scid
2024-05-06 12:27:35.793 | ESM4.CME 1 Min #1 | Chart data loading complete.
2024-05-06 12:27:44.646 | File >> Disconnect selected.
2024-05-06 12:27:44.646 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-05-06 12:27:44.647 | DTC Client socket (2) | CloseSocket call.
2024-05-06 12:27:44.647 | DTC Client socket (2) | Max send buffers used during socket life: 4
2024-05-06 12:27:44.647 | DTC Client socket (2) | Max send buffer size during socket life: 500
2024-05-06 12:27:44.647 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2024-05-06 12:27:44.647 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-05-06 12:27:44.648 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2024-05-06 12:27:44.648 | DTC Client socket (1) | CloseSocket call.
2024-05-06 12:27:44.648 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2024-05-06 12:27:44.648 | Rithmic Direct - DTC | Disconnected.
2024-05-06 12:27:44.648 | Canceling queued historical data download request for GCM4.COMEX Intraday data.
2024-05-06 12:27:44.648 | Removing historical data download ID 2.
2024-05-06 12:27:44.648 | Canceling queued historical data download request for NQM4.CME Intraday data.
2024-05-06 12:27:44.648 | Removing historical data download ID 3.
2024-05-06 12:27:44.648 | Canceling queued historical data download request for ESM4.CME Intraday data.
2024-05-06 12:27:44.649 | Removing historical data download ID 4.
2024-05-06 12:27:44.649 | Canceling queued historical data download request for CLM4.NYMEX Intraday data.
2024-05-06 12:27:44.649 | Removing historical data download ID 5.
2024-05-06 12:27:44.649 | HD Request # 1 | Active download canceled.
2024-05-06 12:27:44.649 | Historical data download thread signaled to stop.
2024-05-06 12:27:44.649 | Socket (3) | CloseSocket call.
2024-05-06 12:27:44.649 | Socket (3) | Shutdown started. Waiting for graceful close.
2024-05-06 12:27:44.649 | HD Request # 1 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESZ3.CME
2024-05-06 12:27:44.649 | HD Request # 1 | Completion time: 4m 53s.
2024-05-06 12:27:44.649 | HD Request # 1 | Intraday data download complete for ESZ3.CME. Unique request ID: 1
2024-05-06 12:27:44.649 | Removing historical data download ID 1.
2024-05-06 12:27:44.649 | HD Request # 1 | Enabling Intraday chart updating for symbol.
2024-05-06 12:27:44.649 | No download requests in the queue to start downloads for.
2024-05-06 12:27:44.761 | DTC Client socket (2) | Socket gracefully closed by remote side.
2024-05-06 12:27:44.761 | DTC Client socket (2) | Closed.
2024-05-06 12:27:44.766 | Socket (3) | Socket gracefully closed by remote side.
2024-05-06 12:27:44.766 | Socket (3) | Closed.
2024-05-06 12:27:44.767 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-05-06 12:27:44.767 | DTC Client socket (1) | Closed.
2024-05-06 12:27:52.061 |
2024-05-06 12:27:52.061 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Europe-Non-Aggregated
2024-05-06 12:27:52.061 | Rithmic Direct - DTC | Connecting to the server rsc-ie.rithmic.com. Port 40804
2024-05-06 12:27:52.100 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2024-05-06 12:27:52.100 | DTC Client socket (1) | New receive buffer size: 0
2024-05-06 12:27:52.100 | DTC Client socket (1) | Connecting to IP: 34.249.49.87.
2024-05-06 12:27:52.217 | Rithmic Direct - DTC | Network connection to server complete.
2024-05-06 12:27:52.217 | Rithmic Direct - DTC | Starting socket receive thread.
2024-05-06 12:27:52.217 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2024-05-06 12:27:52.217 | Rithmic Direct - DTC | Sending logon request message.
2024-05-06 12:27:52.680 | Rithmic Direct - DTC | Received logon response.
2024-05-06 12:27:52.680 | Rithmic Direct - DTC | Server Name: .
2024-05-06 12:27:52.680 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2024-05-06 12:27:52.680 | Rithmic Direct - DTC | Successfully connected.
2024-05-06 12:27:52.680 | Rithmic Direct - DTC | Trading is supported.
2024-05-06 12:27:52.680 | Rithmic Direct - DTC | Order cancel and replace is supported.
2024-05-06 12:27:52.680 | Rithmic Direct - DTC | OCO Orders supported.
2024-05-06 12:27:52.680 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2024-05-06 12:27:52.680 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2024-05-06 12:27:52.680 | Rithmic Direct - DTC | Connected to server complete.
2024-05-06 12:27:52.682 | No download requests in the queue to start downloads for. | Number times message added: 3
2024-05-06 12:27:52.682 | Using symbol data fast lookup vector
2024-05-06 12:27:52.683 | Rithmic Direct - DTC | Starting real-time market data updates for: ESZ3.CME. ID: 1 Service code: rithmic.trading
2024-05-06 12:27:52.688 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-ie.rithmic.com. Port 40805
2024-05-06 12:27:52.689 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2024-05-06 12:27:52.689 | DTC Client socket (2) | New receive buffer size: 0
2024-05-06 12:27:52.689 | DTC Client socket (2) | Connecting to IP: 34.249.49.87.
2024-05-06 12:27:52.693 | Rithmic Direct - DTC | Requesting security definition data for: ESZ3.CME. ID: 1
2024-05-06 12:27:52.693 | Added historical Intraday data request for ESZ3.CME to the queue.
2024-05-06 12:27:52.693 | Intraday data recording state for symbol ESZ3.CME is set to download 'Pending'.
2024-05-06 12:27:52.693 | Triggering next historical data download in queue.
2024-05-06 12:27:52.693 | Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees.
2024-05-06 12:27:52.694 | Delaying start of download for ESZ3.CME.
2024-05-06 12:27:52.796 | Rithmic Direct - DTC | Starting real-time market data updates for: ESM4.CME. ID: 2 Service code: rithmic.trading
2024-05-06 12:27:52.796 | Rithmic Direct - DTC | Requesting security definition data for: ESM4.CME. ID: 2
2024-05-06 12:27:52.796 | Added historical Intraday data request for ESM4.CME to the queue.
2024-05-06 12:27:52.796 | Intraday data recording state for symbol ESM4.CME is set to download 'Pending'.
2024-05-06 12:27:52.796 | Triggering next historical data download in queue.
2024-05-06 12:27:52.810 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-05-06 12:27:52.810 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-05-06 12:27:52.811 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-05-06 12:27:52.811 | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-05-06 12:27:53.496 | Rithmic Direct - DTC (Data) | Received logon response.
2024-05-06 12:27:53.496 | Rithmic Direct - DTC (Data) | Server Name: .
2024-05-06 12:27:53.496 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-05-06 12:27:53.496 | Rithmic Direct - DTC (Data) | Successfully connected.
2024-05-06 12:27:53.496 | Rithmic Direct - DTC (Data) | Trading is not supported.
2024-05-06 12:27:53.496 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2024-05-06 12:27:53.496 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2024-05-06 12:27:53.496 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM4.CME
2024-05-06 12:27:53.496 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESZ3.CME
2024-05-06 12:27:53.831 | Rithmic Direct - DTC (Data) | Received security definition for symbol ESM4.CME
2024-05-06 12:28:09.139 | HD Request # 2 | Downloading Intraday chart data for ESZ3.CME to the file ESZ3.CME.scid. Service: rithmic.trading
2024-05-06 12:28:09.142 | HD Request # 2 | Download start date-time: 2023-12-15 09:29:59.000000. File last date-time: 2023-12-15 09:29:59.411001
2024-05-06 12:28:09.143 | HD Request # 2 | Using server: rsc-ie.rithmic.com port 40806. Use encryption.
2024-05-06 12:28:09.143 | Socket (3) | Creating socket. Using TLS 1.2.
2024-05-06 12:28:09.143 | Socket (3) | New receive buffer size: 0
2024-05-06 12:28:09.143 | Socket (3) | Connecting to IP: 34.249.49.87.
2024-05-06 12:28:09.259 | HD Request # 2 | Sending historical data logon request message.
2024-05-06 12:28:09.718 | HD Request # 2 | Requesting Intraday data. Start date-time: 2023-12-15 09:29:59. Record interval: 0. Symbol: ESZ3.CME
2024-05-06 12:28:12.067 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (4) | Creating socket. Using TLS 1.2.
2024-05-06 12:28:12.067 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (4) | New receive buffer size: 0
2024-05-06 12:28:12.067 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (4) | Connecting to IP: 38.79.0.89.
2024-05-06 12:28:12.302 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (4) | Socket gracefully closed by remote side. | Number times message added: 1
2024-05-06 12:28:12.307 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (4) | CloseSocket call.
2024-05-06 12:28:12.307 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-05-06 12:28:12.307 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (4) | Closed.
Date Time Of Last Edit: 2024-05-06 16:29:40
[2024-05-06 17:32:45]
moe1up - Posts: 22
Disregard. My charts are back working now.
[2024-05-06 18:50:17]
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-05-06 20:53:23.326
DTC Client socket (1) | Closed. | 2024-05-06 20:53:23.326
Software version: 2528 64-bit | 2024-05-06 20:53:23.619
Safe Mode enabled | 2024-05-06 20:53:23.619
Primary Thread ID: 9972 | 2024-05-06 20:53:23.619
Usage end date: 2024-06-06 | 2024-05-06 20:53:23.619
Enabled for: Advanced Features 2. | 2024-05-06 20:53:23.619
Enabled for: Sierra Chart Historical Data Service. | 2024-05-06 20:53:23.619
Enabled for: Denali Real-Time Exchange Data Feed. | 2024-05-06 20:53:23.619
Enabled for: Delayed Denali Exchange Data Feed. | 2024-05-06 20:53:23.619
Allow Support for Sierra Chart Data Feeds is enabled. | 2024-05-06 20:53:23.619
Current selected Data/Trading service: SC Data - All Services | 2024-05-06 20:53:23.619
Custom symbol settings values: enabled | 2024-05-06 20:53:23.619
Chart Update Interval: 500 | 2024-05-06 20:53:23.619
Intraday Data Storage Time Unit: 1 | 2024-05-06 20:53:23.619
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2024-05-06 20:53:23.619
2024-05-06 18:53:23 Local computer time in UTC | 2024-05-06 20:53:23.619
2024-05-06 20:53:23 Local computer time in SC Time Zone | 2024-05-06 20:53:23.619
2024-05-06 18:38:12 Server time in UTC | 2024-05-06 20:53:23.619
Local computer UTC time and Server UTC time difference: 0 seconds. | 2024-05-06 20:53:23.619
Program path: C:\SierraChart\ | 2024-05-06 20:53:23.619
Data Files path: C:\SierraChart\Data\ | 2024-05-06 20:53:23.619
OS Version Number: 10.0 | 2024-05-06 20:53:23.619
Locale Setting: C | 2024-05-06 20:53:23.619
DLLs: UserContributedStudies_64.dll | 2024-05-06 20:53:23.619
Allowed protected custom studies: | 2024-05-06 20:53:23.619
Crash reporter started: true | 2024-05-06 20:53:23.619
SC DTC Delayed Exchange Data | Connecting to the server ds27.sierracharts.com. Port 10043 | 2024-05-06 20:53:25.198
DTC Client socket (1) | Creating socket. | 2024-05-06 20:53:25.199
DTC Client socket (1) | New receive buffer size: 0 | 2024-05-06 20:53:25.199
DTC Client socket (1) | Connecting to IP: 38.142.127.146. | 2024-05-06 20:53:25.199
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-05-06 20:53:25.323
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-05-06 20:53:25.323
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-05-06 20:53:25.323
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-05-06 20:53:25.452
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-05-06 20:53:25.452
SC DTC Delayed Exchange Data | Received logon response. | 2024-05-06 20:53:25.576
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-05-06 20:53:25.576
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-05-06 20:53:25.576
SC DTC Delayed Exchange Data | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2024-05-06 20:53:25.576
SC DTC Delayed Exchange Data | Failed connections: 342 | 2024-05-06 20:53:25.576
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-05-06 20:53:25.576
DTC Client socket (1) | CloseSocket call. | 2024-05-06 20:53:25.577
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-05-06 20:53:25.577
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-05-06 20:53:25.577
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-05-06 20:53:25.577
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-05-06 20:53:25.699
DTC Client socket (1) | Closed. | 2024-05-06 20:53:25.699
SC DTC Delayed Exchange Data | Connecting to the server ds26.sierracharts.com. Port 10043 | 2024-05-06 20:53:27.564
DTC Client socket (1) | Creating socket. | 2024-05-06 20:53:27.565
DTC Client socket (1) | New receive buffer size: 0 | 2024-05-06 20:53:27.565
DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2024-05-06 20:53:27.565
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-05-06 20:53:27.694
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-05-06 20:53:27.694
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-05-06 20:53:27.695
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-05-06 20:53:27.841
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-05-06 20:53:27.841
SC DTC Delayed Exchange Data | Received logon response. | 2024-05-06 20:53:27.985
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-05-06 20:53:27.985
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-05-06 20:53:27.985
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-05-06 20:53:27.985
SC DTC Delayed Exchange Data | Failed connections: 343 | 2024-05-06 20:53:27.985
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-05-06 20:53:27.985
DTC Client socket (1) | CloseSocket call. | 2024-05-06 20:53:27.985
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-05-06 20:53:27.985
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-05-06 20:53:27.985
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-05-06 20:53:27.985
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-05-06 20:53:28.108
DTC Client socket (1) | Closed. | 2024-05-06 20:53:28.108
SC DTC Delayed Exchange Data | Connecting to the server ds28.sierracharts.com. Port 10043 | 2024-05-06 20:53:29.992
DTC Client socket (1) | Creating socket. | 2024-05-06 20:53:29.992
DTC Client socket (1) | New receive buffer size: 0 | 2024-05-06 20:53:29.992
DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2024-05-06 20:53:29.992
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-05-06 20:53:30.114
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-05-06 20:53:30.114
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-05-06 20:53:30.115
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-05-06 20:53:30.272
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-05-06 20:53:30.272
SC DTC Delayed Exchange Data | Received logon response. | 2024-05-06 20:53:30.403
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-05-06 20:53:30.403
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-05-06 20:53:30.403
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-05-06 20:53:30.403
SC DTC Delayed Exchange Data | Failed connections: 344 | 2024-05-06 20:53:30.403
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-05-06 20:53:30.403
DTC Client socket (1) | CloseSocket call. | 2024-05-06 20:53:30.403
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-05-06 20:53:30.403
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-05-06 20:53:30.403
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-05-06 20:53:30.403
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-05-06 20:53:30.522
DTC Client socket (1) | Closed. | 2024-05-06 20:53:30.522
SC DTC Delayed Exchange Data | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2024-05-06 20:53:32.404
DTC Client socket (1) | Creating socket. | 2024-05-06 20:53:32.443
DTC Client socket (1) | New receive buffer size: 0 | 2024-05-06 20:53:32.443
DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2024-05-06 20:53:32.443
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-05-06 20:53:32.573
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-05-06 20:53:32.573
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-05-06 20:53:32.573
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-05-06 20:53:32.747
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-05-06 20:53:32.747
SC DTC Delayed Exchange Data | Received logon response. | 2024-05-06 20:53:32.874
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-05-06 20:53:32.874
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-05-06 20:53:32.874
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-05-06 20:53:32.874
SC DTC Delayed Exchange Data | Failed connections: 345 | 2024-05-06 20:53:32.874
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-05-06 20:53:32.874
DTC Client socket (1) | CloseSocket call. | 2024-05-06 20:53:32.874
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-05-06 20:53:32.874
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-05-06 20:53:32.874
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-05-06 20:53:32.874
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-05-06 20:53:32.997
DTC Client socket (1) | Closed. | 2024-05-06 20:53:32.997
SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2024-05-06 20:53:34.862
DTC Client socket (1) | Creating socket. | 2024-05-06 20:53:34.863
DTC Client socket (1) | New receive buffer size: 0 | 2024-05-06 20:53:34.863
DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2024-05-06 20:53:34.863
SC DTC Delayed Exchange Data | Network connection to server complete. | 2024-05-06 20:53:34.986
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2024-05-06 20:53:34.986
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2024-05-06 20:53:34.986
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2024-05-06 20:53:35.124
SC DTC Delayed Exchange Data | Sending logon request message. | 2024-05-06 20:53:35.124
SC DTC Delayed Exchange Data | Received logon response. | 2024-05-06 20:53:35.269
SC DTC Delayed Exchange Data | Server Name: RealTimeServer. | 2024-05-06 20:53:35.269
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2024-05-06 20:53:35.269
SC DTC Delayed Exchange Data | Logon error received from server: Invalid login data. | 2024-05-06 20:53:35.269
SC DTC Delayed Exchange Data | Failed connections: 346 | 2024-05-06 20:53:35.269
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2024-05-06 20:53:35.269
DTC Client socket (1) | CloseSocket call. | 2024-05-06 20:53:35.270
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2024-05-06 20:53:35.270
SC DTC Delayed Exchange Data | Disconnected from the server. | 2024-05-06 20:53:35.270
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2024-05-06 20:53:35.270
DTC Client socket (1) | Socket gracefully closed by remote side. | 2024-05-06 20:53:35.393
DTC Client socket (1) | Closed. | 2024-05-06 20:53:35.393
Date Time Of Last Edit: 2024-05-06 18:53:44
[2024-05-06 18:54:28]
The symbol is GCQ4-Comex
[2024-05-06 22:45:44]
You need to update to the current release. There have been changes to the delayed streaming data and the version you are on does not work with it any longer. Follow these instructions to update:
[2024-05-07 08:30:35]
Okey, it's still working, thanks for your service :D
