Date/Time: Sun, 24 Nov 2024 18:45:35 +0000
NEW ACCOUNT
View Count: 252
[2024-05-06 14:03:44]
NQ2024 - Posts: 2
HEY , I create a new account am go to pay for Integrated Standard Sierra Chart (Service Package 10) Price: 36 USD/month
my questions is : there is any more fee should i pay for using CME .
i will use rithmic account from phidias prop firm as they recommend this platform to use.
thanks for support .
[2024-05-06 15:16:34]
It depends on where you will get your data from.
If you are going to get your data from Rithmic, then there is nothing else you need from us.
If you are going to get your data from us (our recommendation) then you will need to go through the setup for the data by following these instructions:
Prior to setting up the data from us, you need to understand that you must have a live, funded, futures trading account in order to qualify for the non-professional exchange fees from the CME Group. Refer to the following for more information:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
If you do not have an account that qualifies for the above, then we recommend the solution at the following link:
Easy Solution to CME Funded Trading Account Requirement
[2024-05-06 17:00:10]
NQ2024 - Posts: 2
thank. but up to now i did not understand anything ,,,, so many site so many information
please give a simple answer i will use this platform to trade on prop firm account
but i want to use data from your side ( Denali Exchange Data Feed )
NOTE I WILL BAY THE (Service Package 10) SO THERE IS ANY MORE FEE ?
[2024-05-06 21:23:38]
Since you want to get the data from us, you will need to pay the exchange fee(s) for the exchange(s) for which you want the real-time data.
Also note that the CME Group has a requirement that you have a live, funded, futures trading account order to get the data for the CME Group at the non-professional rates. You also need to be able to connect your Sierra Chart to that live account at least once a month for verification. Refer to the following for more information:
If you do not have a live trading account that will qualify for the above, then we recommend the solution outlined at the following link:
Once you have worked out the trading account issue, then you can go through the following instructions to activate the exchange(s) you want for the CME Group:
