Date/Time: Sun, 24 Nov 2024 19:34:00 +0000
The Chartbook file is not compatible
View Count: 193
[2024-05-06 13:39:24] |
Gunjan54 - Posts: 4 |
Hi Team please help with converting attached Chartbook to the latest version of Sierra Log is as below ***********************Quote******************** 2024-05-05 18:13:40.724 | The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it. File: C:\SierraChart\Data\TicinoTrader_Bookmap2_v.Cht * ***********************Unquote****************** Thanks Gunjan |
TicinoTrader_Bookmap2_v.Cht - Attached On 2024-05-06 13:39:04 UTC - Size: 250.22 KB - 88 views |
[2024-05-06 15:09:59] |
You should contact the creator of that chartbook (TicinoTrader) and get an updated copy from them. The general instructions for opening an older chartbook are at the following link: Chartbooks (Workspaces): Opening Older Chartbooks For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
