Date/Time: Sun, 24 Nov 2024 17:42:40 +0000
Swing High/Low Study Overlay lines intersection
View Count: 276
[2024-05-06 11:04:18] |
funbun - Posts: 90 |
I overlay the Swing H/L over another chart, with the option "Extend until intersection" but as you can see in the screenshot the lines continue through the candles
[2024-05-06 14:32:08] |
The only reason this should occur is if the source study (Swing High/Low) was set to be based on something than the Main Price Graph. Was this the case?
[2024-05-07 14:20:13] |
So in my case it's based on the main graph, changed nothing there. I noticed that when I change the bar period back and forth on both source and destination charts the lines are back again stopping at the chart intersection. How can I replicate it for you to check? |
[2024-05-08 19:35:30] |
Sierra_Chart Engineering - Posts: 17156 |
We will have to look into this.
