Date/Time: Sun, 24 Nov 2024 19:26:15 +0000
Chart Calculator Tool Customisation in Available Control Bar Commands LH Menu
View Count: 250
[2024-05-06 10:31:58] |
User149333 - Posts: 21 |
Hi I'm trying to add 4 iterations of this to my menu. I have done it with countless tools previously, but for some reason I can't find it within the tools or chart menu (I have looked in others). I have set up my options as the tool, but can't see how to add to the toolbar with my saved options: https://app.screencast.com/PBLtbBUBWHgbH Many thanks |
[2024-05-06 14:17:36] |
We are not sure what you are asking. Refer to the following for what we think you are looking for: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-06 14:31:36] |
Ah, I got it. Thanks for the clarification.
