Date/Time: Sun, 24 Nov 2024 19:23:52 +0000
No data on sub instance simulators
View Count: 204
[2024-05-06 09:38:27] |
JbGlobal - Posts: 13 |
Good morning, It seems as though my main instance is receiving simulator data but my sub instance DOM's are blank and charts aren't moving. My current selected service is "Trading Evaluator [trading]". When I switch this back to "SC Data - All Services", everything appears to be working correctly again. I've searched through the forums and tried a few recommendations but still can't get it to work. Am I overlooking something simple? Thank you! Jeff |
[2024-05-06 12:57:28] |
Sierra_Chart Engineering - Posts: 17159 |
Make sure you are using the correct symbols in the sub instance: Data/Trading Service Connection and Symbol Issues: 1.3. Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-06 12:58:00
