Date/Time: Sun, 24 Nov 2024 20:01:53 +0000
Building ACSIL dll
View Count: 218
[2024-05-05 20:24:14] |
MichaelPPTF - Posts: 69 |
Hello SC Engineering, I've got a few questions about building dlls: 1. Why doesn't "Remote Build" support .hpp C++ headers? I know .h/.hpp coexist but I don't understand why wouldn't it support the C++ header. Maybe I just wasn't using it correctly? 2. Since I can't get it to accept .hpp, I chose to build locally with VS C++ Compiler that was installed via SC. Do I have to include the external .hpp header file if I want to distribute the study to other users? 3. What is the best practice to build an arm64 compatible version of the dll? |
[2024-05-05 22:02:37] |
Sierra_Chart Engineering - Posts: 17161 |
1. We are not familiar with those header types. There should be no need for those. Just use .h. 2. You do not have to include any headers when distributing a DLL file. 3. We do not understand the question. You will have to determine how to build an ARM 64 version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-05 22:33:37] |
Do I use windows-msvc-arm64 for building ARM64 compatible dll?
CleanShot 2024-05-05 at 15.31.47.png / V - Attached On 2024-05-05 22:32:25 UTC - Size: 189.47 KB - 50 views |
