Date/Time: Sun, 24 Nov 2024 19:56:53 +0000
Trade activity logs not show Satistics or trade activity
View Count: 265
[2024-05-05 07:07:22] |
User129860 - Posts: 33 |
Hi Support, NOt sure this is relate to recent update that I download ( to latest SC version ) but after doing my replay backtest there are no trade activity or Sattistics. Here are some of my setting from screenshot attached. |
Screenshot 2024-05-05 at 05.03.49.png / V - Attached On 2024-05-05 07:06:27 UTC - Size: 672 KB - 36 views Screenshot 2024-05-05 at 05.04.18.png / V - Attached On 2024-05-05 07:06:36 UTC - Size: 957.07 KB - 39 views Screenshot 2024-05-05 at 05.04.33.png / V - Attached On 2024-05-05 07:06:43 UTC - Size: 865.85 KB - 39 views |
[2024-05-05 07:33:52] |
Sierra_Chart Engineering - Posts: 17161 |
You need to set the Simulation State in the Trade Activity settings window to Simulated. It is currently set to Non-simulated.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-05 07:33:59
[2024-05-05 07:52:27] |
thank you. I will try. Btw, in backtest mode, is there option to set withdrawal amount in frequence? like I want to withdraw if profit positive weekly monthly...?
[2024-05-05 07:57:56] |
I tried to switch to Simulated in Simulation State but only Chart Stats show, but other.
Screenshot 2024-05-05 at 08.57.09.png / V - Attached On 2024-05-05 07:57:28 UTC - Size: 642.91 KB - 44 views Screenshot 2024-05-05 at 08.56.52.png / V - Attached On 2024-05-05 07:57:52 UTC - Size: 575.75 KB - 43 views |
[2024-05-05 08:21:04] |
We do not understand this but any trading has to be implemented by the automated trading system: , is there option to set withdrawal amount in frequence? like I want to withdraw if profit positive weekly monthly...?
The Symbol setting needs to be set to "All Symbols", with no other text. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-05 08:21:22
[2024-05-05 08:25:27] |
thanks, it works now. For the withdrawal, its like option when doing backtest in mt5, that you can simulate how much you want to withdraw from profit. I guess this need to be code within the automated trading system as well? |
[2024-05-05 09:29:20] |
We do not know what is meant by "withdraw from profit". Whatever this exactly is, it would have to be implemented within the automated trading system.
