Date/Time: Sun, 24 Nov 2024 19:47:13 +0000
Status Bar Settings
View Count: 268
[2024-05-05 03:59:39]
user_xyz - Posts: 416
I am looking for a way to make the status bar as small as possible.
Changing this value to anything less than 4 does NOT have any impact.
Global -> General Settings -> Status Bar Width in Characters
Status bar displays approximately 8 characters at setting 4.
I have a handful of SC instances that are ultra light running in a very tiny window I just want to see the color indicator Green-Yellow-Red for monitoring the state of the connection.
[2024-05-05 16:05:50]
You are hitting the minimum size you can set it to. You can not go any smaller. The only other option would be to remove the status bar altogether.
