Date/Time: Sun, 24 Nov 2024 19:54:20 +0000
Range per bar charts- Percent based
View Count: 213
[2024-05-05 01:30:22] |
User566250 - Posts: 37 |
Hello, I use Range Per Bar charts for futures and it being in ticks makes good sense. I would like to use range per bar charts to review stocks but I would like it to work in percentages, for example each candle is worth 3%, if price moves 3% then print a new candle. Is there a way to do this? I reviewed the documentation and that option is not listed in Range Per Bar documentation. Thank you. |
[2024-05-05 16:03:11] |
There is not a built-in way to do this. You might be able to accomplish this by creating your own custom bars from a Custom Study. Refer to the following: ACSIL Interface - Custom Chart Bars List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
