Date/Time: Wed, 27 Nov 2024 08:52:41 +0000
level 2 analysis
View Count: 1012
[2014-08-17 09:08:58] |
User22099 - Posts: 8 |
i am using sierra with interactive brokers connection and want to know how to do any level 2 analysis for best 5 bids and ask analysis
[2014-08-17 11:11:43] |
Is this for stocks or futures?
[2014-08-20 04:32:25] |
tell me for both
[2014-08-20 08:51:08] |
You can only get market depth data for futures from IB when using Sierra Chart. Refer to the documentation here for the market depth window: https://www.sierrachart.com/index.php?page=doc/doc_FileMenu.html#OpenMarketDepthWindow Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
