Date/Time: Sun, 24 Nov 2024 18:35:20 +0000
Simple Limit order management
View Count: 381
[2024-05-04 11:49:22] |
User741988 - Posts: 14 |
Before investing my time and my money, I would like to check with you the feasibility of my project: I'd like to involve a third party to implement a system for moving limit orders with the click of a mouse on the price ladder pf the trading DOM. Here's what I'd like to implement: Like what you propose for attached target and stop orders that can be moved with the mouse pointer by holding down a button, I'd like to implement this for simple limit orders. The idea would be to click on the DOM price scale so that the limit order closest to the current price moves to the clicked location. Do you think this project is technically feasible for a third party? Thanks for your answer |
[2024-05-05 15:54:08] |
Yes, this is technically feasible.
[2024-05-06 21:09:19] |
and is a feature you think that you will add soon? Thanks in advance for your answer all the best |
[2024-05-06 23:16:03] |
We can not say when we would be able to get to any particular request. Therefore, if this is something you are wanting to have now (or at least soon), then it is best to implement it for yourself. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-07 02:53:47] |
Sierra_Chart Engineering - Posts: 17156 |
Regarding this: I'd like to involve a third party to implement a system for moving limit orders with the click of a mouse on the price ladder pf the trading DOM. Here's what I'd like to implement: Like what you propose for attached target and stop orders that can be moved with the mouse pointer by holding down a button, I'd like to implement this for simple limit orders. The idea would be to click on the DOM price scale so that the limit order closest to the current price moves to the clicked location. Do you think this project is technically feasible for a third party? Thanks for your answer This is possible with ACSIL. ACSIL can receive pointer events: Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events The coordinates, of the price scale are known: ACSIL Interface Members - Variables and Arrays: sc.RightValuesScaleLeftCoordinate ACSIL Interface Members - Variables and Arrays: sc.RightValuesScaleRightCoordinate And ACSIL can access orders and modify them: Automated Trading From an Advanced Custom Study It is possible for ACSIL to know the current price being pointed to: ACSIL Interface Members - Variables and Arrays: sc.ChartTradingOrderPrice Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-07 02:54:47
