Date/Time: Sun, 24 Nov 2024 18:54:08 +0000
[User Discussion] - Numbers Bars not loading
View Count: 176
[2024-05-03 15:43:22] |
User842606 - Posts: 1 |
Hi I'm getting this issue with Sierra chart where Numbers Bars are not loadings and its very laggy, new to the system would appreciate the help :) thank you. Followed the steps in "too much data loaded" page but still nothing. https://www.sierrachart.com/image.php?Image=1714750530743.png |
Screenshot 2024-05-03 160248.png / V - Attached On 2024-05-03 15:33:01 UTC - Size: 64.31 KB - 45 views |
[2024-05-03 16:41:42] |
Refer to the following: Cryptocurrency / Bitcoin Data and Trading Services: Important: Volume at Price Studies with Cryptocurrency Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
