Date/Time: Sun, 24 Nov 2024 18:27:31 +0000
Numbers Bars - Imbalance text and Background Colors same setting?
View Count: 164
[2024-05-03 14:28:32]
User993067 - Posts: 156
I am migrating from Multi Charts- Numbers bars: only using column 1
1. background coloring method is set to: Ask Vol/Bid Vol percentage
2. percent compare thresholds are set to: .25,.50,.75 - this provides a gradient of 4 up and 4 down colors in the background
3. column1 text coloring method is set to: diagonal dominant side Ask Vol Bid Vol percentage.
problem is I am getting too many colored text prints, I want the text coloring to be 150%-200%. it seems the that percent compare threshold in #2 above controls both 1 and 3 above. This doesn't work if you need two different settings for each. If I set the thresholds to 200% I get only two colors in the background, but the text is right. If set it where it is at 25,50,75 the background is right but the text isn't. I have tried every optional setting to replicate my MC charts and have given up. Is there a separate setting? What is solution if I am using percentage based coloring for background and text color, but need separate thresholds because I don't see it.
