Date/Time: Sun, 24 Nov 2024 18:28:57 +0000
[feature] TPO - auto expand last blocks/letters column
View Count: 176
[2024-05-02 19:23:02]
fried4104 - Posts: 66
As I'm using hourly TPOs as well, I'd really appreciate if we could have an option to auto expand the last column of a TPO chart automatically.
For daily/weekly it's easy since you only do it manually once per day, but with multiple hourly charts, it would help a lot to this automatically and not having to do it manually every hour - reset to default, then expand, each chart.
Thank you :)
image{27573565-03DD-4356-9922-523089239741}.png / V - Attached On 2024-05-02 19:22:33 UTC - Size: 355.37 KB - 58 views
