Date/Time: Sun, 24 Nov 2024 19:08:16 +0000
Paint candlesticks according to Close To Close
View Count: 184
[2024-05-02 15:27:15]
funbun - Posts: 90
I saw that possibility on the volume study under "Auto Coloring"
How about applying that for candlesticks?
Currently, if a candle opened higher than previous close but closed lower than current open it's painted Red. Even though current close is higher than previous close
Date Time Of Last Edit: 2024-05-02 15:28:33
[2024-05-02 16:43:38]
Refer to the following setting that may be what you are looking for:
Graphics Settings: Up/Down Coloring for OHLC Bars Based on Previous and Current Close (Global Settings >> Graphics Settings >> Other)
[2024-05-02 16:50:46]
funbun - Posts: 90
Just tried and it only works on OHLC and not candlesticks, but it's ok, not a big deal
thanks
