Date/Time: Sun, 24 Nov 2024 18:33:31 +0000
Sierra Chart - Denali - CQG (No Data - Order Routing only) Log in credentials
View Count: 210
[2024-05-02 14:49:30] |
Apereira - Posts: 2 |
Hi , so i did the form for my account with AMP trading and they approved and completed my form, but are asking me to contact Sierra Charts for a log in and password for the Enabled Data, i dont know what to do?
[2024-05-02 16:36:10] |
They are telling you that you need to get the data from us. Right now, you are on a trial, therefore you can not connect to data or trading services. To be able to connect to your AMP account and get the real-time data from us, you need to be on one of the "Integrated" packages. Refer to the information here: Description of Service Packages and Pricing: Integrated Packages To select a paid package, follow the instructions at the following link: Sierra Chart Purchase and License Information: Instructions Once you have the package setup, then you can connect to CQG by following these instructions: CQG Trading Platform Service: Setup Instructions And then to setup the Denali Exchange Data Feed for the CME Group, follow these instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* If you are wanting data for EUREX, CFE, or U.S. Equities, then follow these instructions: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-02 16:52:50] |
Sierra_Chart Engineering - Posts: 17156 |
Also with AMP if you are just trading CME Group exchanges, you will want to use Teton order routing instead of CQG.
