Date/Time: Sun, 24 Nov 2024 18:21:03 +0000
slow chart
View Count: 162
[2024-05-02 14:09:21] |
User683599 - Posts: 10 |
Hi, my chart is 30secs slower than my tradingview.com charts. Can advise? thanks Date Time Of Last Edit: 2024-05-02 14:20:23
[2024-05-02 16:11:56] |
Is this based on the bar times showing or the actual chart bar prices? If it is based on the bar times, then this is most likely related to your computer's clock being off in relation to the time of the exchange clock. Refer to the following: Global Settings Menu: Set System Date-Time from Server (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
