Date/Time: Wed, 27 Nov 2024 08:25:39 +0000
strange color issue
View Count: 1047
[2014-08-16 11:44:20] |
Herb - Posts: 9 |
Just wondering why some bars have different outline and wick colors in the study 'Ask/Bid Volume Difference Bars'. There are no secondary Colors defined. Also, when the bars are sort of stacked in the 'Cumulative Delta Bars - Volume' study, the Colors are as expected. Thanks for your answer.
[2014-08-17 01:39:54] |
We need to see an image of the chart to understand what you are referring to. Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-17 07:14:10] |
Herb - Posts: 9 |
Here is the image as requested. Some of the wrong colors are highlighted http://www.sierrachart.com/image.php?l=140825940211.png |
[2014-08-17 17:31:51] |
vegasfoster - Posts: 444 |
FYI, on a similar and probably more obscure note, when I try to change the wick color of overlayed price bars, only the first 10 bars of down bars are colored correctly, the rest are colored the up bar color. Maybe I have settings wrong, but I could never figure it. Sorry if I hijacked thread, but it seemed appropriate.
WickProblem.png / V - Attached On 2014-08-17 17:28:21 UTC - Size: 61.97 KB - 352 views |
[2014-08-17 19:38:15] |
In response to post #3, unable this option: Global Settings >> Graphics Settings >> Other >>Color Candlestick High-Low Using Outline Colors Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-17 19:40:19
[2014-08-17 19:40:57] |
In response to #4, we have insufficient information to answer the question. We do not understand the basic problem you are trying to point out to begin with and we do not understand the chart configuration. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
