Date/Time: Sun, 24 Nov 2024 18:51:01 +0000
Reduce The Price Digits in NQ Futures Chart
View Count: 271
[2024-05-02 11:42:14] |
Nick11 - Posts: 25 |
Hello! My question is the following : I can see that in my Sierra Chart platform, when I open and see/analyze the micro E-Mini Nasdaq Futures chart, the price in the rightside of the screen is being divided by 0.25 for each different price level. Is there a way that I can reduce this to like 0.50? or to 1? For example, insted of having the price scale set to 17603, 17603.25, 17603.50, 17603.75, .... etc, can I adjust the settings of the platform so that it becomes 17603, 17603.5, 17604, 17604.5, .... etc or 17603, 17604, 17605, 17606, .... etc? I am also using the numbers bars study which shows me the different bid/ask/delta data for each price level. If I manage to change the price scale from 0.25 to 0.50 for example, will I be able to still receive the equivalent data for the numbers bars different price levels but put into the newly shown price levels? Kind of like a "round and sum up" of the different data into the corresponding newly shown price levels? Or will I manage to "lose" the data of the for example 16703.25, 16703.75, 16704.25, 16704.75, .... etc levels when I change to the 0.50 increments? Thanks in advance for your reply. |
[2024-05-02 11:53:13] |
User585104 - Posts: 142 |
Settings, scale, scale button, increment
[2024-05-02 12:13:38] |
Okay, thank you, I managed to change the price scale on the horizontal place on the rightside of the screen to the 0.50 increments but the numbers bars study inside of the chart didn't change. Is there a way that I can change this as well? |
[2024-05-02 15:52:57] |
Refer to the following setting to aggregate the volume data, which will impact the Numbers Bars: Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-02 16:14:11] |
All things sorted out! Thanks a lot guys. |
