Date/Time: Sun, 24 Nov 2024 18:54:00 +0000
there are many files with large sizes and duplicated content in the TradeActivityLogs dir
View Count: 180
[2024-05-02 09:29:24]
d9e5c763 - Posts: 108
these files follow a format similar to "TradeActivityLog_2024-04-30_UTC.None.data", with some exceeding 100 MB, which seem to be pointless, other than manually deleting them, is there any way to prevent the software from generating them automatically?
(the attachment is a screenshot of TAL window)
imagescreenshot-20240502-172253.jpg / V - Attached On 2024-05-02 09:27:28 UTC - Size: 484.51 KB - 63 views
[2024-05-02 12:07:41]
Sierra_Chart Engineering - Posts: 17159
The logging is all necessary. There is no way to prevent logging. The logging is absolutely important. The question is, why are there so many of those log entries. You have a very large number of connections to the trading server.
[2024-05-02 13:07:52]
got it, mistakenly set the update frequency of POSITION_UPDATE to be the same as MARKET_DATA_*
