Date/Time: Mon, 21 Apr 2025 04:35:54 +0000
Comma Separator in Numbers Bars Calculated Values
View Count: 316
[2024-05-01 23:17:06]
connordw - Posts: 49
Hello, is it possible to change the format of the number values in the Numbers Bars Calculated Values study to have a comma separator (e.g. 14,031)? This would make the numbers much easier to read. Thank you.
image1.PNG / V - Attached On 2024-05-01 23:16:37 UTC - Size: 21.43 KB - 80 views
[2024-05-01 23:28:49]
John - SC Support - Posts: 39362
It is not. Sierra Chart does not have any support for showing commas in numbers.
For an easier to read format, refer to the following:
Numbers Bars: Use Large Volume Number Formatting
[2025-03-06 19:48:36]
ROI+ - Posts: 10
Is Large Volume Number Formatting available for only Number Bars? Can large numbers in the Compact Tool Values Window be truncated?
[2025-03-06 21:42:11]
There are various places where you can use the Large Volume Number Formatting. Most commonly, for a study, you can set the "Value Format" to "Large Integer with Suffix".
Otherwise, it depends on the study and whether the option is available. There are also some settings for this such as the following:
Chart Settings: Use Large Number Display Formatting for Market Depth Window (Chart >> Chart Settings >> Market Depth menu)
We are not sure what you are asking about in terms of the Compact Tool Values Window. What do you want to be truncated? If you are asking if there is an option for the "Large Volume Number Formatting" for the Compact Tool Values Window, the answer is that there is not.
[2025-03-06 22:13:39]
ROI+ - Posts: 10
For a study, how do I set the "Value Format" to "Large Integer with Suffix?"
[2025-03-06 22:29:43]
Refer to the following:
Chart Studies: Settings and Inputs Tab >> Value Format
[2025-03-07 19:02:26]
ROI+ - Posts: 10
Is Large Volume Number Formatting available for Chart Headers?
[2025-03-07 19:55:37]
No.
