Date/Time: Sun, 24 Nov 2024 03:34:23 +0000
Problem with Live Trading Symbols for Soybean Meal and Oil at IB
View Count: 324
[2024-05-01 22:24:51] |
User624595 - Posts: 207 |
Should there be a USD at the end of the symbols? Which format is correct? We have done Update Symbol settings, and also Translate Symbols, we have live orders working in TWS not showing up in Sierrachart though the positions are showing. |
[2024-05-01 23:27:13] |
you need to ask Interactive Brokers what they need for the symbol.
[2024-05-02 12:16:55] |
Sierra_Chart Engineering - Posts: 17154 |
The symbols to use are what are listed in File >> Find Symbol. Do not use any other symbol. The USD is not necessary for those symbols unless there is a security definition error from TWS. If you do not see a particular symbol listed, let us know which one and we will make sure it is there. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-02 12:17:17
[2024-05-02 17:59:29] |
Have selected symbol using Find Symbol, using this currently these symbols show up for live positions: ZL-202407-CBOT ZM-202407-CBOT XINA50-202406-SGX-USD-1 Pulling up the chart using these, working orders are shown on the chart for XINA50, but ZL and ZM show the position in the Trade Window, but not working orders. In the Trade Orders Window shows all the working orders with the -USD at the end of the symbols. Is there any risk that working orders entered or modified through Sierracharts using these will not execute? Date Time Of Last Edit: 2024-05-02 18:00:19
2024-05-02_13h57_48.png / V - Attached On 2024-05-02 17:58:39 UTC - Size: 10.9 KB - 57 views |
[2024-05-02 18:23:17] |
Also if working orders are filled while Sierrachart is not running, do the live fills at IB still get downloaded by Sierrachart? On SOFR3-202412-CME-USD , can see the fill executed in Sierrachart, but not the one executed when Sierrachart was not running. |
[2024-05-07 03:00:57] |
Did you submit orders from Sierra Chart for these symbols but with USD at the end: ZL-202407-CBOT ZM-202407-CBOT In the Trade Orders Window shows all the working orders with the -USD at the end of the symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-08 19:48:07] |
No: , do the live fills at IB still get downloaded by Sierrachart?
[2024-06-25 20:35:58] |
Is it possible to restore this previous functionality to maintain accurate records on the SC side? |
[2024-06-25 21:32:47] |
This is not going to change.
