Date/Time: Sun, 24 Nov 2024 19:06:19 +0000
How to keep all global settings from instance 1 to instance 2?
View Count: 194
[2024-05-01 16:48:05] |
visionanu - Posts: 1 |
on the same computer, how do I transfer over my global settings used in instance 1, over to instance 2? For example, when I load my chartbook into instance 2, the proportions are off, the DOM is huge and unuseable, colors on the level 2 are different etc... I love how my instance 1 is set up and don't remeber every little thing i did to make it that way... I am trading with a prop firm now and require a 2nd instance... If there is a way to fix this, that will be greatly appreicated. I'm also thinking about on instance 2 that doesn't look and perform right, to make that my teton / ironbeam account, and to make my instance 1 my Rithmic account, since that is already set up to my needed looks and functionality... is this a thing I could do to? thank you very much -andrew higgins |
[2024-05-01 18:51:26] |
You need to copy the file named 'Sierra4.config' from the instance that is set as you like to the other instance. Just make sure Sierra Chart is not running in either instance. For a list of files and what they contain, refer to step #5 at the following link: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
