Date/Time: Fri, 22 Nov 2024 18:54:37 +0000
[User Discussion] - chart window resize is annoying
View Count: 2460
[2013-05-07 08:47:22]
yoytu - Posts: 59
each time i go from a chartbook to another i get this annoying resize of each chart window even if window size is set to maximum
http://i.imgur.com/AIAkOVj.jpg
[2013-05-26 21:47:22]
yoytu - Posts: 59
/bump
[2013-05-26 22:08:12]
This is not something we are able to help with. Also we do not fully understand what you are trying to show and in any case, it is not something we can help with. There is a reason why you see what you see, and it has to do with how the Windows operating system is designed. Nothing we can do. This is why there was no answer previously.
[2013-05-26 22:15:24]
yoytu - Posts: 59
when I go from a chartbook to another chartbook even if i have the chart in max the chart get resized like on the image posted http://i.imgur.com/AIAkOVj.jpg
well i did not have this on the old version so i dont know what to do ......
[2013-05-26 22:33:59]
yoytu - Posts: 59
hmmmmm i think i got the problem ... just for the record Control Panel\All Control Panel Items\System > advanced system settings > advanced > performance > visual effect uncheck animate windows when minimizing and maximizing
[2013-05-26 22:50:14]
OK, this is good.
You also need to understand, that when a chart window is hidden and it is maximized, it needs to be restored into its normal state before it is hidden. Otherwise, it creates problems . All of this just has to do with how the Windows operating system is designed. We have little control over these kinds of things.
