Date/Time: Sun, 24 Nov 2024 18:56:25 +0000
oscillator scaling
View Count: 195
[2024-05-01 09:00:31]
SafSaf - Posts: 89
hi team, is there a way to set the scale so, for example; let's base this on using a volume main chart accompanied by a cumulative delta oscillator.... i'd like to adjust the horizontal scale of the main chart manually and i'd like for the oscillator to automatically adjust in line with my main chart adjustment so whatever size the bars are on the main chart are reflected on the oscillator.
is this possible please?
[2024-05-03 10:37:38]
SafSaf - Posts: 89
hello?
[2024-05-03 12:48:13]
Sierra_Chart Engineering - Posts: 17159
We do not understand this.
However, refer to this page:
Chart Scale and Scale Adjusting
Also, refer to:
Working With Charts
You will find all relevant information among these two pages.
[2024-05-03 13:11:36]
SafSaf - Posts: 89
That information is not helpful. I’m simply asking if the horizontal line of my hand tool when hovered over the main chart can be mirrored on the oscillator?
[2024-05-03 13:53:01]
We still do not understand this. Are you referring to the Chart Values tool?
[2024-05-03 15:26:23]
SafSaf - Posts: 89
as attached...
imageUntitled.png / V - Attached On 2024-05-03 15:25:53 UTC - Size: 1.57 MB - 43 views
[2024-05-03 15:29:17]
If you are referring to the Chart Values tool, it has only one horizontal line that is in the region where the pointer is. There is no support at all for what you are looking for.
