Date/Time: Sun, 24 Nov 2024 18:20:57 +0000
Deleting Drawing Tool Configurations
View Count: 324
[2024-05-01 01:00:55] |
User688525 - Posts: 257 |
Hello Sierra Chart, Is it possible to delete drawing tool configurations? Updating and overwriting an existing configuration is possible, but not deleting a configuration so that it goes back to the default settings. For example, if a custom configuration for the Horizontal Line tool is "Black Line", how can this be deleted so that it goes back to "TC7" (assuming "Black Line" was originally "TC7")? Thank you |
[2024-05-01 14:35:35] |
There is not a way to reset configurations back to the default. You would have to actually change that configuration to be what you want.
[2024-05-01 14:47:21] |
Sierra_Chart Engineering - Posts: 17156 |
The only way to do this is to follow these instructions: Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File The configurations are always in existence. There is not a way to change them back to default settings if one or more of them have been changed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-01 14:48:11
[2024-05-01 18:26:15] |
Hello John/Sierra Engineering, Thank you for the links. Can this please be added as a feature request. |
[2024-05-01 19:07:58] |
We take all requests, but we can not say when we would get to any particular change.
