Date/Time: Sun, 24 Nov 2024 20:29:48 +0000
TPO 'Letters/Blocks in Own Column' No Longer Works in latest version.
View Count: 186
[2024-04-30 12:09:59]
User450463 - Posts: 123
When you select "Letters/Blocks in Own Column" by right-clicking to bring up the context menu over a profile, it no longer changes to separate columns. The "Letters/Blocks in Own Columns - All Profiles" menu choice still works, as does the "Reset All Profiles to Default Display Style". I didn't try any of the other choices.
Installed previous version (2629) from Help Menu, and everything works again.
[2024-04-30 12:18:35]
Sierra_Chart Engineering - Posts: 17161
This is resolved in version 2633.
Instructions to update:
Date Time Of Last Edit: 2024-04-30 12:18:54
