Date/Time: Sun, 24 Nov 2024 20:37:17 +0000
Data subscription
View Count: 215
[2024-04-30 11:45:54] |
User401102 - Posts: 1 |
Hello, In order to trade -Indexes such as spy,qqq + related options -Mini sp500, mini nasdaq futures - US Equities (including small cap) + options - premarket data - depth market data Can you suggest the correct data subscriptions? Thank you |
[2024-04-30 15:39:36] |
In order to be able to get real-time data and to connect to a trading account, you need to be on one of the "Integrated" packages. Refer to the information at the following link: Description of Service Packages and Pricing: Integrated Packages When you are ready to setup a paid package, follow the instructions at the following link: Sierra Chart Purchase and License Information: Instructions To get data for U.S. Equities with the Market Depth data, you would need to activate both the "U.S. Equities Consolidated Tape" and the "NASDAQ TotalView" exchanges and then enter your symbol with an _MBO suffix (such as IBM_MBO). This will give you the price and volume data from the U.S. Equities Consolidated Tape with the Market Depth data from the NASDAQ TotalView. Refer to the information for these two items here: Denali Exchange Data Feed: US Equities Consolidated Tape Data Feed Notes Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes To get data for the CME Group, you first need to understand that you need a live, funded, futures trading account in order to qualify for the non-professional exchange fees. And you need to be able to connect your Sierra Chart to that trading account at least once a month for verification. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges If you do not have an account that qualifies for the above, then we recommend the solution outlined at the following link: Easy Solution to CME Funded Trading Account Requirement Once you have this worked out, then you can setup the data for the CME Group by following these instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
