Date/Time: Sun, 24 Nov 2024 18:58:30 +0000
Account not active
View Count: 242
[2024-04-30 10:53:45] |
User497465 - Posts: 35 |
Hey there, i've got a prop account by 4proptrader. in gerneral all is working very well. Today i updated my laptop and computer to the current version of sierra and now i can trade with my laptop, but not with the computer. i always get the information in the log that my account shouldn't be active. but my settings are right (global settings -> data/trade service settings). why i can't trade on my computer? |
[2024-04-30 11:25:05] |
Sierra_Chart Engineering - Posts: 17159 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed: Select "File >> Disconnect" Select "File >> Connect to Data Feed" After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-30 13:21:48] |
2024-04-30 15:16:28.831 | Software version: 2633 64-bit 2024-04-30 15:16:28.831 | Safe Mode enabled 2024-04-30 15:16:28.831 | Primary Thread ID: 12148 2024-04-30 15:16:28.831 | Usage end date: 2024-08-09 2024-04-30 15:16:28.831 | Enabled for: Advanced Features 2. 2024-04-30 15:16:28.831 | Enabled for: Sierra Chart Historical Data Service. 2024-04-30 15:16:28.831 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-04-30 15:16:28.831 | Enabled for: Delayed Denali Exchange Data Feed. 2024-04-30 15:16:28.831 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-04-30 15:16:28.831 | Current selected Data/Trading service: Rithmic Direct - DTC 2024-04-30 15:16:28.831 | Custom symbol settings values: enabled 2024-04-30 15:16:28.831 | Chart Update Interval: 10 2024-04-30 15:16:28.831 | Intraday Data Storage Time Unit: 0 2024-04-30 15:16:28.831 | Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) 2024-04-30 15:16:28.831 | 2024-04-30 13:16:28 Local computer time in UTC 2024-04-30 15:16:28.831 | 2024-04-30 15:16:28 Local computer time in SC Time Zone 2024-04-30 15:16:28.831 | 2024-04-30 13:09:12 Server time in UTC 2024-04-30 15:16:28.831 | Local computer UTC time and Server UTC time difference: 0 seconds. 2024-04-30 15:16:28.831 | Program path: C:\Sierra Chart\ 2024-04-30 15:16:28.831 | Data Files path: C:\Sierra Chart\Data\ 2024-04-30 15:16:28.831 | OS Version Number: 10.0 2024-04-30 15:16:28.831 | Locale Setting: C 2024-04-30 15:16:28.831 | DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll 2024-04-30 15:16:28.831 | Allowed protected custom studies: 2024-04-30 15:16:28.831 | Crash reporter started: true 2024-04-30 15:16:28.831 | 2024-04-30 15:17:16.083 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-30 15:17:16.083 | DTC Client socket (2) | CloseSocket call. 2024-04-30 15:17:16.083 | DTC Client socket (2) | Max send buffers used during socket life: 3 2024-04-30 15:17:16.083 | DTC Client socket (2) | Max send buffer size during socket life: 1287 2024-04-30 15:17:16.083 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-30 15:17:16.083 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-04-30 15:17:16.090 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-04-30 15:17:16.090 | DTC Client socket (1) | CloseSocket call. 2024-04-30 15:17:16.090 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-04-30 15:17:16.091 | Rithmic Direct - DTC | Disconnected. 2024-04-30 15:17:16.098 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-04-30 15:17:16.098 | DTC Client socket (2) | Closed. 2024-04-30 15:17:16.106 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-04-30 15:17:16.106 | DTC Client socket (1) | Closed. 2024-04-30 15:17:16.126 | Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 6. 2024-04-30 15:17:16.126 | Current selected Data/Trading service: SC Data - All Services 2024-04-30 15:17:17.271 | Symbol settings MD5 received. Request ID: 6. 2024-04-30 15:17:17.271 | Requested symbol settings for service code scdataallservices. Request ID: 7. 2024-04-30 15:17:17.561 | SC Data - All Services | Disconnected. | Number times message added: 1 2024-04-30 15:17:17.566 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-04-30 15:17:17.570 | ESM24-CME 15 Min #8 | Reloading chart. 2024-04-30 15:17:17.575 | NQM24-CME 15 Min #9 | Reloading chart. 2024-04-30 15:17:17.580 | ESM24-CME 15 Min #6 | Reloading chart. 2024-04-30 15:17:17.583 | GCM24-COMEX 15 Min #12 | Reloading chart. 2024-04-30 15:17:17.587 | 6EM24-CME 15 Min #10 | Reloading chart. 2024-04-30 15:17:17.593 | YMM24-CBOT 15 Min #11 | Reloading chart. 2024-04-30 15:17:17.598 | YMM24-CBOT 1 Min #6 | Reloading chart. 2024-04-30 15:17:17.603 | CLM24-NYMEX 15 Min #13 | Reloading chart. 2024-04-30 15:17:17.607 | YMM24-CBOT 15 Min #7 | Reloading chart. 2024-04-30 15:17:17.610 | 6EM24-CME 15 Min #10 | Reloading chart. 2024-04-30 15:17:17.612 | NQM24-CME 15 Min #9 | Reloading chart. 2024-04-30 15:17:17.615 | GCM24-COMEX 15 Min #8 | Reloading chart. 2024-04-30 15:17:17.621 | CLM24-NYMEX #2 | Reloading chart. 2024-04-30 15:17:17.623 | CLM24-NYMEX [C] 15 Min #7 | Reloading chart. 2024-04-30 15:17:17.648 | Added historical Intraday data request for CLM24-NYMEX to the queue. 2024-04-30 15:17:17.648 | Triggering next historical data download in queue. 2024-04-30 15:17:17.648 | CLM24-NYMEX [C] 15 Min #7 | Waiting for historical downloads to complete with the IDs: 33, 2024-04-30 15:17:17.669 | YMM24-CBOT 1 Min #6 | StartDateTimeForLoadingOrderFills: 2024-04-16 15:01:24 2024-04-30 15:17:17.688 | YMM24-CBOT 1 Min #6 | Chart data loading complete. 2024-04-30 15:17:17.688 | Mapping CLM24-NYMEX to CLM24. Service code: nymex 2024-04-30 15:17:17.688 | HD Request # 29 | Downloading Intraday chart data for CLM24-NYMEX to the file CLM24-NYMEX.scid. Service: nymex 2024-04-30 15:17:17.689 | HD Request # 29 | Download start date-time: 2024-04-23 01:52:31.000000. File last date-time: 2024-04-23 01:52:31.838003 2024-04-30 15:17:17.689 | HD Request # 29 | Using server: ds26.sierracharts.com port 10149 2024-04-30 15:17:17.689 | Socket (3) | Creating socket. 2024-04-30 15:17:17.689 | Socket (3) | New receive buffer size: 0 2024-04-30 15:17:17.689 | Socket (3) | Connecting to IP: 38.103.112.197. 2024-04-30 15:17:17.708 | CLM24-NYMEX #2 | StartDateTimeForLoadingOrderFills: 2024-04-09 01:52:31 2024-04-30 15:17:17.710 | CLM24-NYMEX #2 | Chart data loading complete. 2024-04-30 15:17:17.735 | CLM24-NYMEX [C] 15 Min #5 | Reloading chart. 2024-04-30 15:17:17.736 | CLM24-NYMEX [C] 15 Min #5 | Waiting for historical downloads to complete with the IDs: 33, 2024-04-30 15:17:17.737 | CLM24-NYMEX #4 | Reloading chart. 2024-04-30 15:17:17.742 | CLM24-NYMEX #3 | Reloading chart. 2024-04-30 15:17:17.755 | CLM24-NYMEX 1 Min #1 | Reloading chart. 2024-04-30 15:17:17.758 | CLM24-NYMEX 1 Min #12 | Reloading chart. 2024-04-30 15:17:17.762 | NQM24-CME 1 Min #2 | Reloading chart. 2024-04-30 15:17:17.767 | CLM24-NYMEX 1 Min #12 | StartDateTimeForLoadingOrderFills: 2024-04-09 01:52:31 2024-04-30 15:17:17.767 | CLM24-NYMEX 1 Min #12 | Chart data loading complete. 2024-04-30 15:17:17.772 | CLM24-NYMEX 15 Min #11 | Reloading chart. 2024-04-30 15:17:17.780 | NQM24-CME #1 | Reloading chart. 2024-04-30 15:17:17.790 | ESM24-CME 1 Min #4 | Reloading chart. 2024-04-30 15:17:17.800 | CLM24-NYMEX 1 Min #1 | StartDateTimeForLoadingOrderFills: 2024-04-09 01:52:31 2024-04-30 15:17:17.801 | CLM24-NYMEX 1 Min #1 | Chart data loading complete. 2024-04-30 15:17:17.803 | YMM24-CBOT #5 | Reloading chart. 2024-04-30 15:17:17.814 | ESM24-CME #3 | Reloading chart. 2024-04-30 15:17:17.820 | Mapping ESM24-CME to ESM24. Service code: cme 2024-04-30 15:17:17.820 | Added historical Intraday data request for ESM24-CME to the queue. 2024-04-30 15:17:17.820 | Intraday data recording state for symbol ESM24-CME is set to download 'Pending'. 2024-04-30 15:17:17.820 | Triggering next historical data download in queue. 2024-04-30 15:17:17.833 | Mapping GCM24-COMEX to GCM24. Service code: comex 2024-04-30 15:17:17.833 | Added historical Intraday data request for GCM24-COMEX to the queue. 2024-04-30 15:17:17.833 | Intraday data recording state for symbol GCM24-COMEX is set to download 'Pending'. 2024-04-30 15:17:17.833 | Triggering next historical data download in queue. 2024-04-30 15:17:17.835 | CLM24-NYMEX #3 | StartDateTimeForLoadingOrderFills: 2024-04-09 01:52:31 2024-04-30 15:17:17.836 | CLM24-NYMEX #3 | Chart data loading complete. 2024-04-30 15:17:17.841 | Mapping NQM24-CME to NQM24. Service code: cme 2024-04-30 15:17:17.841 | Added historical Intraday data request for NQM24-CME to the queue. 2024-04-30 15:17:17.841 | Intraday data recording state for symbol NQM24-CME is set to download 'Pending'. 2024-04-30 15:17:17.841 | Triggering next historical data download in queue. 2024-04-30 15:17:17.852 | Mapping YMM24-CBOT to YMM24. Service code: cbot 2024-04-30 15:17:17.852 | Added historical Intraday data request for YMM24-CBOT to the queue. 2024-04-30 15:17:17.852 | Intraday data recording state for symbol YMM24-CBOT is set to download 'Pending'. 2024-04-30 15:17:17.852 | Triggering next historical data download in queue. 2024-04-30 15:17:17.875 | CLM24-NYMEX[M] 15 Min #13 | StartDateTimeForLoadingOrderFills: 2024-02-26 00:00:00 2024-04-30 15:17:17.885 | CLM24-NYMEX[M] 15 Min #13 | Chart data loading complete. 2024-04-30 15:17:17.886 | YMM24-CBOT #5 | StartDateTimeForLoadingOrderFills: 2024-04-16 15:01:24 2024-04-30 15:17:17.895 | YMM24-CBOT #5 | Chart data loading complete. 2024-04-30 15:17:17.916 | Mapping 6EM24-CME to 6EM24. Service code: cme 2024-04-30 15:17:17.916 | Added historical Intraday data request for 6EM24-CME to the queue. 2024-04-30 15:17:17.916 | Intraday data recording state for symbol 6EM24-CME is set to download 'Pending'. 2024-04-30 15:17:17.916 | Triggering next historical data download in queue. 2024-04-30 15:17:17.949 | NQM24-CME 1 Min #2 | StartDateTimeForLoadingOrderFills: 2024-04-09 04:02:56 2024-04-30 15:17:17.950 | HD Request # 29 | Setting DTC encoding to Binary VLS 2024-04-30 15:17:17.950 | HD Request # 29 | Sending historical data logon request message. 2024-04-30 15:17:17.971 | NQM24-CME 1 Min #2 | Chart data loading complete. 2024-04-30 15:17:17.995 | 6EM24-CME[M] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2024-02-26 01:15:00 2024-04-30 15:17:18.003 | 6EM24-CME[M] 15 Min #10 | Chart data loading complete. 2024-04-30 15:17:18.005 | 6EM24-CME[M] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2024-02-26 01:15:00 2024-04-30 15:17:18.007 | 6EM24-CME[M] 15 Min #10 | Chart data loading complete. 2024-04-30 15:17:18.031 | NQM24-CME #1 | StartDateTimeForLoadingOrderFills: 2024-04-09 04:02:56 2024-04-30 15:17:18.038 | NQM24-CME #1 | Chart data loading complete. 2024-04-30 15:17:18.074 | CLM24-NYMEX 15 Min #11 | StartDateTimeForLoadingOrderFills: 2024-02-26 00:00:00 2024-04-30 15:17:18.077 | CLM24-NYMEX 15 Min #11 | Chart data loading complete. 2024-04-30 15:17:18.086 | ESM24-CME 1 Min #4 | StartDateTimeForLoadingOrderFills: 2024-04-09 01:53:31 2024-04-30 15:17:18.096 | ESM24-CME 1 Min #4 | Chart data loading complete. 2024-04-30 15:17:18.108 | ESM24-CME #3 | StartDateTimeForLoadingOrderFills: 2024-04-09 01:53:31 2024-04-30 15:17:18.115 | ESM24-CME #3 | Chart data loading complete. 2024-04-30 15:17:18.267 | YMM24-CBOT[M] 15 Min #11 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:30:00 2024-04-30 15:17:18.275 | YMM24-CBOT[M] 15 Min #11 | Chart data loading complete. 2024-04-30 15:17:18.285 | GCM24-COMEX[M] 15 Min #12 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:00:00 2024-04-30 15:17:18.293 | GCM24-COMEX[M] 15 Min #12 | Chart data loading complete. 2024-04-30 15:17:18.303 | HD Request # 29 | Requesting Intraday data. Start date-time: 2024-04-23 01:52:31. Record interval: 0. Symbol: CLM24 2024-04-30 15:17:18.315 | YMM24-CBOT[M] 15 Min #7 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:30:00 2024-04-30 15:17:18.318 | YMM24-CBOT[M] 15 Min #7 | Chart data loading complete. 2024-04-30 15:17:18.349 | CLM24-NYMEX[M] #4 | Chart data loading complete. 2024-04-30 15:17:18.358 | GCM24-COMEX[M] 15 Min #8 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:00:00 2024-04-30 15:17:18.361 | GCM24-COMEX[M] 15 Min #8 | Chart data loading complete. 2024-04-30 15:17:18.414 | HD Request # 29 | Decompressing data. 2024-04-30 15:17:18.563 | HD Request # 29 | Receiving Intraday data for CLM24-NYMEX starting at 2024-04-23 01:52:31.838000 2024-04-30 15:17:18.909 | Symbol settings received. Request ID: 7. 2024-04-30 15:17:18.916 | HD Request # 29 | Timestamp of first Intraday data file record written: 2024-04-23 01:53:57.073000. 2024-04-30 15:17:19.563 | 2024-04-30 15:17:19.563 | SC Data - All Services | Connected to server complete. 2024-04-30 15:17:19.563 | No download requests in the queue to start downloads for. 2024-04-30 15:17:19.563 | Triggering next historical data download in queue. 2024-04-30 15:17:19.563 | No download requests in the queue to start downloads for. | Number times message added: 1 2024-04-30 15:17:19.563 | Subscribing to symbol for symbol alert. ESH22-CME 2024-04-30 15:17:19.564 | Mapping ESH22-CME to ESH22. Service code: cme 2024-04-30 15:17:19.564 | Using symbol data fast lookup vector 2024-04-30 15:17:19.564 | Delayed Data Feed | Starting real-time market data updates for: ESH22-CME (ESH22). ID: 1 Service code: cme 2024-04-30 15:17:19.564 | Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 2024-04-30 15:17:19.564 | Delayed Data Feed | Requesting security definition data for: ESH22-CME (ESH22). ID: 1 2024-04-30 15:17:19.564 | Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. 2024-04-30 15:17:19.564 | DTC Client socket (1) | Creating socket. 2024-04-30 15:17:19.564 | DTC Client socket (1) | New receive buffer size: 0 2024-04-30 15:17:19.564 | DTC Client socket (1) | Connecting to IP: 38.103.112.187. 2024-04-30 15:17:19.574 | Mapping CLM24-NYMEX to CLM24. Service code: nymex 2024-04-30 15:17:19.575 | Delayed Data Feed | Starting real-time market data updates for: CLM24-NYMEX (CLM24). ID: 2 Service code: nymex 2024-04-30 15:17:19.575 | Delayed Data Feed | Requesting security definition data for: CLM24-NYMEX (CLM24). ID: 2 2024-04-30 15:17:19.597 | Mapping NQM24-CME to NQM24. Service code: cme 2024-04-30 15:17:19.597 | Delayed Data Feed | Starting real-time market data updates for: NQM24-CME (NQM24). ID: 3 Service code: cme 2024-04-30 15:17:19.597 | Delayed Data Feed | Requesting security definition data for: NQM24-CME (NQM24). ID: 3 2024-04-30 15:17:19.614 | Mapping ESM24-CME to ESM24. Service code: cme 2024-04-30 15:17:19.614 | Delayed Data Feed | Starting real-time market data updates for: ESM24-CME (ESM24). ID: 4 Service code: cme 2024-04-30 15:17:19.614 | Delayed Data Feed | Requesting security definition data for: ESM24-CME (ESM24). ID: 4 2024-04-30 15:17:19.629 | Mapping YMM24-CBOT to YMM24. Service code: cbot 2024-04-30 15:17:19.629 | Delayed Data Feed | Starting real-time market data updates for: YMM24-CBOT (YMM24). ID: 5 Service code: cbot 2024-04-30 15:17:19.629 | Delayed Data Feed | Requesting security definition data for: YMM24-CBOT (YMM24). ID: 5 2024-04-30 15:17:19.638 | Mapping GCM24-COMEX to GCM24. Service code: comex 2024-04-30 15:17:19.638 | Delayed Data Feed | Starting real-time market data updates for: GCM24-COMEX (GCM24). ID: 6 Service code: comex 2024-04-30 15:17:19.638 | Delayed Data Feed | Requesting security definition data for: GCM24-COMEX (GCM24). ID: 6 2024-04-30 15:17:19.673 | Mapping 6EM24-CME to 6EM24. Service code: cme 2024-04-30 15:17:19.673 | Delayed Data Feed | Starting real-time market data updates for: 6EM24-CME (6EM24). ID: 7 Service code: cme 2024-04-30 15:17:19.673 | Delayed Data Feed | Requesting security definition data for: 6EM24-CME (6EM24). ID: 7 2024-04-30 15:17:19.703 | Delayed Data Feed | Network connection to server complete. 2024-04-30 15:17:19.703 | Delayed Data Feed | Starting socket receive thread. 2024-04-30 15:17:19.703 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-04-30 15:17:19.761 | NQM24-CME[M] 15 Min #9 | StartDateTimeForLoadingOrderFills: 2024-02-26 00:00:00 2024-04-30 15:17:19.771 | NQM24-CME[M] 15 Min #9 | Chart data loading complete. 2024-04-30 15:17:19.782 | NQM24-CME[M] 15 Min #9 | StartDateTimeForLoadingOrderFills: 2024-02-26 00:00:00 2024-04-30 15:17:19.787 | NQM24-CME[M] 15 Min #9 | Chart data loading complete. 2024-04-30 15:17:19.841 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2024-04-30 15:17:19.841 | Delayed Data Feed | Sending logon request message. 2024-04-30 15:17:20.306 | Delayed Data Feed | Received logon response. 2024-04-30 15:17:20.306 | Delayed Data Feed | Server Name: SC Realtime Server. 2024-04-30 15:17:20.306 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2024-04-30 15:17:20.306 | Delayed Data Feed | Successfully connected. 2024-04-30 15:17:20.306 | Delayed Data Feed | Trading is not supported. 2024-04-30 15:17:20.306 | Delayed Data Feed | MarketDepthIsSupported: 1 2024-04-30 15:17:20.306 | Delayed Data Feed | Restarting real-time data updates for symbol: 6EM24-CME -> 6EM24 2024-04-30 15:17:20.306 | Delayed Data Feed | Restarting real-time data updates for symbol: CLM24-NYMEX -> CLM24 2024-04-30 15:17:20.306 | Delayed Data Feed | Restarting real-time data updates for symbol: ESH22-CME -> ESH22 2024-04-30 15:17:20.306 | Delayed Data Feed | Restarting real-time data updates for symbol: ESM24-CME -> ESM24 2024-04-30 15:17:20.306 | Delayed Data Feed | Restarting real-time data updates for symbol: GCM24-COMEX -> GCM24 2024-04-30 15:17:20.306 | Delayed Data Feed | Restarting real-time data updates for symbol: NQM24-CME -> NQM24 2024-04-30 15:17:20.306 | Delayed Data Feed | Restarting real-time data updates for symbol: YMM24-CBOT -> YMM24 2024-04-30 15:17:20.526 | Delayed Data Feed | Received security definition for symbol 6EM24-CME 2024-04-30 15:17:20.526 | Delayed Data Feed | Received security definition for symbol CLM24-NYMEX 2024-04-30 15:17:20.526 | Delayed Data Feed | Real-time data for symbol ESH22-CME is currently unavailable. 2024-04-30 15:17:20.526 | Delayed Data Feed | Received security definition for symbol ESH22-CME 2024-04-30 15:17:20.526 | Delayed Data Feed | Received security definition for symbol ESM24-CME 2024-04-30 15:17:20.526 | Delayed Data Feed | Received security definition for symbol GCM24-COMEX 2024-04-30 15:17:20.526 | Delayed Data Feed | Received security definition for symbol NQM24-CME 2024-04-30 15:17:20.526 | Delayed Data Feed | Received security definition for symbol YMM24-CBOT 2024-04-30 15:17:21.116 | ESM24-CME[M] 15 Min #8 | StartDateTimeForLoadingOrderFills: 2024-02-26 00:00:00 2024-04-30 15:17:21.123 | ESM24-CME[M] 15 Min #8 | Chart data loading complete. 2024-04-30 15:17:21.131 | ESM24-CME[M] 15 Min #6 | StartDateTimeForLoadingOrderFills: 2024-02-26 00:00:00 2024-04-30 15:17:21.134 | ESM24-CME[M] 15 Min #6 | Chart data loading complete. 2024-04-30 15:17:21.508 | Socket (3) | CloseSocket call. 2024-04-30 15:17:21.508 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-04-30 15:17:21.510 | Historical data download thread signaled to stop. 2024-04-30 15:17:21.511 | HD Request # 29 | Received 861415 Intraday data records from 2024-04-23 01:52:31.838000 to 2024-04-30 15:07:20.372000 (7.6 days. Delay: 10.0 minutes) and wrote 861411 records for CLM24-NYMEX 2024-04-30 15:17:21.516 | HD Request # 29 | Add time&sales data | Remembered last file record date-time: 2024-04-30 13:07:20.372000 2024-04-30 15:17:21.516 | HD Request # 29 | Completion time: 4s. 2024-04-30 15:17:21.516 | HD Request # 29 | Intraday data download complete for CLM24-NYMEX. Unique request ID: 33 2024-04-30 15:17:21.516 | Removing historical data download ID 33. 2024-04-30 15:17:21.516 | Real-time Intraday chart data file updates started for CLM24-NYMEX 2024-04-30 15:17:21.516 | Intraday chart data file opened for CLM24-NYMEX 2024-04-30 15:17:21.516 | HD Request # 29 | Enabling Intraday chart updating for symbol. 2024-04-30 15:17:21.516 | 2024-04-30 15:17:21.516 | Triggering next historical data download in queue. 2024-04-30 15:17:21.516 | Initiating new historical data download for CLM24-NYMEX to get the latest data since the download was started while not connected to primary service. 2024-04-30 15:17:21.516 | Added historical Intraday data request for CLM24-NYMEX to the queue. 2024-04-30 15:17:21.516 | Intraday data recording state for symbol CLM24-NYMEX is set to download 'Pending'. 2024-04-30 15:17:21.516 | Delaying start of download for CLM24-NYMEX. 2024-04-30 15:17:21.607 | CLM24-NYMEX [C] 15 Min #7 | Download is complete for all contract months in chart. Proceeding with data load. 2024-04-30 15:17:21.608 | CLM24-NYMEX [C] 15 Min #7 | Reloading chart. 2024-04-30 15:17:21.629 | Socket (3) | Socket gracefully closed by remote side. 2024-04-30 15:17:21.629 | Socket (3) | Closed. 2024-04-30 15:17:21.655 | CLM24-NYMEX [C] 15 Min #5 | Download is complete for all contract months in chart. Proceeding with data load. 2024-04-30 15:17:21.655 | CLM24-NYMEX [C] 15 Min #5 | Reloading chart. 2024-04-30 15:17:21.733 | CLM24-NYMEX [C] 15 Min #7 | Reloading chart. 2024-04-30 15:17:21.740 | CLM24-NYMEX [C] 15 Min #7 | Waiting for historical downloads to complete with the IDs: 39, 2024-04-30 15:17:21.756 | CLM24-NYMEX [C] 15 Min #5 | Reloading chart. 2024-04-30 15:17:21.761 | CLM24-NYMEX [C] 15 Min #5 | Waiting for historical downloads to complete with the IDs: 39, 2024-04-30 15:17:22.464 | CLM24-NYMEX [C] 15 Min #5 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:00:00 2024-04-30 15:17:22.464 | CLM24-NYMEX [C] 15 Min #5 | Chart data loading complete. 2024-04-30 15:17:22.480 | CLM24-NYMEX [C] 15 Min #7 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:00:00 2024-04-30 15:17:22.518 | CLM24-NYMEX [C] 15 Min #7 | Chart data loading complete. 2024-04-30 15:17:24.576 | Requesting market depth updates for: CLM24-NYMEX if supported. NumLevels=100 2024-04-30 15:17:24.576 | Requesting market depth updates for: ESM24-CME if supported. NumLevels=100 2024-04-30 15:17:24.576 | Requesting market depth updates for: NQM24-CME if supported. NumLevels=100 2024-04-30 15:17:24.576 | Requesting market depth updates for: YMM24-CBOT if supported. NumLevels=100 2024-04-30 15:17:24.723 | Delayed Data Feed | Clearing market depth for CLM24-NYMEX 2024-04-30 15:17:24.723 | Delayed Data Feed | Clearing market depth for ESM24-CME 2024-04-30 15:17:24.723 | Delayed Data Feed | Clearing market depth for NQM24-CME 2024-04-30 15:17:24.723 | Delayed Data Feed | Clearing market depth for YMM24-CBOT 2024-04-30 15:17:25.214 | HD Request # 30 | Downloading Intraday chart data for CLM24-NYMEX to the file CLM24-NYMEX.scid. Service: nymex 2024-04-30 15:17:25.214 | HD Request # 30 | Download start date-time: 2024-04-30 15:07:20.000000. File last date-time: 2024-04-30 15:07:20.372000 2024-04-30 15:17:25.214 | HD Request # 30 | Using server: ds28.sierracharts.com port 10150 2024-04-30 15:17:25.214 | Socket (2) | Creating socket. 2024-04-30 15:17:25.215 | Socket (2) | New receive buffer size: 0 2024-04-30 15:17:25.215 | Socket (2) | Connecting to IP: 38.103.112.187. 2024-04-30 15:17:25.453 | HD Request # 30 | Setting DTC encoding to Binary VLS 2024-04-30 15:17:25.453 | HD Request # 30 | Sending historical data logon request message. 2024-04-30 15:17:25.814 | HD Request # 30 | Requesting Intraday data. Start date-time: 2024-04-30 15:07:20. Record interval: 0. Symbol: CLM24 2024-04-30 15:17:25.928 | HD Request # 30 | Decompressing data. 2024-04-30 15:17:26.037 | HD Request # 30 | Receiving Intraday data for CLM24-NYMEX starting at 2024-04-30 15:07:20.240000 2024-04-30 15:17:26.037 | Socket (2) | CloseSocket call. 2024-04-30 15:17:26.037 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-04-30 15:17:26.042 | Historical data download thread signaled to stop. 2024-04-30 15:17:26.043 | HD Request # 30 | Timestamp of first Intraday data file record written: 2024-04-30 15:07:22.040000. 2024-04-30 15:17:26.043 | HD Request # 30 | Received 26 Intraday data records from 2024-04-30 15:07:20.240000 to 2024-04-30 15:07:25.490000 (5.3 seconds. Delay: 10.0 minutes) and wrote 24 records for CLM24-NYMEX 2024-04-30 15:17:26.048 | HD Request # 30 | Add time&sales data | Remembered last file record date-time: 2024-04-30 13:07:25.490000 2024-04-30 15:17:26.048 | HD Request # 30 | Completion time: 1s. 2024-04-30 15:17:26.048 | HD Request # 30 | Intraday data download complete for CLM24-NYMEX. Unique request ID: 39 2024-04-30 15:17:26.048 | Removing historical data download ID 39. 2024-04-30 15:17:26.048 | Real-time Intraday chart data file updates started for CLM24-NYMEX 2024-04-30 15:17:26.048 | Intraday chart data file opened for CLM24-NYMEX 2024-04-30 15:17:26.048 | HD Request # 30 | Enabling Intraday chart updating for symbol. 2024-04-30 15:17:26.048 | 2024-04-30 15:17:26.048 | Triggering next historical data download in queue. 2024-04-30 15:17:26.048 | HD Request # 31 | Downloading Intraday chart data for ESM24-CME to the file ESM24-CME.scid. Service: cme 2024-04-30 15:17:26.048 | HD Request # 31 | Download start date-time: 2024-04-23 01:53:31.000000. File last date-time: 2024-04-23 01:53:31.167003 2024-04-30 15:17:26.048 | HD Request # 31 | Using server: ds13.sierracharts.com port 10149 2024-04-30 15:17:26.048 | Socket (3) | Creating socket. 2024-04-30 15:17:26.048 | Socket (3) | New receive buffer size: 0 2024-04-30 15:17:26.048 | Socket (3) | Connecting to IP: 38.142.170.155. 2024-04-30 15:17:26.127 | CLM24-NYMEX [C] 15 Min #7 | Download is complete for all contract months in chart. Proceeding with data load. 2024-04-30 15:17:26.127 | CLM24-NYMEX [C] 15 Min #7 | Reloading chart. 2024-04-30 15:17:26.144 | CLM24-NYMEX [C] 15 Min #5 | Download is complete for all contract months in chart. Proceeding with data load. 2024-04-30 15:17:26.144 | CLM24-NYMEX [C] 15 Min #5 | Reloading chart. 2024-04-30 15:17:26.154 | Socket (2) | Socket gracefully closed by remote side. 2024-04-30 15:17:26.154 | Socket (2) | Closed. 2024-04-30 15:17:26.205 | CLM24-NYMEX [C] 15 Min #7 | Reloading chart. 2024-04-30 15:17:26.234 | Opened cached Intraday file: C:\Sierra Chart\Data\CLM24-NYMEX.scid. Thread ID: 20216 2024-04-30 15:17:26.236 | CLM24-NYMEX [C] 15 Min #5 | Reloading chart. 2024-04-30 15:17:26.418 | HD Request # 31 | Setting DTC encoding to Binary VLS 2024-04-30 15:17:26.418 | HD Request # 31 | Sending historical data logon request message. 2024-04-30 15:17:26.646 | HD Request # 31 | Requesting Intraday data. Start date-time: 2024-04-23 01:53:31. Record interval: 0. Symbol: ESM24 2024-04-30 15:17:26.817 | HD Request # 31 | Decompressing data. 2024-04-30 15:17:26.910 | CLM24-NYMEX [C][M] 15 Min #7 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:00:00 2024-04-30 15:17:26.948 | CLM24-NYMEX [C][M] 15 Min #7 | Chart data loading complete. 2024-04-30 15:17:26.988 | CLM24-NYMEX [C][M] 15 Min #5 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:00:00 2024-04-30 15:17:26.988 | CLM24-NYMEX [C][M] 15 Min #5 | Chart data loading complete. 2024-04-30 15:17:27.177 | HD Request # 31 | Receiving Intraday data for ESM24-CME starting at 2024-04-23 01:53:31.146000 2024-04-30 15:17:27.690 | HD Request # 31 | Timestamp of first Intraday data file record written: 2024-04-23 01:53:43.636000. 2024-04-30 15:17:53.305 | Socket (3) | CloseSocket call. 2024-04-30 15:17:53.305 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-04-30 15:17:53.316 | Historical data download thread signaled to stop. 2024-04-30 15:17:53.326 | HD Request # 31 | Received 5060575 Intraday data records from 2024-04-23 01:53:31.146000 to 2024-04-30 15:07:52.429001 (7.6 days. Delay: 10.0 minutes) and wrote 5060569 records for ESM24-CME 2024-04-30 15:17:53.331 | HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2024-04-30 13:07:52.429001 2024-04-30 15:17:53.331 | HD Request # 31 | Completion time: 27s. 2024-04-30 15:17:53.331 | HD Request # 31 | Intraday data download complete for ESM24-CME. Unique request ID: 34 2024-04-30 15:17:53.331 | Removing historical data download ID 34. 2024-04-30 15:17:53.331 | Real-time Intraday chart data file updates started for ESM24-CME 2024-04-30 15:17:53.331 | Intraday chart data file opened for ESM24-CME 2024-04-30 15:17:53.331 | HD Request # 31 | Enabling Intraday chart updating for symbol. 2024-04-30 15:17:53.331 | 2024-04-30 15:17:53.331 | Triggering next historical data download in queue. 2024-04-30 15:17:53.331 | HD Request # 32 | Downloading Intraday chart data for GCM24-COMEX to the file GCM24-COMEX.scid. Service: comex 2024-04-30 15:17:53.331 | HD Request # 32 | Download start date-time: 2024-04-30 15:01:24.000000. File last date-time: 2024-04-30 15:01:24.881000 2024-04-30 15:17:53.332 | HD Request # 32 | Using server: ds23.sierracharts.com port 10150 2024-04-30 15:17:53.332 | Socket (2) | Creating socket. 2024-04-30 15:17:53.332 | Socket (2) | New receive buffer size: 0 2024-04-30 15:17:53.332 | Socket (2) | Connecting to IP: 38.103.112.183. 2024-04-30 15:17:53.486 | Socket (3) | Socket gracefully closed by remote side. 2024-04-30 15:17:53.486 | Socket (3) | Closed. 2024-04-30 15:17:53.571 | HD Request # 32 | Setting DTC encoding to Binary VLS 2024-04-30 15:17:53.571 | HD Request # 32 | Sending historical data logon request message. 2024-04-30 15:17:53.911 | Opened cached Intraday file: C:\Sierra Chart\Data\ESM24-CME.scid. Thread ID: 20216 2024-04-30 15:17:53.939 | HD Request # 32 | Requesting Intraday data. Start date-time: 2024-04-30 15:01:24. Record interval: 0. Symbol: GCM24 2024-04-30 15:17:54.053 | HD Request # 32 | Decompressing data. 2024-04-30 15:17:54.287 | HD Request # 32 | Receiving Intraday data for GCM24-COMEX starting at 2024-04-30 15:01:24.030000 2024-04-30 15:17:54.288 | Socket (2) | CloseSocket call. 2024-04-30 15:17:54.288 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-04-30 15:17:54.288 | Historical data download thread signaled to stop. 2024-04-30 15:17:54.288 | HD Request # 32 | Timestamp of first Intraday data file record written: 2024-04-30 15:01:26.090000. 2024-04-30 15:17:54.288 | HD Request # 32 | Received 1541 Intraday data records from 2024-04-30 15:01:24.030000 to 2024-04-30 15:07:53.842000 (6.5 minutes. Delay: 10.0 minutes) and wrote 1536 records for GCM24-COMEX 2024-04-30 15:17:54.293 | HD Request # 32 | Add time&sales data | Remembered last file record date-time: 2024-04-30 13:07:53.842000 2024-04-30 15:17:54.293 | HD Request # 32 | Completion time: 1s. 2024-04-30 15:17:54.293 | HD Request # 32 | Intraday data download complete for GCM24-COMEX. Unique request ID: 35 2024-04-30 15:17:54.293 | Removing historical data download ID 35. 2024-04-30 15:17:54.293 | Real-time Intraday chart data file updates started for GCM24-COMEX 2024-04-30 15:17:54.293 | Intraday chart data file opened for GCM24-COMEX 2024-04-30 15:17:54.293 | HD Request # 32 | Enabling Intraday chart updating for symbol. 2024-04-30 15:17:54.293 | 2024-04-30 15:17:54.293 | Triggering next historical data download in queue. 2024-04-30 15:17:54.293 | HD Request # 33 | Downloading Intraday chart data for NQM24-CME to the file NQM24-CME.scid. Service: cme 2024-04-30 15:17:54.294 | HD Request # 33 | Download start date-time: 2024-04-23 04:02:56.000000. File last date-time: 2024-04-23 04:02:56.767001 2024-04-30 15:17:54.294 | HD Request # 33 | Using server: ds26.sierracharts.com port 10149 2024-04-30 15:17:54.294 | Socket (3) | Creating socket. 2024-04-30 15:17:54.294 | Socket (3) | New receive buffer size: 0 2024-04-30 15:17:54.294 | Socket (3) | Connecting to IP: 38.103.112.197. 2024-04-30 15:17:54.404 | Socket (2) | Socket gracefully closed by remote side. 2024-04-30 15:17:54.404 | Socket (2) | Closed. 2024-04-30 15:17:54.543 | HD Request # 33 | Setting DTC encoding to Binary VLS 2024-04-30 15:17:54.543 | HD Request # 33 | Sending historical data logon request message. 2024-04-30 15:17:54.784 | Opened cached Intraday file: C:\Sierra Chart\Data\GCM24-COMEX.scid. Thread ID: 20216 2024-04-30 15:17:54.903 | HD Request # 33 | Requesting Intraday data. Start date-time: 2024-04-23 04:02:56. Record interval: 0. Symbol: NQM24 2024-04-30 15:17:55.016 | HD Request # 33 | Decompressing data. 2024-04-30 15:17:55.261 | HD Request # 33 | Receiving Intraday data for NQM24-CME starting at 2024-04-23 04:02:56.765000 2024-04-30 15:17:55.497 | HD Request # 33 | Timestamp of first Intraday data file record written: 2024-04-23 04:02:57.506000. 2024-04-30 15:18:04.711 | Socket (3) | CloseSocket call. 2024-04-30 15:18:04.711 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-04-30 15:18:04.728 | Historical data download thread signaled to stop. 2024-04-30 15:18:04.728 | HD Request # 33 | Received 3023756 Intraday data records from 2024-04-23 04:02:56.765000 to 2024-04-30 15:08:04.644000 (7.5 days. Delay: 10.0 minutes) and wrote 3023749 records for NQM24-CME 2024-04-30 15:18:04.733 | HD Request # 33 | Add time&sales data | Remembered last file record date-time: 2024-04-30 13:08:04.644000 2024-04-30 15:18:04.734 | HD Request # 33 | Completion time: 10s. 2024-04-30 15:18:04.734 | HD Request # 33 | Intraday data download complete for NQM24-CME. Unique request ID: 36 2024-04-30 15:18:04.734 | Removing historical data download ID 36. 2024-04-30 15:18:04.734 | Real-time Intraday chart data file updates started for NQM24-CME 2024-04-30 15:18:04.734 | Intraday chart data file opened for NQM24-CME 2024-04-30 15:18:04.734 | HD Request # 33 | Enabling Intraday chart updating for symbol. 2024-04-30 15:18:04.734 | 2024-04-30 15:18:04.734 | Triggering next historical data download in queue. 2024-04-30 15:18:04.734 | HD Request # 34 | Downloading Intraday chart data for YMM24-CBOT to the file YMM24-CBOT.scid. Service: cbot 2024-04-30 15:18:04.734 | HD Request # 34 | Download start date-time: 2024-04-30 15:01:24.000000. File last date-time: 2024-04-30 15:01:24.943000 2024-04-30 15:18:04.734 | HD Request # 34 | Using server: ds28.sierracharts.com port 10150 2024-04-30 15:18:04.734 | Socket (2) | Creating socket. 2024-04-30 15:18:04.734 | Socket (2) | New receive buffer size: 0 2024-04-30 15:18:04.734 | Socket (2) | Connecting to IP: 38.103.112.187. 2024-04-30 15:18:04.787 | Opened cached Intraday file: C:\Sierra Chart\Data\NQM24-CME.scid. Thread ID: 20216 2024-04-30 15:18:04.832 | Socket (3) | Socket gracefully closed by remote side. 2024-04-30 15:18:04.832 | Socket (3) | Closed. 2024-04-30 15:18:04.973 | HD Request # 34 | Setting DTC encoding to Binary VLS 2024-04-30 15:18:04.973 | HD Request # 34 | Sending historical data logon request message. 2024-04-30 15:18:05.334 | HD Request # 34 | Requesting Intraday data. Start date-time: 2024-04-30 15:01:24. Record interval: 0. Symbol: YMM24 2024-04-30 15:18:05.447 | HD Request # 34 | Decompressing data. 2024-04-30 15:18:05.559 | HD Request # 34 | Receiving Intraday data for YMM24-CBOT starting at 2024-04-30 15:01:24.571000 2024-04-30 15:18:05.559 | Socket (2) | CloseSocket call. 2024-04-30 15:18:05.559 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-04-30 15:18:05.623 | Historical data download thread signaled to stop. 2024-04-30 15:18:05.623 | HD Request # 34 | Timestamp of first Intraday data file record written: 2024-04-30 15:01:30.828000. 2024-04-30 15:18:05.623 | HD Request # 34 | Received 641 Intraday data records from 2024-04-30 15:01:24.571000 to 2024-04-30 15:08:04.676003 (6.7 minutes. Delay: 10.0 minutes) and wrote 631 records for YMM24-CBOT 2024-04-30 15:18:05.629 | HD Request # 34 | Add time&sales data | Remembered last file record date-time: 2024-04-30 13:08:04.676003 2024-04-30 15:18:05.629 | HD Request # 34 | Completion time: 1s. 2024-04-30 15:18:05.629 | HD Request # 34 | Intraday data download complete for YMM24-CBOT. Unique request ID: 37 2024-04-30 15:18:05.629 | Removing historical data download ID 37. 2024-04-30 15:18:05.629 | Real-time Intraday chart data file updates started for YMM24-CBOT 2024-04-30 15:18:05.629 | Intraday chart data file opened for YMM24-CBOT 2024-04-30 15:18:05.629 | HD Request # 34 | Enabling Intraday chart updating for symbol. 2024-04-30 15:18:05.629 | 2024-04-30 15:18:05.629 | Triggering next historical data download in queue. 2024-04-30 15:18:05.629 | HD Request # 35 | Downloading Intraday chart data for 6EM24-CME to the file 6EM24-CME.scid. Service: cme 2024-04-30 15:18:05.629 | HD Request # 35 | Download start date-time: 2024-04-23 01:53:31.000000. File last date-time: 2024-04-23 01:53:31.167002 2024-04-30 15:18:05.629 | HD Request # 35 | Using server: ds13.sierracharts.com port 10149 2024-04-30 15:18:05.629 | Socket (3) | Creating socket. 2024-04-30 15:18:05.629 | Socket (3) | New receive buffer size: 0 2024-04-30 15:18:05.629 | Socket (3) | Connecting to IP: 38.142.170.155. 2024-04-30 15:18:05.679 | Socket (2) | Socket gracefully closed by remote side. 2024-04-30 15:18:05.679 | Socket (2) | Closed. 2024-04-30 15:18:05.997 | HD Request # 35 | Setting DTC encoding to Binary VLS 2024-04-30 15:18:05.997 | HD Request # 35 | Sending historical data logon request message. 2024-04-30 15:18:06.212 | HD Request # 35 | Requesting Intraday data. Start date-time: 2024-04-23 01:53:31. Record interval: 0. Symbol: 6EM24 2024-04-30 15:18:06.381 | HD Request # 35 | Decompressing data. 2024-04-30 15:18:06.752 | HD Request # 35 | Receiving Intraday data for 6EM24-CME starting at 2024-04-23 01:53:31.162000 2024-04-30 15:18:07.430 | HD Request # 35 | Timestamp of first Intraday data file record written: 2024-04-23 01:53:42.495000. 2024-04-30 15:18:08.673 | Opened cached Intraday file: C:\Sierra Chart\Data\YMM24-CBOT.scid. Thread ID: 20216 2024-04-30 15:18:10.232 | Socket (3) | CloseSocket call. 2024-04-30 15:18:10.232 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-04-30 15:18:10.239 | Historical data download thread signaled to stop. 2024-04-30 15:18:10.239 | HD Request # 35 | Received 526887 Intraday data records from 2024-04-23 01:53:31.162000 to 2024-04-30 15:08:09.544001 (7.6 days. Delay: 10.0 minutes) and wrote 526880 records for 6EM24-CME 2024-04-30 15:18:10.244 | HD Request # 35 | Add time&sales data | Remembered last file record date-time: 2024-04-30 13:08:09.544001 2024-04-30 15:18:10.244 | HD Request # 35 | Completion time: 5s. 2024-04-30 15:18:10.244 | HD Request # 35 | Intraday data download complete for 6EM24-CME. Unique request ID: 38 2024-04-30 15:18:10.244 | Removing historical data download ID 38. 2024-04-30 15:18:10.244 | Real-time Intraday chart data file updates started for 6EM24-CME 2024-04-30 15:18:10.244 | Intraday chart data file opened for 6EM24-CME 2024-04-30 15:18:10.244 | HD Request # 35 | Enabling Intraday chart updating for symbol. 2024-04-30 15:18:10.244 | 2024-04-30 15:18:10.244 | No download requests in the queue to start downloads for. 2024-04-30 15:18:10.410 | Socket (3) | Socket gracefully closed by remote side. 2024-04-30 15:18:10.410 | Socket (3) | Closed. 2024-04-30 15:18:10.821 | Opened cached Intraday file: C:\Sierra Chart\Data\6EM24-CME.scid. Thread ID: 20216 2024-04-30 15:18:27.110 | Delayed Data Feed | Waiting for socket receive thread to end 2024-04-30 15:18:27.111 | DTC Client socket (1) | CloseSocket call. 2024-04-30 15:18:27.111 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-04-30 15:18:27.111 | Delayed Data Feed | Disconnected from the server. 2024-04-30 15:18:27.111 | SC Data - All Services | Disconnected. | Number times message added: 1 2024-04-30 15:18:27.112 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (2) | Creating socket. Using TLS 1.2. 2024-04-30 15:18:27.112 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (2) | New receive buffer size: 0 2024-04-30 15:18:27.112 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (2) | Connecting to IP: 38.79.0.89. 2024-04-30 15:18:27.129 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 8. 2024-04-30 15:18:27.129 | Current selected Data/Trading service: Rithmic Direct - DTC 2024-04-30 15:18:27.385 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-04-30 15:18:27.385 | DTC Client socket (1) | Closed. 2024-04-30 15:18:27.779 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (2) | Socket gracefully closed by remote side. | Number times message added: 1 2024-04-30 15:18:27.787 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (2) | CloseSocket call. 2024-04-30 15:18:27.787 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-30 15:18:27.787 | HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (2) | Closed. 2024-04-30 15:18:28.152 | Symbol settings MD5 received. Request ID: 8. 2024-04-30 15:18:28.153 | Requested symbol settings for service code rithmic_v2.trading. Request ID: 9. 2024-04-30 15:18:28.745 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2024-04-30 15:18:28.757 | YMM4.CBOT[M] 1 Min #6 | Reloading chart. 2024-04-30 15:18:28.766 | YMM4.CBOT[M] 15 Min #11 | Reloading chart. 2024-04-30 15:18:28.770 | 6EM4.CME[M] 15 Min #10 | Reloading chart. 2024-04-30 15:18:28.775 | GCM4.COMEX[M] 15 Min #8 | Reloading chart. 2024-04-30 15:18:28.777 | NQM4.CME[M] 15 Min #9 | Reloading chart. 2024-04-30 15:18:28.780 | 6EM4.CME[M] 15 Min #10 | Reloading chart. 2024-04-30 15:18:28.787 | YMM4.CBOT[M] 1 Min #6 | StartDateTimeForLoadingOrderFills: 2024-04-16 15:17:12 2024-04-30 15:18:28.804 | YMM4.CBOT[M] 1 Min #6 | Chart data loading complete. 2024-04-30 15:18:28.821 | YMM4.CBOT[M] 15 Min #7 | Reloading chart. 2024-04-30 15:18:28.824 | CLM4.NYMEX [C][M] 15 Min #5 | Reloading chart. 2024-04-30 15:18:28.830 | CLM4.NYMEX[M] #2 | Reloading chart. 2024-04-30 15:18:28.833 | CLM4.NYMEX[M] #3 | Reloading chart. 2024-04-30 15:18:28.838 | CLM4.NYMEX[M] #4 | Reloading chart. 2024-04-30 15:18:28.843 | CLM4.NYMEX[M] 1 Min #12 | Reloading chart. 2024-04-30 15:18:28.846 | CLM4.NYMEX[M] 1 Min #1 | Reloading chart. 2024-04-30 15:18:28.849 | CLM4.NYMEX[M] 15 Min #11 | Reloading chart. 2024-04-30 15:18:28.854 | NQM4.CME[M] 1 Min #2 | Reloading chart. 2024-04-30 15:18:28.862 | ESM4.CME[M] 1 Min #4 | Reloading chart. 2024-04-30 15:18:28.865 | CLM4.NYMEX[M] 1 Min #12 | StartDateTimeForLoadingOrderFills: 2024-04-16 15:17:16 2024-04-30 15:18:28.867 | CLM4.NYMEX[M] 1 Min #12 | Chart data loading complete. 2024-04-30 15:18:28.875 | NQM4.CME[M] #1 | Reloading chart. 2024-04-30 15:18:28.882 | YMM4.CBOT[M] #5 | Reloading chart. 2024-04-30 15:18:28.900 | ESM4.CME[M] #3 | Reloading chart. 2024-04-30 15:18:28.909 | CLM4.NYMEX[M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 2024-04-16 15:17:16 2024-04-30 15:18:28.911 | CLM4.NYMEX[M] 1 Min #1 | Chart data loading complete. 2024-04-30 15:18:28.913 | ESM4.CME[M] 15 Min #8 | Reloading chart. 2024-04-30 15:18:28.919 | GCM4.COMEX[M] 15 Min #12 | Reloading chart. 2024-04-30 15:18:28.924 | CLM4.NYMEX[M] #3 | StartDateTimeForLoadingOrderFills: 2024-04-16 15:17:16 2024-04-30 15:18:28.928 | CLM4.NYMEX[M] #3 | Chart data loading complete. 2024-04-30 15:18:28.934 | CLM4.NYMEX[M] #2 | StartDateTimeForLoadingOrderFills: 2024-04-16 15:17:16 2024-04-30 15:18:28.937 | CLM4.NYMEX[M] #2 | Chart data loading complete. 2024-04-30 15:18:28.940 | ESM4.CME[M] 15 Min #6 | Reloading chart. 2024-04-30 15:18:28.945 | NQM4.CME[M] 15 Min #9 | Reloading chart. 2024-04-30 15:18:28.953 | CLM4.NYMEX[M] 15 Min #13 | Reloading chart. 2024-04-30 15:18:28.965 | CLM4.NYMEX [C][M] 15 Min #7 | Reloading chart. 2024-04-30 15:18:28.970 | YMM4.CBOT[M] #5 | StartDateTimeForLoadingOrderFills: 2024-04-16 15:17:12 2024-04-30 15:18:28.982 | YMM4.CBOT[M] #5 | Chart data loading complete. 2024-04-30 15:18:29.050 | NQM4.CME[M] 1 Min #2 | StartDateTimeForLoadingOrderFills: 2024-04-16 15:17:15 2024-04-30 15:18:29.080 | NQM4.CME[M] 1 Min #2 | Chart data loading complete. 2024-04-30 15:18:29.110 | ESM4.CME[M] 1 Min #4 | StartDateTimeForLoadingOrderFills: 2024-04-16 15:17:15 2024-04-30 15:18:29.131 | ESM4.CME[M] 1 Min #4 | Chart data loading complete. 2024-04-30 15:18:29.150 | NQM4.CME[M] #1 | StartDateTimeForLoadingOrderFills: 2024-04-16 15:17:15 2024-04-30 15:18:29.166 | NQM4.CME[M] #1 | Chart data loading complete. 2024-04-30 15:18:29.201 | 6EM4.CME 15 Min #10 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:00:00 2024-04-30 15:18:29.204 | 6EM4.CME 15 Min #10 | Chart data loading complete. 2024-04-30 15:18:29.234 | 6EM4.CME 15 Min #10 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:00:00 2024-04-30 15:18:29.242 | 6EM4.CME 15 Min #10 | Chart data loading complete. 2024-04-30 15:18:29.243 | ESM4.CME[M] #3 | StartDateTimeForLoadingOrderFills: 2024-04-16 15:17:15 2024-04-30 15:18:29.254 | ESM4.CME[M] #3 | Chart data loading complete. 2024-04-30 15:18:29.272 | CLM4.NYMEX 15 Min #11 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:00:00 2024-04-30 15:18:29.274 | CLM4.NYMEX 15 Min #11 | Chart data loading complete. 2024-04-30 15:18:29.375 | CLM4.NYMEX 15 Min #13 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:00:00 2024-04-30 15:18:29.383 | CLM4.NYMEX 15 Min #13 | Chart data loading complete. 2024-04-30 15:18:29.481 | YMM4.CBOT 15 Min #11 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:30:00 2024-04-30 15:18:29.488 | YMM4.CBOT 15 Min #11 | Chart data loading complete. 2024-04-30 15:18:29.506 | YMM4.CBOT 15 Min #7 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:30:00 2024-04-30 15:18:29.509 | YMM4.CBOT 15 Min #7 | Chart data loading complete. 2024-04-30 15:18:29.513 | GCM4.COMEX 15 Min #8 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:00:00 2024-04-30 15:18:29.516 | GCM4.COMEX 15 Min #8 | Chart data loading complete. 2024-04-30 15:18:29.586 | Symbol settings received. Request ID: 9. 2024-04-30 15:18:29.654 | GCM4.COMEX 15 Min #12 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:00:00 2024-04-30 15:18:29.663 | GCM4.COMEX 15 Min #12 | Chart data loading complete. 2024-04-30 15:18:29.701 | CLM4.NYMEX #4 | Chart data loading complete. 2024-04-30 15:18:29.732 | CLM4.NYMEX [C] 15 Min #5 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:00:00 2024-04-30 15:18:29.732 | CLM4.NYMEX [C] 15 Min #5 | Chart data loading complete. 2024-04-30 15:18:29.814 | CLM4.NYMEX [C] 15 Min #7 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:00:00 2024-04-30 15:18:29.854 | CLM4.NYMEX [C] 15 Min #7 | Chart data loading complete. 2024-04-30 15:18:31.150 | NQM4.CME 15 Min #9 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:00:00 2024-04-30 15:18:31.155 | NQM4.CME 15 Min #9 | Chart data loading complete. 2024-04-30 15:18:31.257 | NQM4.CME 15 Min #9 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:00:00 2024-04-30 15:18:31.267 | NQM4.CME 15 Min #9 | Chart data loading complete. 2024-04-30 15:18:32.722 | ESM4.CME 15 Min #8 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:00:00 2024-04-30 15:18:32.729 | ESM4.CME 15 Min #8 | Chart data loading complete. 2024-04-30 15:18:32.739 | ESM4.CME 15 Min #6 | StartDateTimeForLoadingOrderFills: 2024-03-04 00:00:00 2024-04-30 15:18:32.741 | ESM4.CME 15 Min #6 | Chart data loading complete. 2024-04-30 15:18:32.752 | 2024-04-30 15:18:32.752 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Frankfurt-Aggregated 2024-04-30 15:18:32.754 | Rithmic Direct - DTC | Connecting to the server rsc-de.rithmic.com. Port 40800 2024-04-30 15:18:32.754 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-04-30 15:18:32.754 | DTC Client socket (1) | New receive buffer size: 0 2024-04-30 15:18:32.754 | DTC Client socket (1) | Connecting to IP: 130.117.187.66. 2024-04-30 15:18:32.770 | Rithmic Direct - DTC | Network connection to server complete. 2024-04-30 15:18:32.770 | Rithmic Direct - DTC | Starting socket receive thread. 2024-04-30 15:18:32.770 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-04-30 15:18:32.770 | Rithmic Direct - DTC | Sending logon request message. 2024-04-30 15:18:32.911 | Rithmic Direct - DTC | Received logon response. 2024-04-30 15:18:32.911 | Rithmic Direct - DTC | Server Name: . 2024-04-30 15:18:32.911 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-04-30 15:18:32.911 | Rithmic Direct - DTC | Successfully connected. 2024-04-30 15:18:32.911 | Rithmic Direct - DTC | Trading is supported. 2024-04-30 15:18:32.911 | Rithmic Direct - DTC | Order cancel and replace is supported. 2024-04-30 15:18:32.911 | Rithmic Direct - DTC | OCO Orders supported. 2024-04-30 15:18:32.911 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2024-04-30 15:18:32.911 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2024-04-30 15:18:32.911 | Rithmic Direct - DTC | Connected to server complete. 2024-04-30 15:18:32.911 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-04-30 15:18:32.911 | Subscribing to symbol for symbol alert. ESH2.CME 2024-04-30 15:18:32.911 | Using symbol data fast lookup vector 2024-04-30 15:18:32.911 | Rithmic Direct - DTC | Starting real-time market data updates for: ESH2.CME. ID: 1 Service code: rithmic.trading 2024-04-30 15:18:32.913 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-de.rithmic.com. Port 40803 2024-04-30 15:18:32.913 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2024-04-30 15:18:32.914 | DTC Client socket (2) | New receive buffer size: 0 2024-04-30 15:18:32.914 | DTC Client socket (2) | Connecting to IP: 130.117.187.66. 2024-04-30 15:18:32.915 | Rithmic Direct - DTC | Requesting security definition data for: ESH2.CME. ID: 1 2024-04-30 15:18:32.915 | Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. 2024-04-30 15:18:32.922 | Rithmic Direct - DTC | Starting real-time market data updates for: GCM4.COMEX. ID: 2 Service code: rithmic.trading 2024-04-30 15:18:32.922 | Rithmic Direct - DTC | Requesting security definition data for: GCM4.COMEX. ID: 2 2024-04-30 15:18:32.922 | Added historical Intraday data request for GCM4.COMEX to the queue. 2024-04-30 15:18:32.922 | Intraday data recording state for symbol GCM4.COMEX is set to download 'Pending'. 2024-04-30 15:18:32.922 | Triggering next historical data download in queue. 2024-04-30 15:18:32.929 | Delaying start of download for GCM4.COMEX. 2024-04-30 15:18:32.929 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-30 15:18:32.929 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-30 15:18:32.929 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-30 15:18:32.929 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-30 15:18:32.930 | Rithmic Direct - DTC | Starting real-time market data updates for: NQM4.CME. ID: 3 Service code: rithmic.trading 2024-04-30 15:18:32.930 | Rithmic Direct - DTC | Requesting security definition data for: NQM4.CME. ID: 3 2024-04-30 15:18:32.930 | Added historical Intraday data request for NQM4.CME to the queue. 2024-04-30 15:18:32.930 | Intraday data recording state for symbol NQM4.CME is set to download 'Pending'. 2024-04-30 15:18:32.930 | Triggering next historical data download in queue. 2024-04-30 15:18:32.935 | Rithmic Direct - DTC | Starting real-time market data updates for: ESM4.CME. ID: 4 Service code: rithmic.trading 2024-04-30 15:18:32.935 | Rithmic Direct - DTC | Requesting security definition data for: ESM4.CME. ID: 4 2024-04-30 15:18:32.935 | Added historical Intraday data request for ESM4.CME to the queue. 2024-04-30 15:18:32.935 | Intraday data recording state for symbol ESM4.CME is set to download 'Pending'. 2024-04-30 15:18:32.935 | Triggering next historical data download in queue. 2024-04-30 15:18:32.942 | Rithmic Direct - DTC | Starting real-time market data updates for: CLM4.NYMEX. ID: 5 Service code: rithmic.trading 2024-04-30 15:18:32.942 | Rithmic Direct - DTC | Requesting security definition data for: CLM4.NYMEX. ID: 5 2024-04-30 15:18:32.942 | Added historical Intraday data request for CLM4.NYMEX to the queue. 2024-04-30 15:18:32.942 | Intraday data recording state for symbol CLM4.NYMEX is set to download 'Pending'. 2024-04-30 15:18:32.942 | Triggering next historical data download in queue. 2024-04-30 15:18:33.027 | Rithmic Direct - DTC | Starting real-time market data updates for: YMM4.CBOT. ID: 6 Service code: rithmic.trading 2024-04-30 15:18:33.027 | Rithmic Direct - DTC | Requesting security definition data for: YMM4.CBOT. ID: 6 2024-04-30 15:18:33.027 | Added historical Intraday data request for YMM4.CBOT to the queue. 2024-04-30 15:18:33.027 | Intraday data recording state for symbol YMM4.CBOT is set to download 'Pending'. 2024-04-30 15:18:33.027 | Triggering next historical data download in queue. 2024-04-30 15:18:33.039 | Rithmic Direct - DTC | Starting real-time market data updates for: 6EM4.CME. ID: 7 Service code: rithmic.trading 2024-04-30 15:18:33.039 | Rithmic Direct - DTC | Requesting security definition data for: 6EM4.CME. ID: 7 2024-04-30 15:18:33.039 | Added historical Intraday data request for 6EM4.CME to the queue. 2024-04-30 15:18:33.039 | Intraday data recording state for symbol 6EM4.CME is set to download 'Pending'. 2024-04-30 15:18:33.039 | Triggering next historical data download in queue. 2024-04-30 15:18:33.082 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-30 15:18:33.082 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-30 15:18:33.082 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-30 15:18:33.082 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-30 15:18:33.082 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-30 15:18:33.082 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-30 15:18:33.082 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-30 15:18:33.082 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: 6EM4.CME 2024-04-30 15:18:33.082 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLM4.NYMEX 2024-04-30 15:18:33.082 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESH2.CME 2024-04-30 15:18:33.082 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM4.CME 2024-04-30 15:18:33.082 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCM4.COMEX 2024-04-30 15:18:33.082 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQM4.CME 2024-04-30 15:18:33.082 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: YMM4.CBOT 2024-04-30 15:18:33.310 | Rithmic Direct - DTC (Data) | Received security definition for symbol 6EM4.CME 2024-04-30 15:18:33.310 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLM4.NYMEX 2024-04-30 15:18:33.311 | Rithmic Direct - DTC (Data) | Received security definition for symbol ESM4.CME 2024-04-30 15:18:33.312 | Rithmic Direct - DTC (Data) | Received security definition for symbol GCM4.COMEX 2024-04-30 15:18:33.333 | Rithmic Direct - DTC (Data) | Received security definition for symbol NQM4.CME 2024-04-30 15:18:33.333 | Rithmic Direct - DTC (Data) | Received security definition for symbol YMM4.CBOT 2024-04-30 15:18:37.914 | Requesting market depth updates for: CLM4.NYMEX if supported. NumLevels=100 2024-04-30 15:18:37.914 | Requesting market depth updates for: ESM4.CME if supported. NumLevels=100 2024-04-30 15:18:37.914 | Requesting market depth updates for: NQM4.CME if supported. NumLevels=100 2024-04-30 15:18:37.914 | Requesting market depth updates for: YMM4.CBOT if supported. NumLevels=100 2024-04-30 15:18:38.148 | Rithmic Direct - DTC (Data) | Clearing market depth for ESM4.CME 2024-04-30 15:18:38.194 | HD Request # 36 | Downloading Intraday chart data for GCM4.COMEX to the file GCM4.COMEX.scid. Service: rithmic.trading 2024-04-30 15:18:38.195 | HD Request # 36 | Download start date-time: 2024-04-30 15:17:14.000000. File last date-time: 2024-04-30 15:17:14.000004 2024-04-30 15:18:38.195 | HD Request # 36 | Using server: rsc-de.rithmic.com port 40802. Use encryption. 2024-04-30 15:18:38.195 | Socket (3) | Creating socket. Using TLS 1.2. 2024-04-30 15:18:38.195 | Socket (3) | New receive buffer size: 0 2024-04-30 15:18:38.195 | Socket (3) | Connecting to IP: 130.117.187.66. 2024-04-30 15:18:38.216 | Rithmic Direct - DTC (Data) | Clearing market depth for CLM4.NYMEX 2024-04-30 15:18:38.216 | HD Request # 36 | Sending historical data logon request message. 2024-04-30 15:18:38.235 | Rithmic Direct - DTC (Data) | Clearing market depth for YMM4.CBOT 2024-04-30 15:18:38.235 | Rithmic Direct - DTC (Data) | Clearing market depth for NQM4.CME 2024-04-30 15:18:38.361 | HD Request # 36 | Requesting Intraday data. Start date-time: 2024-04-30 15:17:14. Record interval: 0. Symbol: GCM4.COMEX 2024-04-30 15:18:38.575 | HD Request # 36 | Receiving Intraday data for GCM4.COMEX starting at 2024-04-30 15:17:14.020000 2024-04-30 15:18:38.588 | Socket (3) | CloseSocket call. 2024-04-30 15:18:38.589 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-04-30 15:18:38.589 | Historical data download thread signaled to stop. 2024-04-30 15:18:38.589 | HD Request # 36 | Timestamp of first Intraday data file record written: 2024-04-30 15:17:14.020000. 2024-04-30 15:18:38.589 | HD Request # 36 | Received 134 Intraday data records from 2024-04-30 15:17:14.020000 to 2024-04-30 15:18:38.934000 (84.9 seconds. Delay: -0.3 seconds) and wrote 134 records for GCM4.COMEX 2024-04-30 15:18:38.594 | HD Request # 36 | Add time&sales data | Remembered last file record date-time: 2024-04-30 13:18:38.934000 2024-04-30 15:18:38.594 | HD Request # 36 | Completion time: 0s. 2024-04-30 15:18:38.594 | HD Request # 36 | Intraday data download complete for GCM4.COMEX. Unique request ID: 40 2024-04-30 15:18:38.594 | Removing historical data download ID 40. 2024-04-30 15:18:38.594 | Real-time Intraday chart data file updates started for GCM4.COMEX 2024-04-30 15:18:38.594 | Intraday chart data file opened for GCM4.COMEX 2024-04-30 15:18:38.594 | HD Request # 36 | Enabling Intraday chart updating for symbol. 2024-04-30 15:18:38.594 | 2024-04-30 15:18:38.595 | Triggering next historical data download in queue. 2024-04-30 15:18:38.595 | HD Request # 37 | Downloading Intraday chart data for NQM4.CME to the file NQM4.CME.scid. Service: rithmic.trading 2024-04-30 15:18:38.595 | HD Request # 37 | Download start date-time: 2024-04-30 15:17:15.000000. File last date-time: 2024-04-30 15:17:15.000007 2024-04-30 15:18:38.595 | HD Request # 37 | Using server: rsc-de.rithmic.com port 40802. Use encryption. 2024-04-30 15:18:38.595 | Socket (4) | Creating socket. Using TLS 1.2. 2024-04-30 15:18:38.595 | Socket (4) | New receive buffer size: 0 2024-04-30 15:18:38.595 | Socket (4) | Connecting to IP: 130.117.187.66. 2024-04-30 15:18:38.611 | Socket (3) | Socket gracefully closed by remote side. 2024-04-30 15:18:38.611 | Socket (3) | Closed. 2024-04-30 15:18:38.615 | HD Request # 37 | Sending historical data logon request message. 2024-04-30 15:18:38.769 | HD Request # 37 | Requesting Intraday data. Start date-time: 2024-04-30 15:17:15. Record interval: 0. Symbol: NQM4.CME 2024-04-30 15:18:38.994 | HD Request # 37 | Receiving Intraday data for NQM4.CME starting at 2024-04-30 15:17:15.540000 2024-04-30 15:18:39.013 | Socket (4) | CloseSocket call. 2024-04-30 15:18:39.013 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-04-30 15:18:39.027 | Socket (4) | Socket gracefully closed by remote side. 2024-04-30 15:18:39.027 | Socket (4) | Closed. 2024-04-30 15:18:39.030 | Historical data download thread signaled to stop. 2024-04-30 15:18:39.030 | HD Request # 37 | Timestamp of first Intraday data file record written: 2024-04-30 15:17:15.540000. 2024-04-30 15:18:39.030 | HD Request # 37 | Received 432 Intraday data records from 2024-04-30 15:17:15.540000 to 2024-04-30 15:18:38.929000 (83.4 seconds. Delay: 0.1 seconds) and wrote 432 records for NQM4.CME 2024-04-30 15:18:39.036 | HD Request # 37 | Add time&sales data | Remembered last file record date-time: 2024-04-30 13:18:38.929000 2024-04-30 15:18:39.036 | HD Request # 37 | Completion time: 1s. 2024-04-30 15:18:39.036 | HD Request # 37 | Intraday data download complete for NQM4.CME. Unique request ID: 41 2024-04-30 15:18:39.036 | Removing historical data download ID 41. 2024-04-30 15:18:39.036 | Real-time Intraday chart data file updates started for NQM4.CME 2024-04-30 15:18:39.036 | Intraday chart data file opened for NQM4.CME 2024-04-30 15:18:39.036 | HD Request # 37 | Enabling Intraday chart updating for symbol. 2024-04-30 15:18:39.036 | 2024-04-30 15:18:39.036 | Triggering next historical data download in queue. 2024-04-30 15:18:39.036 | HD Request # 38 | Downloading Intraday chart data for ESM4.CME to the file ESM4.CME.scid. Service: rithmic.trading 2024-04-30 15:18:39.036 | HD Request # 38 | Download start date-time: 2024-04-30 15:17:15.000000. File last date-time: 2024-04-30 15:17:15.000000 2024-04-30 15:18:39.037 | HD Request # 38 | Using server: rsc-de.rithmic.com port 40802. Use encryption. 2024-04-30 15:18:39.037 | Socket (3) | Creating socket. Using TLS 1.2. 2024-04-30 15:18:39.037 | Socket (3) | New receive buffer size: 0 2024-04-30 15:18:39.037 | Socket (3) | Connecting to IP: 130.117.187.66. 2024-04-30 15:18:39.052 | HD Request # 38 | Sending historical data logon request message. 2024-04-30 15:18:39.194 | HD Request # 38 | Requesting Intraday data. Start date-time: 2024-04-30 15:17:15. Record interval: 0. Symbol: ESM4.CME 2024-04-30 15:18:39.414 | HD Request # 38 | Receiving Intraday data for ESM4.CME starting at 2024-04-30 15:17:15.230000 2024-04-30 15:18:39.433 | Socket (3) | CloseSocket call. 2024-04-30 15:18:39.433 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-04-30 15:18:39.444 | Historical data download thread signaled to stop. 2024-04-30 15:18:39.444 | HD Request # 38 | Timestamp of first Intraday data file record written: 2024-04-30 15:17:15.230000. 2024-04-30 15:18:39.444 | HD Request # 38 | Received 599 Intraday data records from 2024-04-30 15:17:15.230000 to 2024-04-30 15:18:39.910010 (84.7 seconds. Delay: -0.5 seconds) and wrote 599 records for ESM4.CME 2024-04-30 15:18:39.447 | Socket (3) | Socket gracefully closed by remote side. 2024-04-30 15:18:39.447 | Socket (3) | Closed. 2024-04-30 15:18:39.449 | HD Request # 38 | Add time&sales data | Remembered last file record date-time: 2024-04-30 13:18:39.910010 2024-04-30 15:18:39.449 | HD Request # 38 | Completion time: 0s. 2024-04-30 15:18:39.449 | HD Request # 38 | Intraday data download complete for ESM4.CME. Unique request ID: 42 2024-04-30 15:18:39.449 | Removing historical data download ID 42. 2024-04-30 15:18:39.449 | Real-time Intraday chart data file updates started for ESM4.CME 2024-04-30 15:18:39.449 | Intraday chart data file opened for ESM4.CME 2024-04-30 15:18:39.449 | HD Request # 38 | Enabling Intraday chart updating for symbol. 2024-04-30 15:18:39.449 | 2024-04-30 15:18:39.449 | Triggering next historical data download in queue. 2024-04-30 15:18:39.449 | HD Request # 39 | Downloading Intraday chart data for CLM4.NYMEX to the file CLM4.NYMEX.scid. Service: rithmic.trading 2024-04-30 15:18:39.450 | HD Request # 39 | Download start date-time: 2024-04-30 15:17:16.000000. File last date-time: 2024-04-30 15:17:16.000002 2024-04-30 15:18:39.450 | HD Request # 39 | Using server: rsc-de.rithmic.com port 40802. Use encryption. 2024-04-30 15:18:39.450 | Socket (3) | Creating socket. Using TLS 1.2. 2024-04-30 15:18:39.450 | Socket (3) | New receive buffer size: 0 2024-04-30 15:18:39.450 | Socket (3) | Connecting to IP: 130.117.187.66. 2024-04-30 15:18:39.465 | HD Request # 39 | Sending historical data logon request message. 2024-04-30 15:18:39.613 | HD Request # 39 | Requesting Intraday data. Start date-time: 2024-04-30 15:17:16. Record interval: 0. Symbol: CLM4.NYMEX 2024-04-30 15:18:39.828 | HD Request # 39 | Receiving Intraday data for CLM4.NYMEX starting at 2024-04-30 15:17:16.030000 2024-04-30 15:18:39.856 | Socket (3) | CloseSocket call. 2024-04-30 15:18:39.856 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-04-30 15:18:39.856 | Historical data download thread signaled to stop. 2024-04-30 15:18:39.856 | HD Request # 39 | Timestamp of first Intraday data file record written: 2024-04-30 15:17:16.030000. 2024-04-30 15:18:39.856 | HD Request # 39 | Received 405 Intraday data records from 2024-04-30 15:17:16.030000 to 2024-04-30 15:18:39.529000 (83.5 seconds. Delay: 0.3 seconds) and wrote 405 records for CLM4.NYMEX 2024-04-30 15:18:39.861 | HD Request # 39 | Add time&sales data | Remembered last file record date-time: 2024-04-30 13:18:39.529000 2024-04-30 15:18:39.861 | HD Request # 39 | Completion time: 0s. 2024-04-30 15:18:39.861 | HD Request # 39 | Intraday data download complete for CLM4.NYMEX. Unique request ID: 43 2024-04-30 15:18:39.861 | Removing historical data download ID 43. 2024-04-30 15:18:39.861 | Real-time Intraday chart data file updates started for CLM4.NYMEX 2024-04-30 15:18:39.861 | Intraday chart data file opened for CLM4.NYMEX 2024-04-30 15:18:39.861 | HD Request # 39 | Enabling Intraday chart updating for symbol. 2024-04-30 15:18:39.861 | 2024-04-30 15:18:39.861 | Triggering next historical data download in queue. 2024-04-30 15:18:39.861 | HD Request # 40 | Downloading Intraday chart data for YMM4.CBOT to the file YMM4.CBOT.scid. Service: rithmic.trading 2024-04-30 15:18:39.861 | HD Request # 40 | Download start date-time: 2024-04-30 15:17:12.000000. File last date-time: 2024-04-30 15:17:12.000001 2024-04-30 15:18:39.861 | HD Request # 40 | Using server: rsc-de.rithmic.com port 40802. Use encryption. 2024-04-30 15:18:39.862 | Socket (4) | Creating socket. Using TLS 1.2. 2024-04-30 15:18:39.862 | Socket (4) | New receive buffer size: 0 2024-04-30 15:18:39.862 | Socket (4) | Connecting to IP: 130.117.187.66. 2024-04-30 15:18:39.875 | HD Request # 40 | Sending historical data logon request message. 2024-04-30 15:18:39.877 | Socket (3) | Socket gracefully closed by remote side. 2024-04-30 15:18:39.877 | Socket (3) | Closed. 2024-04-30 15:18:40.021 | HD Request # 40 | Requesting Intraday data. Start date-time: 2024-04-30 15:17:12. Record interval: 0. Symbol: YMM4.CBOT 2024-04-30 15:18:40.235 | HD Request # 40 | Receiving Intraday data for YMM4.CBOT starting at 2024-04-30 15:17:12.455000 2024-04-30 15:18:40.242 | Socket (4) | CloseSocket call. 2024-04-30 15:18:40.242 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-04-30 15:18:40.242 | Historical data download thread signaled to stop. 2024-04-30 15:18:40.242 | HD Request # 40 | Timestamp of first Intraday data file record written: 2024-04-30 15:17:12.455000. 2024-04-30 15:18:40.242 | HD Request # 40 | Received 30 Intraday data records from 2024-04-30 15:17:12.455000 to 2024-04-30 15:18:39.910000 (87.5 seconds. Delay: 0.3 seconds) and wrote 30 records for YMM4.CBOT 2024-04-30 15:18:40.247 | HD Request # 40 | Add time&sales data | Remembered last file record date-time: 2024-04-30 13:18:39.910000 2024-04-30 15:18:40.247 | HD Request # 40 | Completion time: 1s. 2024-04-30 15:18:40.247 | HD Request # 40 | Intraday data download complete for YMM4.CBOT. Unique request ID: 44 2024-04-30 15:18:40.247 | Removing historical data download ID 44. 2024-04-30 15:18:40.247 | Real-time Intraday chart data file updates started for YMM4.CBOT 2024-04-30 15:18:40.247 | Intraday chart data file opened for YMM4.CBOT 2024-04-30 15:18:40.247 | HD Request # 40 | Enabling Intraday chart updating for symbol. 2024-04-30 15:18:40.247 | 2024-04-30 15:18:40.247 | Triggering next historical data download in queue. 2024-04-30 15:18:40.247 | HD Request # 41 | Downloading Intraday chart data for 6EM4.CME to the file 6EM4.CME.scid. Service: rithmic.trading 2024-04-30 15:18:40.248 | HD Request # 41 | Download start date-time: 2024-04-30 15:17:14.000000. File last date-time: 2024-04-30 15:17:14.000013 2024-04-30 15:18:40.248 | HD Request # 41 | Using server: rsc-de.rithmic.com port 40802. Use encryption. 2024-04-30 15:18:40.248 | Socket (3) | Creating socket. Using TLS 1.2. 2024-04-30 15:18:40.248 | Socket (3) | New receive buffer size: 0 2024-04-30 15:18:40.248 | Socket (3) | Connecting to IP: 130.117.187.66. 2024-04-30 15:18:40.255 | Socket (4) | Socket gracefully closed by remote side. 2024-04-30 15:18:40.255 | Socket (4) | Closed. 2024-04-30 15:18:40.265 | HD Request # 41 | Sending historical data logon request message. 2024-04-30 15:18:40.406 | HD Request # 41 | Requesting Intraday data. Start date-time: 2024-04-30 15:17:14. Record interval: 0. Symbol: 6EM4.CME 2024-04-30 15:18:40.620 | HD Request # 41 | Receiving Intraday data for 6EM4.CME starting at 2024-04-30 15:17:14.541000 2024-04-30 15:18:40.629 | Socket (3) | CloseSocket call. 2024-04-30 15:18:40.629 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-04-30 15:18:40.629 | Historical data download thread signaled to stop. 2024-04-30 15:18:40.629 | HD Request # 41 | Timestamp of first Intraday data file record written: 2024-04-30 15:17:14.541000. 2024-04-30 15:18:40.629 | HD Request # 41 | Received 303 Intraday data records from 2024-04-30 15:17:14.541000 to 2024-04-30 15:18:38.621000 (84.1 seconds. Delay: 2.0 seconds) and wrote 303 records for 6EM4.CME 2024-04-30 15:18:40.634 | HD Request # 41 | Add time&sales data | Remembered last file record date-time: 2024-04-30 13:18:38.621000 2024-04-30 15:18:40.634 | HD Request # 41 | Completion time: 0s. 2024-04-30 15:18:40.634 | HD Request # 41 | Intraday data download complete for 6EM4.CME. Unique request ID: 45 2024-04-30 15:18:40.634 | Removing historical data download ID 45. 2024-04-30 15:18:40.634 | Real-time Intraday chart data file updates started for 6EM4.CME 2024-04-30 15:18:40.634 | Intraday chart data file opened for 6EM4.CME 2024-04-30 15:18:40.634 | HD Request # 41 | Enabling Intraday chart updating for symbol. 2024-04-30 15:18:40.634 | 2024-04-30 15:18:40.634 | No download requests in the queue to start downloads for. 2024-04-30 15:18:40.643 | Socket (3) | Socket gracefully closed by remote side. 2024-04-30 15:18:40.643 | Socket (3) | Closed. 2024-04-30 15:18:43.380 | Opened cached Intraday file: C:\Sierra Chart\Data\GCM4.COMEX.scid. Thread ID: 12880 2024-04-30 15:18:43.380 | Opened cached Intraday file: C:\Sierra Chart\Data\NQM4.CME.scid. Thread ID: 12880 2024-04-30 15:18:43.380 | Opened cached Intraday file: C:\Sierra Chart\Data\ESM4.CME.scid. Thread ID: 12880 2024-04-30 15:18:43.381 | Opened cached Intraday file: C:\Sierra Chart\Data\CLM4.NYMEX.scid. Thread ID: 12880 2024-04-30 15:18:52.804 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (3) | Creating socket. Using TLS 1.2. 2024-04-30 15:18:52.804 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (3) | New receive buffer size: 0 2024-04-30 15:18:52.804 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (3) | Connecting to IP: 38.79.0.89. 2024-04-30 15:18:53.438 | Opened cached Intraday file: C:\Sierra Chart\Data\YMM4.CBOT.scid. Thread ID: 12880 2024-04-30 15:18:53.438 | Opened cached Intraday file: C:\Sierra Chart\Data\6EM4.CME.scid. Thread ID: 12880 2024-04-30 15:18:53.508 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (3) | Socket gracefully closed by remote side. | Number times message added: 1 2024-04-30 15:18:53.509 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (3) | CloseSocket call. 2024-04-30 15:18:53.509 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-30 15:18:53.509 | HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (3) | Closed. 2024-04-30 15:19:52.184 | File >> Disconnect selected. 2024-04-30 15:19:52.184 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-04-30 15:19:52.184 | DTC Client socket (2) | CloseSocket call. 2024-04-30 15:19:52.184 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2024-04-30 15:19:52.184 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-04-30 15:19:52.191 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-04-30 15:19:52.192 | DTC Client socket (1) | CloseSocket call. 2024-04-30 15:19:52.192 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-04-30 15:19:52.192 | Rithmic Direct - DTC | Disconnected. 2024-04-30 15:19:52.197 | DTC Client socket (2) | Socket gracefully closed by remote side. 2024-04-30 15:19:52.197 | DTC Client socket (2) | Closed. 2024-04-30 15:19:52.211 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-04-30 15:19:52.211 | DTC Client socket (1) | Closed. 2024-04-30 15:19:56.050 | 2024-04-30 15:19:56.051 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Frankfurt-Aggregated 2024-04-30 15:19:56.051 | Rithmic Direct - DTC | Connecting to the server rsc-de.rithmic.com. Port 40800 2024-04-30 15:19:56.051 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-04-30 15:19:56.051 | DTC Client socket (1) | New receive buffer size: 0 2024-04-30 15:19:56.051 | DTC Client socket (1) | Connecting to IP: 130.117.187.66. 2024-04-30 15:19:56.069 | Rithmic Direct - DTC | Network connection to server complete. 2024-04-30 15:19:56.069 | Rithmic Direct - DTC | Starting socket receive thread. 2024-04-30 15:19:56.069 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-04-30 15:19:56.069 | Rithmic Direct - DTC | Sending logon request message. 2024-04-30 15:19:56.225 | Rithmic Direct - DTC | Received logon response. 2024-04-30 15:19:56.225 | Rithmic Direct - DTC | Server Name: . 2024-04-30 15:19:56.225 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-04-30 15:19:56.225 | Rithmic Direct - DTC | Successfully connected. 2024-04-30 15:19:56.225 | Rithmic Direct - DTC | Trading is supported. 2024-04-30 15:19:56.225 | Rithmic Direct - DTC | Order cancel and replace is supported. 2024-04-30 15:19:56.225 | Rithmic Direct - DTC | OCO Orders supported. 2024-04-30 15:19:56.225 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2024-04-30 15:19:56.225 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2024-04-30 15:19:56.225 | Rithmic Direct - DTC | Connected to server complete. 2024-04-30 15:19:56.226 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-04-30 15:19:56.226 | Subscribing to symbol for symbol alert. ESH2.CME 2024-04-30 15:19:56.226 | Using symbol data fast lookup vector 2024-04-30 15:19:56.226 | Rithmic Direct - DTC | Starting real-time market data updates for: ESH2.CME. ID: 1 Service code: rithmic.trading 2024-04-30 15:19:56.228 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-de.rithmic.com. Port 40803 2024-04-30 15:19:56.228 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2024-04-30 15:19:56.228 | DTC Client socket (2) | New receive buffer size: 0 2024-04-30 15:19:56.228 | DTC Client socket (2) | Connecting to IP: 130.117.187.66. 2024-04-30 15:19:56.230 | Rithmic Direct - DTC | Requesting security definition data for: ESH2.CME. ID: 1 2024-04-30 15:19:56.230 | Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. 2024-04-30 15:19:56.236 | Rithmic Direct - DTC | Starting real-time market data updates for: GCM4.COMEX. ID: 2 Service code: rithmic.trading 2024-04-30 15:19:56.236 | Rithmic Direct - DTC | Requesting security definition data for: GCM4.COMEX. ID: 2 2024-04-30 15:19:56.237 | Added historical Intraday data request for GCM4.COMEX to the queue. 2024-04-30 15:19:56.237 | Intraday data recording state for symbol GCM4.COMEX is set to download 'Pending'. 2024-04-30 15:19:56.237 | Triggering next historical data download in queue. 2024-04-30 15:19:56.244 | Delaying start of download for GCM4.COMEX. 2024-04-30 15:19:56.244 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-04-30 15:19:56.244 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-04-30 15:19:56.245 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-04-30 15:19:56.245 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-04-30 15:19:56.245 | Rithmic Direct - DTC | Starting real-time market data updates for: NQM4.CME. ID: 3 Service code: rithmic.trading 2024-04-30 15:19:56.245 | Rithmic Direct - DTC | Requesting security definition data for: NQM4.CME. ID: 3 2024-04-30 15:19:56.245 | Added historical Intraday data request for NQM4.CME to the queue. 2024-04-30 15:19:56.245 | Intraday data recording state for symbol NQM4.CME is set to download 'Pending'. 2024-04-30 15:19:56.245 | Triggering next historical data download in queue. 2024-04-30 15:19:56.276 | Rithmic Direct - DTC | Starting real-time market data updates for: ESM4.CME. ID: 4 Service code: rithmic.trading 2024-04-30 15:19:56.276 | Rithmic Direct - DTC | Requesting security definition data for: ESM4.CME. ID: 4 2024-04-30 15:19:56.276 | Added historical Intraday data request for ESM4.CME to the queue. 2024-04-30 15:19:56.276 | Intraday data recording state for symbol ESM4.CME is set to download 'Pending'. 2024-04-30 15:19:56.276 | Triggering next historical data download in queue. 2024-04-30 15:19:56.305 | Rithmic Direct - DTC | Starting real-time market data updates for: CLM4.NYMEX. ID: 5 Service code: rithmic.trading 2024-04-30 15:19:56.305 | Rithmic Direct - DTC | Requesting security definition data for: CLM4.NYMEX. ID: 5 2024-04-30 15:19:56.305 | Added historical Intraday data request for CLM4.NYMEX to the queue. 2024-04-30 15:19:56.305 | Intraday data recording state for symbol CLM4.NYMEX is set to download 'Pending'. 2024-04-30 15:19:56.305 | Triggering next historical data download in queue. 2024-04-30 15:19:56.392 | Rithmic Direct - DTC | Starting real-time market data updates for: YMM4.CBOT. ID: 6 Service code: rithmic.trading 2024-04-30 15:19:56.392 | Rithmic Direct - DTC | Requesting security definition data for: YMM4.CBOT. ID: 6 2024-04-30 15:19:56.392 | Added historical Intraday data request for YMM4.CBOT to the queue. 2024-04-30 15:19:56.392 | Intraday data recording state for symbol YMM4.CBOT is set to download 'Pending'. 2024-04-30 15:19:56.392 | Triggering next historical data download in queue. 2024-04-30 15:19:56.409 | Rithmic Direct - DTC (Data) | Received logon response. 2024-04-30 15:19:56.409 | Rithmic Direct - DTC (Data) | Server Name: . 2024-04-30 15:19:56.409 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-04-30 15:19:56.409 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-04-30 15:19:56.409 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-04-30 15:19:56.409 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-04-30 15:19:56.409 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-04-30 15:19:56.409 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLM4.NYMEX 2024-04-30 15:19:56.409 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESH2.CME 2024-04-30 15:19:56.409 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ESM4.CME 2024-04-30 15:19:56.409 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCM4.COMEX 2024-04-30 15:19:56.409 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NQM4.CME 2024-04-30 15:19:56.409 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: YMM4.CBOT 2024-04-30 15:19:56.420 | Rithmic Direct - DTC | Starting real-time market data updates for: 6EM4.CME. ID: 7 Service code: rithmic.trading 2024-04-30 15:19:56.420 | Rithmic Direct - DTC | Requesting security definition data for: 6EM4.CME. ID: 7 2024-04-30 15:19:56.420 | Added historical Intraday data request for 6EM4.CME to the queue. 2024-04-30 15:19:56.420 | Intraday data recording state for symbol 6EM4.CME is set to download 'Pending'. 2024-04-30 15:19:56.420 | Triggering next historical data download in queue. 2024-04-30 15:19:56.637 | Rithmic Direct - DTC (Data) | Received security definition for symbol CLM4.NYMEX 2024-04-30 15:19:56.645 | Rithmic Direct - DTC (Data) | Received security definition for symbol ESM4.CME 2024-04-30 15:19:56.683 | Rithmic Direct - DTC (Data) | Received security definition for symbol GCM4.COMEX 2024-04-30 15:19:56.683 | Rithmic Direct - DTC (Data) | Received security definition for symbol NQM4.CME 2024-04-30 15:19:56.683 | Rithmic Direct - DTC (Data) | Received security definition for symbol YMM4.CBOT 2024-04-30 15:20:01.271 | Requesting market depth updates for: CLM4.NYMEX if supported. NumLevels=100 2024-04-30 15:20:01.271 | Requesting market depth updates for: ESM4.CME if supported. NumLevels=100 2024-04-30 15:20:01.271 | Requesting market depth updates for: NQM4.CME if supported. NumLevels=100 2024-04-30 15:20:01.271 | Requesting market depth updates for: YMM4.CBOT if supported. NumLevels=100 2024-04-30 15:20:01.279 | HD Request # 42 | Downloading Intraday chart data for GCM4.COMEX to the file GCM4.COMEX.scid. Service: rithmic.trading 2024-04-30 15:20:01.279 | HD Request # 42 | Download start date-time: 2024-04-30 15:19:51.000000. File last date-time: 2024-04-30 15:19:51.000002 2024-04-30 15:20:01.279 | HD Request # 42 | Using server: rsc-de.rithmic.com port 40802. Use encryption. 2024-04-30 15:20:01.280 | Socket (3) | Creating socket. Using TLS 1.2. 2024-04-30 15:20:01.280 | Socket (3) | New receive buffer size: 0 2024-04-30 15:20:01.280 | Socket (3) | Connecting to IP: 130.117.187.66. 2024-04-30 15:20:01.296 | HD Request # 42 | Sending historical data logon request message. 2024-04-30 15:20:01.437 | HD Request # 42 | Requesting Intraday data. Start date-time: 2024-04-30 15:19:51. Record interval: 0. Symbol: GCM4.COMEX 2024-04-30 15:20:01.509 | Rithmic Direct - DTC (Data) | Clearing market depth for ESM4.CME 2024-04-30 15:20:01.609 | Rithmic Direct - DTC (Data) | Clearing market depth for CLM4.NYMEX 2024-04-30 15:20:01.609 | Rithmic Direct - DTC (Data) | Clearing market depth for YMM4.CBOT 2024-04-30 15:20:01.624 | Rithmic Direct - DTC (Data) | Clearing market depth for NQM4.CME 2024-04-30 15:20:01.651 | HD Request # 42 | Receiving Intraday data for GCM4.COMEX starting at 2024-04-30 15:19:51.931000 2024-04-30 15:20:01.662 | Socket (3) | CloseSocket call. 2024-04-30 15:20:01.662 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-04-30 15:20:01.662 | Historical data download thread signaled to stop. 2024-04-30 15:20:01.662 | HD Request # 42 | Timestamp of first Intraday data file record written: 2024-04-30 15:19:51.931000. 2024-04-30 15:20:01.662 | HD Request # 42 | Received 88 Intraday data records from 2024-04-30 15:19:51.931000 to 2024-04-30 15:20:01.444000 (9.5 seconds. Delay: 0.2 seconds) and wrote 88 records for GCM4.COMEX 2024-04-30 15:20:01.671 | HD Request # 42 | Add time&sales data | Remembered last file record date-time: 2024-04-30 13:20:01.444000 2024-04-30 15:20:01.671 | HD Request # 42 | Completion time: 0s. 2024-04-30 15:20:01.671 | HD Request # 42 | Intraday data download complete for GCM4.COMEX. Unique request ID: 46 2024-04-30 15:20:01.671 | Removing historical data download ID 46. 2024-04-30 15:20:01.671 | Real-time Intraday chart data file updates started for GCM4.COMEX 2024-04-30 15:20:01.671 | Intraday chart data file opened for GCM4.COMEX 2024-04-30 15:20:01.671 | HD Request # 42 | Enabling Intraday chart updating for symbol. 2024-04-30 15:20:01.671 | 2024-04-30 15:20:01.671 | Triggering next historical data download in queue. 2024-04-30 15:20:01.672 | HD Request # 43 | Downloading Intraday chart data for NQM4.CME to the file NQM4.CME.scid. Service: rithmic.trading 2024-04-30 15:20:01.672 | HD Request # 43 | Download start date-time: 2024-04-30 15:19:52.000000. File last date-time: 2024-04-30 15:19:52.000007 2024-04-30 15:20:01.672 | HD Request # 43 | Using server: rsc-de.rithmic.com port 40802. Use encryption. 2024-04-30 15:20:01.672 | Socket (4) | Creating socket. Using TLS 1.2. 2024-04-30 15:20:01.672 | Socket (4) | New receive buffer size: 0 2024-04-30 15:20:01.672 | Socket (4) | Connecting to IP: 130.117.187.66. 2024-04-30 15:20:01.678 | Socket (3) | Socket gracefully closed by remote side. 2024-04-30 15:20:01.678 | Socket (3) | Closed. 2024-04-30 15:20:01.692 | HD Request # 43 | Sending historical data logon request message. 2024-04-30 15:20:01.835 | HD Request # 43 | Requesting Intraday data. Start date-time: 2024-04-30 15:19:52. Record interval: 0. Symbol: NQM4.CME 2024-04-30 15:20:02.048 | HD Request # 43 | Receiving Intraday data for NQM4.CME starting at 2024-04-30 15:19:52.005000 2024-04-30 15:20:02.066 | Socket (4) | CloseSocket call. 2024-04-30 15:20:02.066 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-04-30 15:20:02.070 | Historical data download thread signaled to stop. 2024-04-30 15:20:02.070 | HD Request # 43 | Timestamp of first Intraday data file record written: 2024-04-30 15:19:52.005000. 2024-04-30 15:20:02.070 | HD Request # 43 | Received 43 Intraday data records from 2024-04-30 15:19:52.005000 to 2024-04-30 15:20:01.781002 (9.8 seconds. Delay: 0.3 seconds) and wrote 43 records for NQM4.CME 2024-04-30 15:20:02.076 | HD Request # 43 | Add time&sales data | Remembered last file record date-time: 2024-04-30 13:20:01.781002 2024-04-30 15:20:02.077 | HD Request # 43 | Completion time: 1s. 2024-04-30 15:20:02.077 | HD Request # 43 | Intraday data download complete for NQM4.CME. Unique request ID: 47 2024-04-30 15:20:02.077 | Removing historical data download ID 47. 2024-04-30 15:20:02.077 | Real-time Intraday chart data file updates started for NQM4.CME 2024-04-30 15:20:02.077 | Intraday chart data file opened for NQM4.CME 2024-04-30 15:20:02.077 | HD Request # 43 | Enabling Intraday chart updating for symbol. 2024-04-30 15:20:02.077 | 2024-04-30 15:20:02.077 | Triggering next historical data download in queue. 2024-04-30 15:20:02.077 | HD Request # 44 | Downloading Intraday chart data for ESM4.CME to the file ESM4.CME.scid. Service: rithmic.trading 2024-04-30 15:20:02.077 | HD Request # 44 | Download start date-time: 2024-04-30 15:19:52.000000. File last date-time: 2024-04-30 15:19:52.000015 2024-04-30 15:20:02.077 | HD Request # 44 | Using server: rsc-de.rithmic.com port 40802. Use encryption. 2024-04-30 15:20:02.077 | Socket (3) | Creating socket. Using TLS 1.2. 2024-04-30 15:20:02.077 | Socket (3) | New receive buffer size: 0 2024-04-30 15:20:02.077 | Socket (3) | Connecting to IP: 130.117.187.66. 2024-04-30 15:20:02.085 | Socket (4) | Socket gracefully closed by remote side. 2024-04-30 15:20:02.085 | Socket (4) | Closed. 2024-04-30 15:20:02.095 | HD Request # 44 | Sending historical data logon request message. 2024-04-30 15:20:02.242 | HD Request # 44 | Requesting Intraday data. Start date-time: 2024-04-30 15:19:52. Record interval: 0. Symbol: ESM4.CME 2024-04-30 15:20:02.455 | HD Request # 44 | Receiving Intraday data for ESM4.CME starting at 2024-04-30 15:19:52.005000 2024-04-30 15:20:02.467 | Socket (3) | CloseSocket call. 2024-04-30 15:20:02.467 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-04-30 15:20:02.480 | Historical data download thread signaled to stop. 2024-04-30 15:20:02.480 | HD Request # 44 | Timestamp of first Intraday data file record written: 2024-04-30 15:19:52.005000. 2024-04-30 15:20:02.480 | HD Request # 44 | Received 123 Intraday data records from 2024-04-30 15:19:52.005000 to 2024-04-30 15:20:00.812003 (8.8 seconds. Delay: 1.7 seconds) and wrote 123 records for ESM4.CME 2024-04-30 15:20:02.484 | Socket (3) | Socket gracefully closed by remote side. 2024-04-30 15:20:02.484 | Socket (3) | Closed. 2024-04-30 15:20:02.485 | HD Request # 44 | Add time&sales data | Remembered last file record date-time: 2024-04-30 13:20:00.812003 2024-04-30 15:20:02.485 | HD Request # 44 | Completion time: 0s. 2024-04-30 15:20:02.485 | HD Request # 44 | Intraday data download complete for ESM4.CME. Unique request ID: 48 2024-04-30 15:20:02.485 | Removing historical data download ID 48. 2024-04-30 15:20:02.485 | Real-time Intraday chart data file updates started for ESM4.CME 2024-04-30 15:20:02.485 | Intraday chart data file opened for ESM4.CME 2024-04-30 15:20:02.485 | HD Request # 44 | Enabling Intraday chart updating for symbol. 2024-04-30 15:20:02.485 | 2024-04-30 15:20:02.485 | Triggering next historical data download in queue. 2024-04-30 15:20:02.485 | HD Request # 45 | Downloading Intraday chart data for CLM4.NYMEX to the file CLM4.NYMEX.scid. Service: rithmic.trading 2024-04-30 15:20:02.485 | HD Request # 45 | Download start date-time: 2024-04-30 15:19:52.000000. File last date-time: 2024-04-30 15:19:52.000006 2024-04-30 15:20:02.486 | HD Request # 45 | Using server: rsc-de.rithmic.com port 40802. Use encryption. 2024-04-30 15:20:02.486 | Socket (3) | Creating socket. Using TLS 1.2. 2024-04-30 15:20:02.486 | Socket (3) | New receive buffer size: 0 2024-04-30 15:20:02.486 | Socket (3) | Connecting to IP: 130.117.187.66. 2024-04-30 15:20:02.505 | HD Request # 45 | Sending historical data logon request message. 2024-04-30 15:20:02.641 | HD Request # 45 | Requesting Intraday data. Start date-time: 2024-04-30 15:19:52. Record interval: 0. Symbol: CLM4.NYMEX 2024-04-30 15:20:02.855 | HD Request # 45 | Receiving Intraday data for CLM4.NYMEX starting at 2024-04-30 15:19:52.495000 2024-04-30 15:20:02.867 | Socket (3) | CloseSocket call. 2024-04-30 15:20:02.867 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-04-30 15:20:02.872 | Historical data download thread signaled to stop. 2024-04-30 15:20:02.872 | HD Request # 45 | Timestamp of first Intraday data file record written: 2024-04-30 15:19:52.495000. 2024-04-30 15:20:02.872 | HD Request # 45 | Received 57 Intraday data records from 2024-04-30 15:19:52.495000 to 2024-04-30 15:20:02.855000 (10.4 seconds. Delay: 0.0 seconds) and wrote 57 records for CLM4.NYMEX 2024-04-30 15:20:02.877 | HD Request # 45 | Add time&sales data | Remembered last file record date-time: 2024-04-30 13:20:02.855000 2024-04-30 15:20:02.877 | HD Request # 45 | Completion time: 0s. 2024-04-30 15:20:02.877 | HD Request # 45 | Intraday data download complete for CLM4.NYMEX. Unique request ID: 49 2024-04-30 15:20:02.877 | Removing historical data download ID 49. 2024-04-30 15:20:02.877 | Real-time Intraday chart data file updates started for CLM4.NYMEX 2024-04-30 15:20:02.877 | Intraday chart data file opened for CLM4.NYMEX 2024-04-30 15:20:02.877 | HD Request # 45 | Enabling Intraday chart updating for symbol. 2024-04-30 15:20:02.877 | 2024-04-30 15:20:02.877 | Triggering next historical data download in queue. 2024-04-30 15:20:02.877 | HD Request # 46 | Downloading Intraday chart data for YMM4.CBOT to the file YMM4.CBOT.scid. Service: rithmic.trading 2024-04-30 15:20:02.878 | HD Request # 46 | Download start date-time: 2024-04-30 15:19:52.000000. File last date-time: 2024-04-30 15:19:52.000001 2024-04-30 15:20:02.878 | HD Request # 46 | Using server: rsc-de.rithmic.com port 40802. Use encryption. 2024-04-30 15:20:02.878 | Socket (4) | Creating socket. Using TLS 1.2. 2024-04-30 15:20:02.878 | Socket (4) | New receive buffer size: 0 2024-04-30 15:20:02.878 | Socket (4) | Connecting to IP: 130.117.187.66. 2024-04-30 15:20:02.893 | Socket (3) | Socket gracefully closed by remote side. 2024-04-30 15:20:02.893 | Socket (3) | Closed. 2024-04-30 15:20:02.899 | HD Request # 46 | Sending historical data logon request message. 2024-04-30 15:20:03.044 | HD Request # 46 | Requesting Intraday data. Start date-time: 2024-04-30 15:19:52. Record interval: 0. Symbol: YMM4.CBOT 2024-04-30 15:20:03.255 | HD Request # 46 | Receiving Intraday data for YMM4.CBOT starting at 2024-04-30 15:19:52.400000 2024-04-30 15:20:03.262 | Socket (4) | CloseSocket call. 2024-04-30 15:20:03.262 | Socket (4) | Shutdown started. Waiting for graceful close. 2024-04-30 15:20:03.276 | Socket (4) | Socket gracefully closed by remote side. 2024-04-30 15:20:03.276 | Socket (4) | Closed. 2024-04-30 15:20:03.287 | Historical data download thread signaled to stop. 2024-04-30 15:20:03.287 | HD Request # 46 | Timestamp of first Intraday data file record written: 2024-04-30 15:19:52.400000. 2024-04-30 15:20:03.287 | HD Request # 46 | Received 12 Intraday data records from 2024-04-30 15:19:52.400000 to 2024-04-30 15:20:03.412000 (11.0 seconds. Delay: -0.1 seconds) and wrote 12 records for YMM4.CBOT 2024-04-30 15:20:03.293 | HD Request # 46 | Add time&sales data | Remembered last file record date-time: 2024-04-30 13:20:03.412000 2024-04-30 15:20:03.293 | HD Request # 46 | Completion time: 1s. 2024-04-30 15:20:03.293 | HD Request # 46 | Intraday data download complete for YMM4.CBOT. Unique request ID: 50 2024-04-30 15:20:03.293 | Removing historical data download ID 50. 2024-04-30 15:20:03.293 | Real-time Intraday chart data file updates started for YMM4.CBOT 2024-04-30 15:20:03.293 | Intraday chart data file opened for YMM4.CBOT 2024-04-30 15:20:03.293 | HD Request # 46 | Enabling Intraday chart updating for symbol. 2024-04-30 15:20:03.293 | 2024-04-30 15:20:03.293 | Triggering next historical data download in queue. 2024-04-30 15:20:03.293 | HD Request # 47 | Downloading Intraday chart data for 6EM4.CME to the file 6EM4.CME.scid. Service: rithmic.trading 2024-04-30 15:20:03.293 | HD Request # 47 | Download start date-time: 2024-04-30 15:19:52.000000. File last date-time: 2024-04-30 15:19:52.000010 2024-04-30 15:20:03.293 | HD Request # 47 | Using server: rsc-de.rithmic.com port 40802. Use encryption. 2024-04-30 15:20:03.293 | Socket (3) | Creating socket. Using TLS 1.2. 2024-04-30 15:20:03.293 | Socket (3) | New receive buffer size: 0 2024-04-30 15:20:03.293 | Socket (3) | Connecting to IP: 130.117.187.66. 2024-04-30 15:20:03.308 | HD Request # 47 | Sending historical data logon request message. 2024-04-30 15:20:03.455 | HD Request # 47 | Requesting Intraday data. Start date-time: 2024-04-30 15:19:52. Record interval: 0. Symbol: 6EM4.CME 2024-04-30 15:20:03.671 | HD Request # 47 | Receiving Intraday data for 6EM4.CME starting at 2024-04-30 15:19:52.143000 2024-04-30 15:20:03.681 | Socket (3) | CloseSocket call. 2024-04-30 15:20:03.681 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-04-30 15:20:03.687 | Historical data download thread signaled to stop. 2024-04-30 15:20:03.687 | HD Request # 47 | Timestamp of first Intraday data file record written: 2024-04-30 15:19:52.143000. 2024-04-30 15:20:03.687 | HD Request # 47 | Received 93 Intraday data records from 2024-04-30 15:19:52.143000 to 2024-04-30 15:20:04.003000 (11.9 seconds. Delay: -0.3 seconds) and wrote 93 records for 6EM4.CME 2024-04-30 15:20:03.692 | HD Request # 47 | Add time&sales data | Remembered last file record date-time: 2024-04-30 13:20:04.003000 2024-04-30 15:20:03.692 | HD Request # 47 | Completion time: 0s. 2024-04-30 15:20:03.692 | HD Request # 47 | Intraday data download complete for 6EM4.CME. Unique request ID: 51 2024-04-30 15:20:03.692 | Removing historical data download ID 51. 2024-04-30 15:20:03.692 | Real-time Intraday chart data file updates started for 6EM4.CME 2024-04-30 15:20:03.692 | Intraday chart data file opened for 6EM4.CME 2024-04-30 15:20:03.692 | HD Request # 47 | Enabling Intraday chart updating for symbol. 2024-04-30 15:20:03.692 | 2024-04-30 15:20:03.692 | No download requests in the queue to start downloads for. 2024-04-30 15:20:03.697 | Socket (3) | Socket gracefully closed by remote side. 2024-04-30 15:20:03.697 | Socket (3) | Closed. 2024-04-30 15:20:04.032 | Opened cached Intraday file: C:\Sierra Chart\Data\GCM4.COMEX.scid. Thread ID: 12880 2024-04-30 15:20:04.033 | Opened cached Intraday file: C:\Sierra Chart\Data\NQM4.CME.scid. Thread ID: 12880 2024-04-30 15:20:04.033 | Opened cached Intraday file: C:\Sierra Chart\Data\ESM4.CME.scid. Thread ID: 12880 2024-04-30 15:20:04.033 | Opened cached Intraday file: C:\Sierra Chart\Data\CLM4.NYMEX.scid. Thread ID: 12880 2024-04-30 15:20:04.033 | Opened cached Intraday file: C:\Sierra Chart\Data\YMM4.CBOT.scid. Thread ID: 12880 2024-04-30 15:20:09.095 | Opened cached Intraday file: C:\Sierra Chart\Data\6EM4.CME.scid. Thread ID: 12880 2024-04-30 15:20:16.060 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Creating socket. Using TLS 1.2. 2024-04-30 15:20:16.060 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | New receive buffer size: 0 2024-04-30 15:20:16.060 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Connecting to IP: 38.79.0.89. 2024-04-30 15:20:16.759 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Socket gracefully closed by remote side. | Number times message added: 1 2024-04-30 15:20:16.769 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | CloseSocket call. 2024-04-30 15:20:16.769 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-04-30 15:20:16.769 | HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (3) | Closed. |
[2024-04-30 13:23:06] |
User497465 - Posts: 35 |
when i want to set a trade: 2024-04-30 15:09:13.214 | TradeActivity files query time: 0.057193 seconds. Entries: 0. Current queries: 2 2024-04-30 15:09:13.219 | TradeActivity files query time: 0.005120 seconds. Entries: 550. Current queries: 2 2024-04-30 15:09:18.781 | Rithmic Direct - DTC | Requesting trade accounts from server. 2024-04-30 15:09:18.893 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: 4PROP-PQRR. 2024-04-30 15:09:18.893 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: 4PROP-UOOR. 2024-04-30 15:09:18.893 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: 4PROP-UIUZ. 2024-04-30 15:09:18.893 | Rithmic Direct - DTC | Received 3 accounts from service. 2024-04-30 15:09:18.916 | TradeActivity files query time: 0.022804 seconds. Entries: 0. Current queries: 3 2024-04-30 15:09:18.916 | Rithmic Direct - DTC | Requesting historical account balances for account 4PROP-PQRR. Start date-time UTC: 2023-12-28 13:09:18 2024-04-30 15:09:18.942 | TradeActivity files query time: 0.026013 seconds. Entries: 0. Current queries: 2 2024-04-30 15:09:18.942 | Rithmic Direct - DTC | Requesting historical account balances for account 4PROP-UOOR. Start date-time UTC: 2023-12-28 13:09:18 2024-04-30 15:09:18.965 | TradeActivity files query time: 0.023377 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:18.965 | Rithmic Direct - DTC | Requesting historical account balances for account 4PROP-UIUZ. Start date-time UTC: 2023-12-28 13:09:18 2024-04-30 15:09:19.044 | Rithmic Direct - DTC | Requesting Trade Positions data. 2024-04-30 15:09:22.319 | TradeActivity files query time: 0.001051 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:22.323 | TradeActivity files query time: 0.000995 seconds. Entries: 0. Current queries: 2 2024-04-30 15:09:22.325 | TradeActivity files query time: 0.000716 seconds. Entries: 0. Current queries: 3 2024-04-30 15:09:22.329 | TradeActivity files query time: 0.000684 seconds. Entries: 0. Current queries: 4 2024-04-30 15:09:22.339 | TradeActivity files query time: 0.000937 seconds. Entries: 0. Current queries: 5 2024-04-30 15:09:22.351 | TradeActivity files query time: 0.001575 seconds. Entries: 0. Current queries: 6 2024-04-30 15:09:22.364 | TradeActivity files query time: 0.001156 seconds. Entries: 0. Current queries: 7 2024-04-30 15:09:22.370 | TradeActivity files query time: 0.002510 seconds. Entries: 0. Current queries: 8 2024-04-30 15:09:22.375 | TradeActivity files query time: 0.000769 seconds. Entries: 0. Current queries: 9 2024-04-30 15:09:22.407 | TradeActivity files query time: 0.002139 seconds. Entries: 0. Current queries: 10 2024-04-30 15:09:22.411 | TradeActivity files query time: 0.000771 seconds. Entries: 0. Current queries: 11 2024-04-30 15:09:22.428 | TradeActivity files query time: 0.001794 seconds. Entries: 0. Current queries: 12 2024-04-30 15:09:22.435 | TradeActivity files query time: 0.000916 seconds. Entries: 0. Current queries: 13 2024-04-30 15:09:22.526 | TradeActivity files query time: 0.001881 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:22.605 | TradeActivity files query time: 0.001726 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:22.615 | TradeActivity files query time: 0.001900 seconds. Entries: 0. Current queries: 2 2024-04-30 15:09:22.737 | TradeActivity files query time: 0.001668 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:22.812 | TradeActivity files query time: 0.001841 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:24.359 | TradeActivity files query time: 0.001563 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:24.755 | TradeActivity files query time: 0.002058 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:26.164 | TradeActivity files query time: 0.001979 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:26.421 | TradeActivity files query time: 0.001788 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:28.831 | TradeActivity files query time: 0.008897 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:28.838 | TradeActivity files query time: 0.003763 seconds. Entries: 0. Current queries: 2 2024-04-30 15:09:45.428 | TradeActivity files query time: 0.005170 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:45.522 | TradeActivity files query time: 0.000971 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:45.549 | TradeActivity files query time: 0.000647 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:45.557 | TradeActivity files query time: 0.000667 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:50.048 | TradeActivity files query time: 0.003930 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:50.140 | TradeActivity files query time: 0.003346 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:53.110 | TradeActivity files query time: 0.000692 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:53.174 | TradeActivity files query time: 0.000829 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:53.226 | TradeActivity files query time: 0.000815 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:53.237 | TradeActivity files query time: 0.000667 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:56.141 | TradeActivity files query time: 0.003659 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:56.147 | TradeActivity files query time: 0.003405 seconds. Entries: 0. Current queries: 2 2024-04-30 15:09:59.241 | TradeActivity files query time: 0.000833 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:59.273 | TradeActivity files query time: 0.000837 seconds. Entries: 0. Current queries: 1 2024-04-30 15:09:59.288 | TradeActivity files query time: 0.000633 seconds. Entries: 0. Current queries: 2 2024-04-30 15:09:59.291 | TradeActivity files query time: 0.000724 seconds. Entries: 0. Current queries: 3 2024-04-30 15:10:00.325 | TradeActivity files query time: 0.027840 seconds. Entries: 0. Current queries: 1 2024-04-30 15:10:00.367 | TradeActivity files query time: 0.003560 seconds. Entries: 0. Current queries: 2 2024-04-30 15:10:03.234 | TradeActivity files query time: 0.006673 seconds. Entries: 0. Current queries: 1 2024-04-30 15:10:03.239 | TradeActivity files query time: 0.000805 seconds. Entries: 0. Current queries: 2 2024-04-30 15:10:03.276 | TradeActivity files query time: 0.000873 seconds. Entries: 0. Current queries: 1 2024-04-30 15:10:03.279 | TradeActivity files query time: 0.000703 seconds. Entries: 0. Current queries: 2 2024-04-30 15:10:03.922 | TradeActivity files query time: 0.003801 seconds. Entries: 0. Current queries: 1 2024-04-30 15:10:03.949 | TradeActivity files query time: 0.003321 seconds. Entries: 0. Current queries: 1 2024-04-30 15:10:05.251 | TradeActivity files query time: 0.000959 seconds. Entries: 0. Current queries: 1 2024-04-30 15:10:05.283 | TradeActivity files query time: 0.000935 seconds. Entries: 0. Current queries: 1 2024-04-30 15:10:05.297 | TradeActivity files query time: 0.000736 seconds. Entries: 0. Current queries: 2 2024-04-30 15:10:05.318 | TradeActivity files query time: 0.000811 seconds. Entries: 0. Current queries: 1 2024-04-30 15:10:18.382 | TradeActivity files query time: 0.008306 seconds. Entries: 0. Current queries: 1 2024-04-30 15:10:18.444 | TradeActivity files query time: 0.003500 seconds. Entries: 0. Current queries: 1 2024-04-30 15:10:20.357 | Rithmic Direct - DTC | Requesting trade accounts from server. 2024-04-30 15:10:20.487 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: 4PROP-PQRR. 2024-04-30 15:10:20.487 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: 4PROP-UOOR. 2024-04-30 15:10:20.487 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: 4PROP-UIUZ. 2024-04-30 15:10:20.487 | Rithmic Direct - DTC | Received 3 accounts from service. 2024-04-30 15:10:20.611 | TradeActivity files query time: 0.124774 seconds. Entries: 0. Current queries: 3 2024-04-30 15:10:20.615 | Rithmic Direct - DTC | Requesting historical account balances for account 4PROP-PQRR. Start date-time UTC: 2023-12-28 13:10:20 2024-04-30 15:10:20.639 | TradeActivity files query time: 0.027589 seconds. Entries: 0. Current queries: 2 2024-04-30 15:10:20.639 | Rithmic Direct - DTC | Requesting historical account balances for account 4PROP-UOOR. Start date-time UTC: 2023-12-28 13:10:20 2024-04-30 15:10:20.642 | Rithmic Direct - DTC | Requesting Trade Positions data. 2024-04-30 15:10:20.673 | TradeActivity files query time: 0.033805 seconds. Entries: 0. Current queries: 1 2024-04-30 15:10:20.693 | Rithmic Direct - DTC | Requesting historical account balances for account 4PROP-UIUZ. Start date-time UTC: 2023-12-28 13:10:20 2024-04-30 15:10:26.906 | Rithmic Direct - DTC (Order reject). Info: Account not active. Internal Order ID: 5283. Service Order ID: 1820389731. Symbol: GCM4.COMEX. Account: 4PROP-UOOR * 2024-04-30 15:11:16.038 | TradeActivity files query time: 0.013181 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:16.099 | TradeActivity files query time: 0.001118 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:16.103 | TradeActivity files query time: 0.000756 seconds. Entries: 0. Current queries: 2 2024-04-30 15:11:16.189 | TradeActivity files query time: 0.038136 seconds. Entries: 0. Current queries: 2 2024-04-30 15:11:16.190 | TradeActivity files query time: 0.000825 seconds. Entries: 0. Current queries: 2 2024-04-30 15:11:16.254 | TradeActivity files query time: 0.001002 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:16.342 | TradeActivity files query time: 0.006903 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:16.364 | TradeActivity files query time: 0.001867 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:16.411 | TradeActivity files query time: 0.000820 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:16.424 | TradeActivity files query time: 0.001175 seconds. Entries: 0. Current queries: 2 2024-04-30 15:11:16.492 | TradeActivity files query time: 0.006807 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:16.500 | TradeActivity files query time: 0.001203 seconds. Entries: 0. Current queries: 2 2024-04-30 15:11:16.547 | TradeActivity files query time: 0.006426 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:16.580 | TradeActivity files query time: 0.001677 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:16.651 | TradeActivity files query time: 0.005500 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:16.664 | TradeActivity files query time: 0.006275 seconds. Entries: 0. Current queries: 2 2024-04-30 15:11:16.843 | TradeActivity files query time: 0.005466 seconds. Entries: 0. Current queries: 2 2024-04-30 15:11:16.848 | TradeActivity files query time: 0.005049 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:18.671 | TradeActivity files query time: 0.005123 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:18.693 | TradeActivity files query time: 0.005333 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:18.909 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-04-30 15:11:18.909 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-04-30 15:11:20.193 | TradeActivity files query time: 0.004993 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:20.200 | TradeActivity files query time: 0.004726 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:21.228 | TradeActivity files query time: 0.026202 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:21.302 | TradeActivity files query time: 0.003403 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:26.167 | TradeActivity files query time: 0.003513 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:26.247 | TradeActivity files query time: 0.003294 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:34.296 | TradeActivity files query time: 0.005518 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:34.363 | TradeActivity files query time: 0.000951 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:34.403 | TradeActivity files query time: 0.000843 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:34.418 | TradeActivity files query time: 0.001023 seconds. Entries: 0. Current queries: 2 2024-04-30 15:11:34.451 | TradeActivity files query time: 0.000815 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:34.602 | TradeActivity files query time: 0.001288 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:34.677 | TradeActivity files query time: 0.000971 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:34.682 | TradeActivity files query time: 0.001708 seconds. Entries: 0. Current queries: 2 2024-04-30 15:11:34.723 | TradeActivity files query time: 0.001568 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:34.757 | TradeActivity files query time: 0.001143 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:34.771 | TradeActivity files query time: 0.001110 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:34.813 | TradeActivity files query time: 0.001113 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:34.890 | TradeActivity files query time: 0.001493 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:34.907 | TradeActivity files query time: 0.001530 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:34.937 | TradeActivity files query time: 0.001591 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:34.977 | TradeActivity files query time: 0.001454 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:35.029 | TradeActivity files query time: 0.001521 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:35.128 | TradeActivity files query time: 0.001440 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:35.209 | TradeActivity files query time: 0.003661 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:35.346 | TradeActivity files query time: 0.003783 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:36.812 | TradeActivity files query time: 0.001519 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:36.835 | TradeActivity files query time: 0.001392 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:38.070 | TradeActivity files query time: 0.001464 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:38.334 | TradeActivity files query time: 0.001374 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:38.424 | Rithmic Direct - DTC | Requesting trade accounts from server. 2024-04-30 15:11:38.552 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: 4PROP-PQRR. 2024-04-30 15:11:38.552 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: 4PROP-UOOR. 2024-04-30 15:11:38.552 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: 4PROP-UIUZ. 2024-04-30 15:11:38.552 | Rithmic Direct - DTC | Received 3 accounts from service. 2024-04-30 15:11:38.677 | TradeActivity files query time: 0.125808 seconds. Entries: 0. Current queries: 3 2024-04-30 15:11:38.679 | Rithmic Direct - DTC | Requesting historical account balances for account 4PROP-PQRR. Start date-time UTC: 2023-12-28 13:11:38 2024-04-30 15:11:38.705 | TradeActivity files query time: 0.027227 seconds. Entries: 0. Current queries: 2 2024-04-30 15:11:38.724 | TradeActivity files query time: 0.019326 seconds. Entries: 0. Current queries: 2 2024-04-30 15:11:38.727 | Rithmic Direct - DTC | Requesting historical account balances for account 4PROP-UOOR. Start date-time UTC: 2023-12-28 13:11:38 2024-04-30 15:11:38.727 | Rithmic Direct - DTC | Requesting historical account balances for account 4PROP-UIUZ. Start date-time UTC: 2023-12-28 13:11:38 2024-04-30 15:11:38.751 | Rithmic Direct - DTC | Requesting Trade Positions data. 2024-04-30 15:11:45.822 | TradeActivity files query time: 0.000763 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:45.954 | TradeActivity files query time: 0.000789 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:45.982 | TradeActivity files query time: 0.000856 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:45.990 | TradeActivity files query time: 0.000786 seconds. Entries: 0. Current queries: 2 2024-04-30 15:11:50.481 | TradeActivity files query time: 0.008829 seconds. Entries: 0. Current queries: 2 2024-04-30 15:11:50.485 | TradeActivity files query time: 0.003515 seconds. Entries: 0. Current queries: 2 2024-04-30 15:11:57.629 | TradeActivity files query time: 0.005483 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:57.704 | TradeActivity files query time: 0.000821 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:57.751 | TradeActivity files query time: 0.000844 seconds. Entries: 0. Current queries: 1 2024-04-30 15:11:57.762 | TradeActivity files query time: 0.000785 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:00.110 | TradeActivity files query time: 0.003725 seconds. Entries: 0. Current queries: 2 2024-04-30 15:12:00.113 | TradeActivity files query time: 0.003716 seconds. Entries: 0. Current queries: 2 2024-04-30 15:12:00.768 | TradeActivity files query time: 0.000871 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:00.795 | TradeActivity files query time: 0.000791 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:00.813 | TradeActivity files query time: 0.000888 seconds. Entries: 0. Current queries: 2 2024-04-30 15:12:00.816 | TradeActivity files query time: 0.000690 seconds. Entries: 0. Current queries: 3 2024-04-30 15:12:01.323 | TradeActivity files query time: 0.003610 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:01.352 | TradeActivity files query time: 0.003545 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:02.622 | TradeActivity files query time: 0.000806 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:02.643 | TradeActivity files query time: 0.000894 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:02.674 | TradeActivity files query time: 0.000718 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:02.677 | TradeActivity files query time: 0.000680 seconds. Entries: 0. Current queries: 2 2024-04-30 15:12:03.321 | TradeActivity files query time: 0.003893 seconds. Entries: 0. Current queries: 2 2024-04-30 15:12:03.324 | TradeActivity files query time: 0.003545 seconds. Entries: 0. Current queries: 2 2024-04-30 15:12:04.791 | TradeActivity files query time: 0.000867 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:04.817 | TradeActivity files query time: 0.000920 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:04.851 | TradeActivity files query time: 0.000708 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:04.856 | TradeActivity files query time: 0.000699 seconds. Entries: 0. Current queries: 2 2024-04-30 15:12:05.496 | TradeActivity files query time: 0.003560 seconds. Entries: 0. Current queries: 2 2024-04-30 15:12:05.499 | TradeActivity files query time: 0.003508 seconds. Entries: 0. Current queries: 2 2024-04-30 15:12:06.929 | TradeActivity files query time: 0.001030 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:06.958 | TradeActivity files query time: 0.000678 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:06.968 | TradeActivity files query time: 0.000636 seconds. Entries: 0. Current queries: 2 2024-04-30 15:12:06.971 | TradeActivity files query time: 0.000779 seconds. Entries: 0. Current queries: 3 2024-04-30 15:12:07.777 | TradeActivity files query time: 0.003712 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:07.819 | TradeActivity files query time: 0.003580 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:12.322 | TradeActivity files query time: 0.000954 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:12.441 | TradeActivity files query time: 0.000794 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:12.470 | TradeActivity files query time: 0.000737 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:12.478 | TradeActivity files query time: 0.000726 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:16.424 | TradeActivity files query time: 0.003616 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:16.450 | TradeActivity files query time: 0.003460 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:38.062 | TradeActivity files query time: 0.000749 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:38.163 | TradeActivity files query time: 0.000800 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:38.209 | TradeActivity files query time: 0.000988 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:38.220 | TradeActivity files query time: 0.000772 seconds. Entries: 0. Current queries: 2 2024-04-30 15:12:40.524 | TradeActivity files query time: 0.003651 seconds. Entries: 0. Current queries: 2 2024-04-30 15:12:40.527 | TradeActivity files query time: 0.003640 seconds. Entries: 0. Current queries: 2 2024-04-30 15:12:43.056 | TradeActivity files query time: 0.000822 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:43.070 | TradeActivity files query time: 0.001014 seconds. Entries: 0. Current queries: 2 2024-04-30 15:12:43.116 | TradeActivity files query time: 0.000874 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:43.123 | TradeActivity files query time: 0.000724 seconds. Entries: 0. Current queries: 2 2024-04-30 15:12:43.608 | TradeActivity files query time: 0.003444 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:43.621 | TradeActivity files query time: 0.003326 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:47.715 | TradeActivity files query time: 0.000746 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:47.726 | TradeActivity files query time: 0.000706 seconds. Entries: 0. Current queries: 2 2024-04-30 15:12:47.741 | TradeActivity files query time: 0.000789 seconds. Entries: 0. Current queries: 3 2024-04-30 15:12:47.745 | TradeActivity files query time: 0.000735 seconds. Entries: 0. Current queries: 4 2024-04-30 15:12:48.360 | TradeActivity files query time: 0.003811 seconds. Entries: 0. Current queries: 1 2024-04-30 15:12:48.380 | TradeActivity files query time: 0.003466 seconds. Entries: 0. Current queries: 1 2024-04-30 15:13:27.664 | TradeActivity files query time: 0.000953 seconds. Entries: 0. Current queries: 1 2024-04-30 15:13:27.690 | TradeActivity files query time: 0.000871 seconds. Entries: 0. Current queries: 1 2024-04-30 15:13:27.725 | TradeActivity files query time: 0.000727 seconds. Entries: 0. Current queries: 1 2024-04-30 15:13:27.730 | TradeActivity files query time: 0.000771 seconds. Entries: 0. Current queries: 2 2024-04-30 15:13:28.360 | TradeActivity files query time: 0.003589 seconds. Entries: 0. Current queries: 1 2024-04-30 15:13:28.407 | TradeActivity files query time: 0.003456 seconds. Entries: 0. Current queries: 1 2024-04-30 15:14:02.497 | TradeActivity files query time: 0.000892 seconds. Entries: 0. Current queries: 1 2024-04-30 15:14:02.509 | TradeActivity files query time: 0.000772 seconds. Entries: 0. Current queries: 2 2024-04-30 15:14:02.548 | TradeActivity files query time: 0.000750 seconds. Entries: 0. Current queries: 1 2024-04-30 15:14:02.551 | TradeActivity files query time: 0.000703 seconds. Entries: 0. Current queries: 2 2024-04-30 15:14:03.178 | TradeActivity files query time: 0.003690 seconds. Entries: 0. Current queries: 1 2024-04-30 15:14:03.220 | TradeActivity files query time: 0.003442 seconds. Entries: 0. Current queries: 1 2024-04-30 15:15:45.423 | Rithmic Direct - DTC (Order reject). Info: Account not active. Internal Order ID: 5284. Service Order ID: 1820400046. Symbol: ESM4.CME. Account: 4PROP-UOOR * 2024-04-30 15:16:55.484 | Rithmic Direct - DTC (Order reject). Info: Account not active. Internal Order ID: 5285. Service Order ID: 1820402111. Symbol: ESM4.CME. Account: 4PROP-UOOR * 2024-04-30 15:17:17.676 | TradeActivity files query time: 0.006464 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:17.709 | TradeActivity files query time: 0.001151 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:17.768 | TradeActivity files query time: 0.001177 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:17.801 | TradeActivity files query time: 0.001309 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:17.836 | TradeActivity files query time: 0.001169 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:17.882 | TradeActivity files query time: 0.007537 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:17.887 | TradeActivity files query time: 0.001076 seconds. Entries: 0. Current queries: 2 2024-04-30 15:17:17.950 | TradeActivity files query time: 0.000950 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:18.000 | TradeActivity files query time: 0.005109 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:18.011 | TradeActivity files query time: 0.006046 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:18.032 | TradeActivity files query time: 0.000922 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:18.080 | TradeActivity files query time: 0.006195 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:18.087 | TradeActivity files query time: 0.000840 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:18.109 | TradeActivity files query time: 0.000943 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:18.269 | TradeActivity files query time: 0.001518 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:18.286 | TradeActivity files query time: 0.001528 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:18.317 | TradeActivity files query time: 0.001449 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:18.360 | TradeActivity files query time: 0.001401 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:19.766 | TradeActivity files query time: 0.004975 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:19.787 | TradeActivity files query time: 0.004859 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:20.306 | Delayed Data Feed | MaxConnectionsDifferentDevices = 4, NumCurrentConnectionsDifferentDevices = 1 2024-04-30 15:17:20.306 | Delayed Data Feed | MaxConnectionsForSameDevice = 4, NumCurrentConnectionsForSameDevice = 1 2024-04-30 15:17:21.121 | TradeActivity files query time: 0.004864 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:21.136 | TradeActivity files query time: 0.004942 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:22.472 | TradeActivity files query time: 0.008127 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:22.484 | TradeActivity files query time: 0.003631 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:26.914 | TradeActivity files query time: 0.003573 seconds. Entries: 0. Current queries: 1 2024-04-30 15:17:26.992 | TradeActivity files query time: 0.003468 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:28.793 | TradeActivity files query time: 0.005825 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:28.867 | TradeActivity files query time: 0.001516 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:28.910 | TradeActivity files query time: 0.000941 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:28.925 | TradeActivity files query time: 0.001103 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:28.935 | TradeActivity files query time: 0.000760 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:28.971 | TradeActivity files query time: 0.001219 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:29.051 | TradeActivity files query time: 0.001101 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:29.112 | TradeActivity files query time: 0.001077 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:29.151 | TradeActivity files query time: 0.001136 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:29.204 | TradeActivity files query time: 0.002139 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:29.235 | TradeActivity files query time: 0.001701 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:29.244 | TradeActivity files query time: 0.000936 seconds. Entries: 0. Current queries: 2 2024-04-30 15:18:29.273 | TradeActivity files query time: 0.001436 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:29.377 | TradeActivity files query time: 0.001772 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:29.482 | TradeActivity files query time: 0.001439 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:29.508 | TradeActivity files query time: 0.001628 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:29.514 | TradeActivity files query time: 0.001463 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:29.656 | TradeActivity files query time: 0.001688 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:29.736 | TradeActivity files query time: 0.003570 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:29.817 | TradeActivity files query time: 0.003536 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:31.151 | TradeActivity files query time: 0.001463 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:31.259 | TradeActivity files query time: 0.001456 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:32.723 | TradeActivity files query time: 0.001517 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:32.740 | TradeActivity files query time: 0.001353 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:32.921 | Rithmic Direct - DTC | Requesting trade accounts from server. 2024-04-30 15:18:33.044 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: 4PROP-PQRR. 2024-04-30 15:18:33.044 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: 4PROP-UOOR. 2024-04-30 15:18:33.044 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: 4PROP-UIUZ. 2024-04-30 15:18:33.044 | Rithmic Direct - DTC | Received 3 accounts from service. 2024-04-30 15:18:33.060 | TradeActivity files query time: 0.015965 seconds. Entries: 0. Current queries: 3 2024-04-30 15:18:33.064 | Rithmic Direct - DTC | Requesting historical account balances for account 4PROP-PQRR. Start date-time UTC: 2023-12-28 13:18:33 2024-04-30 15:18:33.084 | TradeActivity files query time: 0.023213 seconds. Entries: 0. Current queries: 2 2024-04-30 15:18:33.084 | Rithmic Direct - DTC | Requesting historical account balances for account 4PROP-UOOR. Start date-time UTC: 2023-12-28 13:18:33 2024-04-30 15:18:33.103 | TradeActivity files query time: 0.019015 seconds. Entries: 0. Current queries: 1 2024-04-30 15:18:33.103 | Rithmic Direct - DTC | Requesting historical account balances for account 4PROP-UIUZ. Start date-time UTC: 2023-12-28 13:18:33 2024-04-30 15:18:33.160 | Rithmic Direct - DTC | Requesting Trade Positions data. 2024-04-30 15:19:39.997 | Rithmic Direct - DTC (Order reject). Info: Account not active. Internal Order ID: 5286. Service Order ID: 1820406929. Symbol: ESM4.CME. Account: 4PROP-UOOR * 2024-04-30 15:19:56.236 | Rithmic Direct - DTC | Requesting trade accounts from server. 2024-04-30 15:19:56.392 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: 4PROP-PQRR. 2024-04-30 15:19:56.392 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: 4PROP-UOOR. 2024-04-30 15:19:56.392 | Rithmic Direct - DTC | Performing query for most recent account balances Date-Time for Trade Account: 4PROP-UIUZ. 2024-04-30 15:19:56.392 | Rithmic Direct - DTC | Received 3 accounts from service. 2024-04-30 15:19:56.407 | TradeActivity files query time: 0.015587 seconds. Entries: 0. Current queries: 3 2024-04-30 15:19:56.409 | Rithmic Direct - DTC | Requesting historical account balances for account 4PROP-PQRR. Start date-time UTC: 2023-12-28 13:19:56 2024-04-30 15:19:56.430 | TradeActivity files query time: 0.022789 seconds. Entries: 0. Current queries: 2 2024-04-30 15:19:56.430 | Rithmic Direct - DTC | Requesting historical account balances for account 4PROP-UOOR. Start date-time UTC: 2023-12-28 13:19:56 2024-04-30 15:19:56.449 | TradeActivity files query time: 0.019081 seconds. Entries: 0. Current queries: 1 2024-04-30 15:19:56.450 | Rithmic Direct - DTC | Requesting historical account balances for account 4PROP-UIUZ. Start date-time UTC: 2023-12-28 13:19:56 2024-04-30 15:19:56.511 | Rithmic Direct - DTC | Requesting Trade Positions data. 2024-04-30 15:22:03.462 | Rithmic Direct - DTC (Order reject). Info: Account not active. Internal Order ID: 5287. Service Order ID: 1820413497. Symbol: ESM4.CME. Account: 4PROP-UOOR * |
[2024-04-30 13:24:05] |
but here i can see, that i actually have another account name. this should be the new one 4PROP-PQRR. why is this not activated? |
[2024-04-30 13:30:42] |
now i chaged the account everywhere trade-> attach trade window to chart and change account in every window. my laptop did this automatically. why my computer not?
[2024-04-30 14:11:58] |
and another confusing behavoir, this time of my orderbook in Cl. it can't stand still, is always rolling up or down, so that placing an order isn't possible
[2024-04-30 16:51:27] |
Now that you have the correct trade account selected are you still having an issue? With regards to the chart for CL, if this is a Trading DOM, then make sure the Scale is set to "Constant Range" and then Reset the scale. Refer to the following: Chart Scale and Scale Adjusting: Constant Range (Scale Range) Chart Scale and Scale Adjusting: Resetting the Scale For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-03 14:07:31] |
thanks for your help
