Date/Time: Wed, 27 Nov 2024 08:49:28 +0000
Subgraph in Region 2 NOT based on Main Chart Symbol
View Count: 1347
[2014-08-15 18:23:47] |
User68474 - Posts: 201 |
Is it possible to include/insert a chart+ its studies into/onto a main chart's Region 2, which is NOT based upon that main chart but rather upon another independent chart (i.e. which is NOT the main chart) ?? An example might be having the ES as Main Graph, but in Region 2 having the T-NYSE or even Tick-Nasdaq ???
[2014-08-18 17:36:59] |
Yes, refer to the documentation here for this: Sierra Chart Market Statistics: Overlaying a Chart on Another Chart as a Study When you overlay a price graph from another chart on a chart, you can then base studies on it by using the "Based On" setting: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#BasedOn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
