Date/Time: Sun, 24 Nov 2024 20:40:52 +0000
Gros ordres
View Count: 206
[2024-04-29 13:28:20]
User914407 - Posts: 38
Bonjour,
Comment fonctionne le champ "Volume filter" dans "Chart settings" ?
Exemple : si "Exclude<= 200" alors j'aurai les trades unitaires de 200 lots minimum ou alors j'aurais le total des trades faisant plus de 200 lots sur un niveau de prix?
Merci
[2024-04-29 17:46:15]
We need you to post on the Support Board with your active Sierra Chart account. To do that select "Help >> Support Board " from within Sierra Chart.
If you did not get an answer to your prior question, post here again after doing the above confirming that you have logged in with your current account to let us know.
