Date/Time: Sun, 24 Nov 2024 16:33:17 +0000
Copy data to excel
View Count: 261
[2024-04-29 10:14:43] |
User266447 - Posts: 253 |
I have a two questions: how can I copy data (price and volume) to excel from a choicen chart? And the second question: as the price and volume displayed on a chart are different from a i.e. 4 hour chart and a point and figure chart, if I copy data (price and volume) from the point and figure chart wiil it be the data which is on the chart or it will be a data from a standard (intra-day, or historical) chart? |
[2024-04-29 17:26:22] |
Use the Spreadsheet Study input to save the data to a text file: https://www.sierrachart.com/index.php?page=doc/SpreadsheetStudyInputs.html#PeriodicallySaveSheetAsTextInMinutes Yes: wiil it be the data which is on the chart
[2024-05-02 07:17:06] |
Could you confim, if I use point and figure chart i.e. 18-6 and I download the data from the chart (price and volume) will I have the data from the chart or it will come as price and wolume from a i.e. daily chart?
[2024-05-02 15:09:12] |
The saved data from the Spreadsheet (or when using "Edit >> Export Bar Data to File") is the actual bar data that is in the chart. If you want to get the intraday data that is actually stored in the data file, then you would use "Edit >> Export Intraday Data". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-09 17:41:43] |
Is it possible to save the downloaded text files to .csv?
[2024-05-09 17:56:36] |
Please never mind the last question
