Date/Time: Sun, 24 Nov 2024 20:41:49 +0000
connection error CQG
View Count: 172
[2024-04-29 08:57:19] |
User811741 - Posts: 3 |
Hi I get the concurrent session error and it logs me off even though I am just connecting on the one PC and don't have any other connections running.
Attachment Deleted. |
[2024-04-29 12:40:39] |
Sierra_Chart Engineering - Posts: 17161 |
There must be another connection that you are unaware of. If you need further help you need to ask CQG. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-29 12:41:03
