Date/Time: Sun, 24 Nov 2024 20:22:20 +0000
AutoTrade Control Bar Buttons to toggle Long Entry / Short Entry
View Count: 243
[2024-04-29 00:53:29]
Bedhog - Posts: 179
Hello Team,
I have control bar buttons for [Auto Trade] and [AutoTrd Chart].
Are there Control Bar buttons to enable/disable long and short trades?
If no, may I have them? :)
For example:
[Auto Trade] [Autotrd Chart] [AutoTrd Long] [AutoTrd Short]
I've considered this workaround but don't want the performance hit. i.e. duplicate the chartbook and have only long trades on one, and only short trades enabled on the other.
Thank you in advance!
imagecontrolbar.png / V - Attached On 2024-04-29 00:52:03 UTC - Size: 4.04 KB - 63 views
[2024-04-29 17:22:58]
There are no control bar buttons that do this specifically, but if you have a custom study that you are using, then you can build this into your study. Refer to the following:
Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events: Advanced Custom Study Buttons and Pointer Events
