Date/Time: Sun, 24 Nov 2024 20:44:56 +0000
Limit order not showing up on DOM / Chart
View Count: 270
[2024-04-28 23:38:49] |
User276813 - Posts: 64 |
Please see attached screenshots. This is an issue all the sudden, never a problem before. Just opened the chart and now its a problem. If I enter an order on the DOM, it doesn't show up on the chart. If I enter an order on the chart, it doesn't show up on the DOM. If I flip over to SIM mode, it works fine and the orders show up as they should. |
Screenshot 2024-04-28 193534.png / V - Attached On 2024-04-28 23:37:02 UTC - Size: 116.17 KB - 73 views Screenshot 2024-04-28 193622.png / V - Attached On 2024-04-28 23:37:06 UTC - Size: 131.07 KB - 51 views |
[2024-04-29 17:18:05] |
Refer to the following - specifically step #3: Chart Trading and the Chart DOM: Enabling Display of Orders and Trade Position, and Configuration of Orders and Trade Position Display For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
