Date/Time: Sun, 24 Nov 2024 20:23:22 +0000
Multiple VbP for TPO?
View Count: 206
[2024-04-28 15:11:35] |
User2069 - Posts: 20 |
I was wondering if it's possible to have more than 1 VbP study properly associated with a TPO, each with it's own space. Currently i have one that is left aligned displaying the volume and wanted to add another for Delta but it gets added right on top of the first one and i can't really add it there since i have that one color coded and would like to keep it like that. I tried aligning the delta on the right which is how i wanted it anyways and it kind of works but it overlaps a lot and i had to make it really transparent to still be able to see the other one properly. Is there some way to control the spacing or sizing of them in any way so at least they don't overlap and i can make the delta fully visible?
[2024-04-29 17:04:18] |
There is no specific solution for what you are trying to do. What you have done is the best option available.
[2024-04-29 18:42:54] |
I see, i managed to find a way that works a little bit better for me but i had a feeling that would more or less be the case, thank you for confirming.
