Date/Time: Thu, 19 Sep 2024 16:14:33 +0000
i do not want to see yesterdays data
View Count: 889
[2014-08-15 13:44:16] |
mayerrs - Posts: 70 |
hi, i would like to set sierra to NOT see yesterdays data. i mean, i have chart of TICK-NYSE. i set this chart "use number of fays to load" 0 and sice 9:30:00 to 11:59:59 but when i start sierra next day i always see yesterdays data. am i somehow able to set sierra to not see previouse day? i just want to see actual day my time period. thank you |
[2014-08-15 16:52:10] |
You need to set Chart >> Chart Settings >Use Number of Days to Load >> Days to Load to 1. After this, when the new trading day begins, you need to select Chart >> Reload and Recalculate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-15 16:52:27
