Date/Time: Sun, 24 Nov 2024 20:24:45 +0000
Trade order/position/account monitor windows
View Count: 265
[2024-04-27 21:54:53] |
User112927 - Posts: 9 |
Hello SC support, Thank you for such a great platform. My question is regarding to fields within the Trade order/position/account monitor windows. I understand you can drag the | to the left to 'minimize' each field to an extend, is there an option to select which fields to be displayed/hided? For example, hiding the 'Internal Order ID' field under the trade order window, or the 'currency' field under the trade position window, or the 'description' field under account monitor window? Thanks in advance. Date Time Of Last Edit: 2024-04-27 21:56:36
[2024-04-28 14:01:10] |
Sierra_Chart Engineering - Posts: 17161 |
No there is not a way to completely remove a field from these windows. There is a substantial amount of work to support that. And it is something we just have never done. You can drag them off to the right side and resize the window itself.
[2024-04-29 00:54:50] |
Thank you for the clarification!
