Date/Time: Sun, 24 Nov 2024 20:39:36 +0000
SI-1000 tick size
View Count: 183
[2024-04-27 17:18:21] |
User8135477 - Posts: 115 |
SI futures are traded with a tick size of 0.005, but my chart only shows in 0.01 increments. I tried to adjust this in the Symbol settings, but my vertical scale still rounds to the nearest 0.01. How do I fix this?
[2024-04-28 14:59:02] |
Sierra_Chart Engineering - Posts: 17161 |
Follow the instructions here: Global Symbol Settings: Update/Apply Symbol Settings to Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
