Date/Time: Wed, 27 Nov 2024 08:29:38 +0000
OEC Sierra Charts Down not printing bars on some of the charts
View Count: 926
[2014-08-15 13:22:57] |
User84455 - Posts: 32 |
please help
[2014-08-15 16:38:01] |
Most likely this is an issue with OEC. Refer to help topic 3 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails3.html You may have gone over the 5 symbol limit which is explained here: http://www.sierrachart.com/index.php?page=doc/openecry.php#Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
