Date/Time: Sun, 24 Nov 2024 18:35:42 +0000
Unable to add studies on custom chart bars
View Count: 214
[2024-04-27 15:11:53] |
jwchong - Posts: 1 |
I'm trying to add studies on custom chart bars (ACSIL Interface - Custom Chart Bars). But it doesn't seem possible through the GUI. Are there workarounds to this issue? Steps to reproduce: 1. Add "Custom Range Chart Bars Example" built from the official SC code (Chart Study -> Add Custom Study -> Sierra Chart Custom Studies and Examples). 2. Add "Moving Average - Exponential", change "Based On" to "Custom Range Bars". Issue: it doesn't display any choices for "Input Data". Related issue: the "Bar Time Duration" study doesn't display correct values on custom chart bars. Date Time Of Last Edit: 2024-04-27 15:12:19
[2024-04-30 21:06:23] |
Sierra_Chart Engineering - Posts: 17156 |
When using a Custom Chart Bars study, there is not a need to use Based On to base other studies on it. That inherently happens. There is nothing special to do.
[2024-05-02 19:49:02] |
This will be resolved in the next release: Related issue: the "Bar Time Duration" study doesn't display correct values on custom chart bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
