Date/Time: Wed, 27 Nov 2024 08:32:32 +0000
Inter-Market Divergence
View Count: 1977
[2014-08-15 12:09:46] |
KrystoFx - Posts: 3 |
Is it possible to do this with sierra chart (signal to automatically show you when correlated market relationships are breaking down)? Thx |
intermarket.png / V - Attached On 2014-08-15 12:08:54 UTC - Size: 34.02 KB - 555 views |
[2014-08-15 16:53:33] |
The question is too vague for us to answer.
[2014-08-15 19:36:53] |
Please look the picture intermarket.png. SPX500 is the main graph and when sp make a new high, but NQ not make new high, the alert appear. |
[2014-08-18 09:29:18] |
This is what we recommend doing: -Add the Daily OHLC study to both charts: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s137 -Set the Graph High Low Historically (0 Reference Days Back) Input with the studies to Yes. - Overlay the Daily OHLC study from one of the charts to the other, so they are both present on a single chart. Refer to this help topic for instructions: Http://www.sierrachart.com/index.php?page=doc/helpdetails28.html -You can then write a Simple Alert Formula to reference the Daily OHLC studies to check for your condition: http://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-18 09:29:53
