Date/Time: Sun, 24 Nov 2024 02:05:19 +0000
USDJPY Historical Data - Beginning 2007-12-03
View Count: 403
[2024-04-26 08:42:38]
User34124 - Posts: 276
Seems to be some small error here. The other pairs mostly go back to 1993, could they all be checked please? This is quite crucial seeing as so many Yen pairs are breaking highs. And pairs such as USDJPY look way different compared to the pairs with data going back to 1993.
[2024-04-26 11:53:49]
Sierra_Chart Engineering - Posts: 17154
We have increased the amount of historical data for this symbol.
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download" from the main Sierra Chart menu. You just need to do this once per symbol and not for each chart. This command is on the main Sierra Chart menu at the top. Only use it from that location.
[2024-04-26 12:02:56]
That worked a treat. Now goes back to 1980, which is very handy as that decade was extremely important for global FX. Can you do the across all FX pairs?
Date Time Of Last Edit: 2024-04-26 12:03:07
[2024-06-07 13:29:34]
Please please can you do the same for GBPUSD? Back to 1980 (or even 1973)?
[2024-06-10 19:50:16]
We will check on this.
[2024-06-18 00:04:54]
Sorry to bother you again. CHFJPY on the monthly only goes back to 1993, new highs now so the chart looks really off-whack.
A consistency of <1984 with the FX historical graphs would be VERY appreciated!
[2024-06-26 20:13:48]
We will get to this as soon as possible.
[2024-07-03 15:22:16]
We have added more historical data for GBPUSD.
We cannot add any more historical data for CHFJPY. Unless you have a good source, where we can obtain it. We checked a source and they do not have anything further back than 1993. It actually only goes back to 2001.
Date Time Of Last Edit: 2024-07-03 15:22:46
