Date/Time: Sun, 24 Nov 2024 21:02:18 +0000
Can I add a button to the control bar to set a specific instrument?
View Count: 264
[2024-04-26 07:41:09]
User367161 - Posts: 10
I basically know, how to add and remove buttons. If I use the "Find Symbol" button, it will open a new chart.
My charts in the present chartbook are linked. So what I want, is a button (eg FGBL) That will change the symbol on my active chart (not open a new one) and subsequently changing it on the other open charts.
Best regards,
Andreas
[2024-04-26 14:46:27]
There is not a built-in way to do this.
You could create a custom study to do this for you. Refer to the following:
ACSIL Interface Members - Variables and Arrays: sc.DataFile
List of Third Party Sierra Chart Study and System Programmers
[2024-04-26 15:31:09]
... oh my ...
Thank you anyway.
[2024-04-26 15:55:42]
Sierra_Chart Engineering - Posts: 17161
You can open a Chartbook:
Control Bar: Control Bar Chartbook Buttons
[2024-04-26 19:03:39]
User832812 - Posts: 7
Isn't this supported using a watchlist?
[2024-04-26 20:30:31]
Yes, you can do that. Refer to the following:
Changing the Symbol of a Chart: Using Compact Associated Watch List on Control Bar for Chart or Trade DOM
